Anyone else having trouble with Gimp?
The global menu is extremely sluggish and it makes my fans spin up. Also it’s basically unusable because the modifier keys aren’t working for selections and rubber stamp.
Kernel: 6.8.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw rootflags=subvol=@
splash rd.udev.log_priority=3 loglevel=3
drm.edid_firmware=DisplayPort-0:/edid/Samsung-EDID-RGB.bin intel_iommu=on
iommu=pt vfio-pci.ids=10de:1d01,10de:0fb8 plymouth.enable=0
disablehooks=plymouth ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_x11 tools: avail: xlock,xscreensaver vt: 2 dm: SDDM Distro: Garuda
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F28
date: 12/14/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x122
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 987 high: 1104 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1099 3: 1100
4: 800 5: 1100 6: 800 7: 1100 8: 1103 9: 800 10: 1098 11: 1100 12: 800
13: 1100 14: 800 15: 1100 16: 800 17: 1100 18: 1100 19: 800 20: 1100
21: 800 22: 800 23: 1101 24: 1104 bogomips: 164044
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73a5
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: vfio-pci v: N/A alternate: nouveau non-free: 545.xx+ status: current
(as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 04:00.0 chip-ID: 10de:1d01
Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.1:7
chip-ID: 1532:0e03 class-ID: 0102
Device-4: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:9 chip-ID: 534d:2109
Device-5: Elgato Systems GmbH Game Capture HD60 X
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.1:4
chip-ID: 0fd9:0082 class-ID: 0300 serial: <filter>
Device-6: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.2:8
chip-ID: 07ca:0110 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Screen-1: 0 s-res: 6400x2160 s-dpi: 96 s-size: 1693x571mm (66.65x22.48")
s-diag: 1787mm (70.34")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-left model: Samsung
serial: <filter> built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: bottom-r model: DP2VGA V221
built: 2015 res: 640x240 hz: 60 dpi: 64 gamma: 1.2
size: 256x192mm (10.08x7.56") diag: 690mm (27.2") ratio: 16:9 modes:
max: 1024x768 min: 640x480
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 17.0.6 DRM 3.57 6.8.5-zen1-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: vfio-pci alternate: snd_hda_intel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 04:00.1 chip-ID: 10de:0fb8
Device-4: PreSonus Audio AudioBox USB driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12.3:18
chip-ID: 194f:0302 class-ID: 0103
Device-5: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-6: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-7: MacroSilicon USB Video
Device-8: Emagic Soft- und Hardware GmbH Unitor8 driver: snd-usb-audio
type: USB rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.4.2:23
chip-ID: 086a:0001 class-ID: ff00
Device-9: Elgato Systems GmbH Game Capture HD60 X
Device-10: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.8.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3an Ethernet [Marvell
Scalable mGig] vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 2 port: N/A bus-ID: 09:00.0 chip-ID: 1d6a:14c0
class-ID: 0200 temp: 44.0 C
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
IF: enp10s0 state: down mac: <filter>
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:21 chip-ID: 8087:0033
Local Storage: total: 13.88 TiB used: 4.03 TiB (29.0%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 51.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 56.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:5 vendor: Western Digital
fw-rev: 731100WD temp: 55.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-5: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HUS724040ALA640
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: AA70 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: X110 2.5 7MM 256GB
tech: SSD serial: <filter> fw-rev: 412 scheme: GPT
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
ID-8: /dev/sde maj-min: 8:64 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.33 TiB (73.3%)
used: 2.1 MiB (0.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 1.33 TiB (73.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.62 GiB used: 872 MiB (1.4%) priority: 100
System Temperatures: cpu: 37.0 C mobo: N/A gpu: amdgpu temp: 58.0 C
mem: 58.0 C
Memory: total: 64 GiB note: est. available: 62.62 GiB
used: 10.95 GiB (17.5%)
Processes: 553 Power: uptime: 1d 16h 19m states: freeze,mem,disk
reboot, suspend, test_resume image: 25.01 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2417 libs: 621 tools: octopi,paru,yay
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.25-1):
System install date: 2023-05-03
Last full system update: 2024-04-14 ↻
