KDE git keeps crashing/crashing and crashing
  Kernel: 6.1.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=6eeb25be-f032-4b16-9353-02a2cfdce99c rw [email protected]
    loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.80 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 2
  Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 2601 date: 05/17/2022
  Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 4125 high: 5116 min/max: 800/5100 scaling:
    driver: intel_pstate governor: performance cores: 1: 5099 2: 3800 3: 3800
    4: 5096 5: 5116 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 5102 12: 3800
    13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121596
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
    ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
    bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 49.0 C
  Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.7
  Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
    built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
    diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
    missing.
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Sound API: ALSA v: k6.1.9-zen1-2-zen running: yes
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.18 TiB used: 17.83 GiB (0.5%)
    model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
    rev: 211070WD temp: 33.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
    rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
    rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
    used: 17.83 GiB (7.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
  System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 49.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1201
  Processes: 358 Uptime: 2h 17m wakeups: 0 Memory: 31.25 GiB
  used: 3.39 GiB (10.9%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1349
  libs: 327 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.0
Garuda (2.6.14.r0.g8183f88-1):
  System install date:     2023-02-07
  Last full system update: 2023-02-08
  1. system keeps logging me out if I leave the computer unattended for 5 minutes and I did adjust all display setting to do nothing
  2. Every time I install something I get a password promote the pc will freeze and to unfreeze it I must look for the password box because sometime it will not show because other windows are open
  3. And now every time I try to change wallpaper / change anything I get an error message
    failed to launch
file:///usr/share/plasma/plasmoids/org.kde.latte.
plasmoid/contents/ui/main.qml:596:5:
TaskManagerApplet.DragHelper is not a type
KDE work fine here, since years, btw.
Why do you post garuda-inxi two times?
Let me edit your posts... :slight_smile:
I was looking for logs sorry
I Just uninstalled latte
Man I know it was causing problems :frowning:
so is that it ? The latte ?
Anyways it's -git packages so breakages are to be expected using those packages.
Ok so i was doing a fast read on the link that SGS provided above
and here is what i got // its about refreshing the keys //
sudo pacman-key --refresh-keys
Part 1
g: error reading key: No data
gpg: refreshing 1 key from hkps://keyserver.ubuntu.com
gpg: key E711306E3C4F88BC: 1 duplicate signature removed
gpg: key E711306E3C4F88BC: "Timothy Redaelli <[email protected]>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
gpg: key B02854ED753E0F1F: "Anatol Pomozov (Arch Linux developer account) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2014-02-04 [SC] [expires: 2026-10-25]
      8E1992167465DB5FB045557CB02854ED753E0F1F
uid           [  full  ] Anatol Pomozov (Arch Linux developer account) <[email protected]>
uid           [marginal] Anatol Pomozov <[email protected]>
sub   rsa4096 2014-02-04 [E] [expires: 2026-10-25]
gpg: error retrieving '[email protected]' via WKD: No data
gpg: error reading key: No data
gpg: key 5F946DED983D4366: "Justin Davis (juster) <[email protected]>" 1 new signature
gpg: key 5F946DED983D4366: "Justin Davis (juster) <[email protected]>" 1 new subkey
gpg: key 5F946DED983D4366: "Justin Davis (juster) <[email protected]>" 1 signature cleaned
gpg:            new subkeys: 1
gpg:         new signatures: 1
gpg:     signatures cleaned: 1
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:  15  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  15  signed:  96  trust: 0-, 0q, 0n, 15m, 0f, 0u
gpg: depth: 2  valid:  74  signed:  28  trust: 74-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-03-30
gpg: key 39E4B877E62EB915: "Sven-Hendrik Haase <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-09-10 [SC]
      8FC15A064950A99DD1BD14DD39E4B877E62EB915
uid           [marginal] Sven-Hendrik Haase <[email protected]>
uid           [  full  ] Sven-Hendrik Haase <[email protected]>
sub   rsa4096 2022-07-10 [A]
sub   rsa4096 2011-09-10 [E]
gpg: key 468F122CE8162295: "Santiago Torres-Arias <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2014-05-22 [SC] [expires: 2023-10-27]
      903BAB73640EB6D65533EFF3468F122CE8162295
uid           [  full  ] Santiago Torres-Arias <[email protected]>
uid           [marginal] Santiago Torres <[email protected]>
uid           [ unknown] Santiago Torres-Arias (Academic profile) <[email protected]>
uid           [marginal] Santiago Torres-Arias <[email protected]>
sub   rsa4096 2014-05-22 [E]
gpg: key BB992F9864FAD168: public key "David Runge <[email protected]>" imported
gpg: key 54C28F4FF5A1A949: "David Runge <[email protected]>" 6 new signatures
gpg: Total number processed: 2
gpg:               imported: 1
gpg:         new signatures: 6
gpg: depth: 2  valid:  74  signed:  29  trust: 74-, 0q, 0n, 0m, 0f, 0u
pub   ed25519 2022-04-29 [SC] [expires: 2026-04-28]
      1793DAD5D803A8FFD7451697BB992F9864FAD168
uid           [  undef ] David Runge <[email protected]>
sub   ed25519 2022-04-29 [A] [expires: 2026-04-28]
sub   cv25519 2022-04-29 [E] [expires: 2026-04-28]
gpg: key A88E23E377514E00: "Florian Pritz (Arch Linux Master Key) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2015-12-17 [SC]
      91FFE0700E80619CEB73235CA88E23E377514E00
uid           [  full  ] Florian Pritz (Arch Linux Master Key) <[email protected]>
sub   rsa4096 2015-12-17 [E]
gpg: error retrieving '[email protected]' via WKD: General error
gpg: error reading key: General error
gpg: key AFF5D95098BC6FF5: "Maxime Gauduin <[email protected]>" not changed
gpg: key 0F65C7D881506130: "Maxime Gauduin <[email protected]>" not changed
gpg:              unchanged: 2
pub   rsa2048 2013-01-21 [SC]
      9437DD3815A7A9169E3D3946AFF5D95098BC6FF5
uid           [marginal] Maxime Gauduin <[email protected]>
sub   rsa2048 2013-01-21 [E]
gpg: key E6B456CAF15447D5: 2 duplicate signatures removed
gpg: key E6B456CAF15447D5: "Federico Cinelli <[email protected]>" 1 signature cleaned
gpg: key 0F65C7D881506130: "Maxime Gauduin <[email protected]l.com>" not changed
gpg:              unchanged: 2
gpg: key C91A9911192C187A: "Daurnimator <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2015-01-25 [SC] [expires: 2023-08-02]
      954A3772D62EF90E4B31FBC6C91A9911192C187A
uid           [  full  ] Daurnimator <[email protected]>
uid           [marginal] Daurnimator <[email protected]>
sub   rsa4096 2016-04-06 [S] [expires: 2023-08-02]
sub   rsa4096 2016-04-06 [A] [expires: 2023-08-02]
sub   rsa4096 2015-01-25 [E] [expires: 2023-08-02]
gpg: key FCF3C8CB5CF9C8D4: 1 duplicate signature removed
gpg: key FCF3C8CB5CF9C8D4: "Alexander Rødseth <[email protected]>" 1 new signature
gpg: key FCF3C8CB5CF9C8D4: "Alexander Rødseth <[email protected]>" 1 signature cleaned
gpg: depth: 2  valid:  74  signed:  30  trust: 74-, 0q, 0n, 0m, 0f, 0u
gpg: key 1C736AEF96402E7C: "Andreas Schleifer <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2021-12-10 [SC]
      9674D4ED3DFB6ADCC4F9F1EA1C736AEF96402E7C
uid           [  full  ] Andreas Schleifer <[email protected]>
sub   rsa4096 2021-12-10 [E]
gpg: key 51DAE9B7C1AE9161: "NicoHood <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2015-06-17 [SCA] [expires: 2023-04-21]
      97312D5EB9D7AE7D0BD4307351DAE9B7C1AE9161
uid           [ unknown] NicoHood <[email protected]>
uid           [marginal] N <[email protected]>
uid           [marginal] NNNNN <[email protected]>
uid           [marginal] NicoHood <[email protected]>
uid           [  full  ] NicoHood <[email protected]>
uid           [marginal] _____ <[email protected]>
sub   rsa4096 2015-06-17 [E] [expires: 2023-04-21]
gpg: key 139B09DA5BF0D338: "David Runge <dvzr[email protected]>" not changed
gpg: key 7258734B41C31549: "David Runge <[email protected]>" not changed
gpg:              unchanged: 2
pub   ed25519 2022-05-10 [SC] [expires: 2026-05-09]
      991F6E3F0765CF6295888586139B09DA5BF0D338
uid           [  full  ] David Runge <[email protected]>
sub   ed25519 2022-05-10 [A] [expires: 2026-05-09]
sub   cv25519 2022-05-10 [E] [expires: 2026-05-09]
gpg: key 4AC5588F941C2A25: "Antonio Rojas <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2014-10-21 [SC]
      9D74DF6F91B7BDABD5815CA84AC5588F941C2A25
uid           [  full  ] Antonio Rojas <[email protected]>
uid           [marginal] Antonio Rojas <[email protected]>
sub   rsa2048 2014-11-07 [S]
sub   rsa2048 2014-11-07 [E]
gpg: key 19802F8B0D70FC30: "Jan Alexander Steffens (heftig) <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2020-05-11 [SC]
      A2FF3A36AAA56654109064AB19802F8B0D70FC30
uid           [ unknown] Jan Alexander Steffens (heftig) <[email protected]>
uid           [  full  ] Jan Alexander Steffens (heftig) <[email protected]>
sub   ed25519 2020-05-11 [A]
sub   ed25519 2020-05-11 [S]
sub   cv25519 2020-05-11 [E]
gpg: key 284FC34C8E4B1A25: "Thomas Bächler <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-05-04 [SC]
      A314827C4E4250A204CE6E13284FC34C8E4B1A25
uid           [ unknown] Thomas Bächler <[email protected]>
uid           [  undef ] Thomas Bächler <[email protected]>
sub   rsa4096 2011-05-04 [E]
gpg: key 46EC46F39F3E2EF1: "Remi Gacogne <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2014-10-22 [SC] [expires: 2023-11-09]
      A4CBEA7974898599195E4FEC46EC46F39F3E2EF1
uid           [  full  ] Remi Gacogne <[email protected]>
sub   rsa4096 2014-10-22 [E] [expires: 2023-11-09]
sub   rsa4096 2020-12-07 [S] [expires: 2023-11-09]
gpg: WARNING: unacceptable HTTP redirect from server was cleaned up
gpg: key 5C2E46A0F53A76ED: 1 duplicate signature removed
gpg: key 5C2E46A0F53A76ED: "Dan McGee <[email protected]>" 3 signatures cleaned
gpg:     signatures cleaned: 3
gpg: key 69DF1F2EB44B05BE: "Nicola Squartini <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-11-01 [SC] [revoked: 2022-08-14]
      A667E8A1B61D07A50FC430DF69DF1F2EB44B05BE
uid           [ revoked] Nicola Squartini <[email protected]>
gpg: key 976AC6FA3B94FA10: "Jan de Groot <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-06-06 [SC]
      A84B8DC73AB832067BE54C3C976AC6FA3B94FA10
uid           [ unknown] Jan de Groot <[email protected]>
sub   rsa2048 2011-06-06 [E]
gpg: key C847B6AEB0544167: 1 duplicate signature removed
gpg: key C847B6AEB0544167: "Nicola Squartini <[email protected]>" 1 signature cleaned
gpg: key BA1DFB64FFF979E7: "Allan McRae (Arch Linux Master Key) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-11-29 [SC] [revoked: 2022-05-10]
      AB19265E5D7D20687D303246BA1DFB64FFF979E7
uid           [ revoked] Allan McRae (Arch Linux Master Key) <[email protected]>
gpg: key 94657AB20F2A092B: "Andreas Radke <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-05-14 [SC]
      ADC8A1FCC15E01D45310419E94657AB20F2A092B
uid           [  full  ] Andreas Radke <[email protected]>
uid           [  undef ] Andreas Radke <[email protected]>
sub   rsa2048 2011-05-14 [E]
gpg: key 097D629E437520BD: 1 duplicate signature removed
gpg: key 097D629E437520BD: "Vesa Kaihlavirta <[email protected]>" 1 signature cleaned
gpg: key 59E43E106B247368: "Leonidas Spyropoulos <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2017-06-18 [SCA] [expires: 2023-12-01]
      B4B759625D4633430B74877059E43E106B247368
uid           [  full  ] Leonidas Spyropoulos <[email protected]>
uid           [ unknown] Leonidas Spyropoulos <[email protected]>
sub   rsa4096 2022-01-11 [A]
sub   rsa4096 2017-06-18 [E]
gpg: key 786C63F330D7CB92: "Felix Yan <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2012-01-20 [SC]
      B5971F2C5C10A9A08C60030F786C63F330D7CB92
uid           [  full  ] Felix Yan <[email protected]>
uid           [marginal] Felix Yan <[email protected]>
uid           [ unknown] Felix Yan <[email protected]>
uid           [  undef ] Felix Yan <[email protected]>
uid           [marginal] Yan, Ran (Name on Passport) <[email protected]>
uid           [marginal] keybase.io/felixonmars <[email protected]>
sub   rsa4096 2012-01-20 [E]
gpg: key 8DBD63B82072D77A: "SĂ©bastien Luttringer <[email protected]>" 1 new signature
pub   rsa4096 2011-11-11 [SC]
      B81B051F2D7FC867AAFF35A58DBD63B82072D77A
uid           [marginal] SĂ©bastien Luttringer <[email protected]>
uid           [  full  ] SĂ©bastien Luttringer <[email protected]>
sub   rsa4032 2014-03-30 [E]
sub   rsa4032 2017-07-07 [S]
sub   rsa4032 2017-07-07 [E]
sub   rsa4032 2014-03-30 [S]
sub   rsa4064 2012-12-12 [S]
sub   rsa4096 2013-03-30 [S]
sub   rsa4096 2013-03-30 [E]
sub   rsa4096 2011-11-11 [E]
sub   ed25519 2019-10-10 [S]
sub   cv25519 2019-10-10 [E]
gpg: key E2539214C6C11350: 1 duplicate signature removed
gpg: key E2539214C6C11350: "Federico Cinelli <[email protected]>" 1 signature cleaned
gpg: key 84818A6819AF4A9B: "Eli Schwartz <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2016-05-04 [SC] [expired: 2022-07-10]
      BD27B07A5EF45C2ADAF70E0484818A6819AF4A9B
uid           [ expired] Eli Schwartz <[email protected]>
gpg: key A06B49470F8E620A: "Brett Cornwall <[email protected]>" 6 new signatures
pub   ed25519 2018-10-03 [SC] [expires: 2024-07-09]
      BE2DBCF2B1E3E588AC325AEAA06B49470F8E620A
uid           [marginal] Brett Cornwall <[email protected]>
uid           [  full  ] Brett Cornwall <[email protected]>
sub   ed25519 2021-11-18 [A] [expires: 2024-07-09]
sub   ed25519 2021-11-18 [S] [expires: 2024-07-09]
sub   cv25519 2021-11-18 [E] [expires: 2024-07-09]
gpg: key 1F0CD4921ECAA030: 1 duplicate signature removed
gpg: key 1F0CD4921ECAA030: "Baptiste Jonglez <[email protected]>" 2 signatures cleaned
gpg: key 1F0CD4921ECAA030: "Baptiste Jonglez <[email protected]>" 1 user ID cleaned
gpg:     signatures cleaned: 2
gpg:       user IDs cleaned: 1
gpg: key 9C02FF419FECBE16: "Morten Linderud <[email protected]>" 1 new signature
pub   rsa4096 2014-09-05 [SC]
      C100346676634E80C940FB9E9C02FF419FECBE16
uid           [marginal] Morten Linderud <[email protected]>
uid           [  full  ] Morten Linderud <[email protected]>
sub   rsa4096 2018-11-26 [A]
sub   rsa4096 2014-09-05 [E]
sub   rsa4096 2018-11-13 [S]
part 2
gpg: key 930B82BFC2BDA011: "Fabio Castelli (Muflone) (VBSimple) <[email protected]>" not changed
gpg: key E642299183ED727E: "Fabio Castelli (Muflone) (Primary) <[email protected]>" not changed
gpg:              unchanged: 2
pub   rsa4096 2022-05-01 [SCE] [expires: 2023-12-18]
      42DFAFB7C03B2E4E7BBDBA69930B82BFC2BDA011
uid           [ unknown] Fabio Castelli (Muflone) (VBSimple) <[email protected]>
uid           [  full  ] Fabio Castelli (Muflone) (Arch Linux) <[email protected]>
uid           [ unknown] Fabio Castelli (Muflone) (Primary) <[email protected]>
sub   rsa4096 2022-05-01 [A] [expires: 2023-12-18]
gpg: key 139B09DA5BF0D338: "David Runge <[email protected]>" not changed
gpg:              unchanged: 2
gpg:              unchanged: 2
gpg: key 66E60E5F785A6824: "Campbell Jones (for package signing only) <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2022-08-16 [SC]
      CAAE0C97533C35D3A0C6C34066E60E5F785A6824
uid           [  full  ] Campbell Jones (for package signing only) <[email protected]>
sub   cv25519 2022-08-16 [E]
gpg: error retrieving '[email protected]' via WKD: No name
gpg: error reading key: No name
gpg: key 40AC6F48D55AB11D: "Ivy Foster <[email protected]>" not changed
gpg: key FCAC9CF5A6EE1209: "Ivy Foster <[email protected]>" not changed
gpg:              unchanged: 2
pub   ed25519 2021-10-27 [SC] [expires: 2026-10-26]
      DB5B4A9546601F945389C66940AC6F48D55AB11D
uid           [ unknown] Ivy Foster <[email protected]>
uid           [  full  ] Ivy Foster <[email protected]>
sub   cv25519 2021-10-27 [E] [expires: 2026-10-26]
gpg: key 81A402D4F382BBBD: "Brad Fanella <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2018-03-02 [SC]
      CC5967D4095B4F3B42D45FA081A402D4F382BBBD
uid           [ unknown] Brad Fanella <[email protected]>
sub   rsa2048 2018-03-02 [E]
gpg: key D4A753468A5A5B67: "Caleb Maclennan <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-07-12 [SC] [expires: 2023-07-12]
      CCB34EBBB9541EF3F7B366C1D4A753468A5A5B67
uid           [  full  ] Caleb Maclennan <[email protected]>
sub   rsa4096 2021-07-12 [S] [expires: 2023-07-12]
sub   cv25519 2021-07-12 [E] [expires: 2023-07-12]
gpg: key B61DBCE10901C163: 1 duplicate signature removed
gpg: key B61DBCE10901C163: "BallĂł György <[email protected]>" 1 new signature
gpg: key B61DBCE10901C163: "BallĂł György <[email protected]>" 1 signature cleaned
gpg: depth: 2  valid:  74  signed:  31  trust: 74-, 0q, 0n, 0m, 0f, 0u
gpg: key F4AA4E0ED2568E87: "Jiachen YANG (Arch Linux Packager Signing Key) <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2022-05-07 [SC] [expires: 2026-05-06]
      CE536327AED18EABC3B99A17F4AA4E0ED2568E87
uid           [  full  ] Jiachen YANG (Arch Linux Packager Signing Key) <[email protected]>
sub   cv25519 2022-05-07 [E] [expires: 2026-05-06]
gpg: key 6D1655C14CE1C13E: "Florian Pritz <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2008-08-01 [SCA]
      CFA6AF15E5C74149FC1D8C086D1655C14CE1C13E
uid           [marginal] Florian Pritz <[email protected]>
uid           [  full  ] Florian Pritz <[email protected]>
sub   rsa4096 2008-08-01 [E]
gpg: key 6D1A9E70E19DAA50: 1 duplicate signature removed
gpg: key 6D1A9E70E19DAA50: "Peter Richard Lewis <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 12C6F735F7A9A519: "Xyne. (Replaces EC3CBE7F607D11E663149E811D1F0DC78F173680.) <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-11-12 [SC]
      D89FAAEB4CECAFD199A2F5E612C6F735F7A9A519
uid           [  full  ] Xyne. (Replaces EC3CBE7F607D11E663149E811D1F0DC78F173680.) <[email protected]>
sub   cv25519 2021-11-12 [E]
gpg: key D6D055F927843F1C: "Levente Polyak (Arch Linux Master Key) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2018-11-08 [SC]
      D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C
uid           [  full  ] Levente Polyak (Arch Linux Master Key) <[email protected]>
sub   rsa4096 2018-11-08 [E]
sub   rsa4096 2018-11-08 [A]
gpg: key 81AF739EC0711BF1: "Rashif Rahman (Ray) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-10-31 [SC]
      D921CABED130A5690EF1896E81AF739EC0711BF1
uid           [ unknown] Rashif Rahman (Ray) <[email protected]>
sub   rsa2048 2011-10-31 [E]
gpg: key DB323392796CA067: 1 duplicate signature removed
gpg: key DB323392796CA067: 1 signature not checked due to a missing key
gpg: key DB323392796CA067: "Ike Devolder <[email protected]>" 1 new signature
gpg: key DB323392796CA067: "Ike Devolder <[email protected]>" 1 signature cleaned
gpg: public key DB323392796CA067 is 3037 days newer than the signature
gpg:              unchanged: 2
gpg: key 6BC26A17B9B7018A: "Alad Wenter <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2017-09-07 [SC] [expired: 2022-11-16]
      DBE7D3DD8C81D58D0A13D0E76BC26A17B9B7018A
uid           [ expired] Alad Wenter <[email protected]>
gpg: key 9B729B06A680C281: "BartĹ‚omiej Piotrowski (Arch Linux Master Key) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2017-05-15 [SC] [revoked: 2017-05-15]
      DDB867B92AA789C165EEFA799B729B06A680C281
uid           [ revoked] BartĹ‚omiej Piotrowski (Arch Linux Master Key) <[email protected]>
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
gpg: error retrieving '[email protected]' via WKD: No fingerprint
gpg: key FC1B547C8D8172C8: "Levente Polyak (anthraxx) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-11-07 [SC] [expires: 2023-12-31]
      E240B57E2C4630BA768E2F26FC1B547C8D8172C8
uid           [marginal] Levente Polyak (anthraxx) <[email protected]>
uid           [marginal] Levente Polyak (Jabber/XMPP only) <[email protected]>
uid           [marginal] Levente Polyak <[email protected]>
uid           [  full  ] Levente Polyak <[email protected]>
sub   rsa4096 2011-11-07 [E] [expires: 2023-12-31]
gpg: key C06086337C50773E: "Jelle van der Waa <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-10-08 [SC]
      E499C79F53C96A54E572FEE1C06086337C50773E
uid           [marginal] Jelle van der Waa <[email protected]>
uid           [  full  ] Jelle van der Waa <[email protected]>
sub   rsa2048 2011-10-08 [E]
gpg: key 56EC201BFC794362: "Chih-Hsuan Yen <[email protected]>" not changed
gpg: key 3FDDD575826C5C30: "Chih-Hsuan Yen <[email protected]>" not changed
gpg:              unchanged: 2
pub   ed25519 2022-08-10 [SC] [expires: 2023-08-10]
      E62545315B012B69C8C94A1D56EC201BFC794362
uid           [  full  ] Chih-Hsuan Yen <[email protected]>
sub   ed25519 2022-08-10 [S] [expires: 2023-08-10]
sub   ed25519 2022-08-11 [A] [expires: 2023-08-11]
sub   cv25519 2022-08-10 [E] [expires: 2023-08-10]
gpg: key A001876699AD6E84: "Gavin Marciniak-Bisesi <[email protected]>" 1 signature cleaned
gpg: key 426991CD8406FFF3: "Ronald van Haren <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-09-10 [SC]
      EA84EA00866F51FB10CD19AE426991CD8406FFF3
uid           [marginal] Ronald van Haren <[email protected]>
sub   rsa2048 2011-09-10 [E]
gpg: key B5DB77409B11B601: "Maxim Baz <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-10-24 [SC]
      56C3E775E72B0C8B1C0C1BD0B5DB77409B11B601
uid           [ unknown] Maxim Baz <[email protected]>
uid           [  full  ] Maxim Baz <[email protected]>
sub   ed25519 2021-10-24 [S]
sub   ed25519 2021-10-24 [A]
sub   cv25519 2021-10-24 [E]
gpg: key 1D1F0DC78F173680: 1 duplicate signature removed
gpg: key 1D1F0DC78F173680: "Xyne. (key #3) <[email protected]>" 1 signature cleaned
gpg: key F22FB1D78A77AEAB: "Giancarlo Razzolini (grazzolini) <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2016-11-11 [SC]
      ECCAC84C1BA08A6CC8E63FBBF22FB1D78A77AEAB
uid           [  full  ] Giancarlo Razzolini (grazzolini) <[email protected]>
sub   rsa4096 2016-11-11 [E]
gpg: error retrieving '[email protected]' via WKD: Network error
gpg: error reading key: Network error
gpg: key BBE43771487328A9: "Bartlomiej Piotrowski <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-10-10 [SC]
      F3691687D867B81B51CE07D9BBE43771487328A9
uid           [ unknown] Bartlomiej Piotrowski <[email protected]>
uid           [ unknown] Bartlomiej Piotrowski (Barthalion) <[email protected]>
uid           [ unknown] BartĹ‚omiej Piotrowski (Barthalion) <[email protected]>
uid           [ unknown] BartĹ‚omiej Piotrowski <[email protected]>
sub   rsa2048 2011-10-10 [E]
gpg: key E8F18BA1615137BC: "Ionut Biru <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-04-19 [SC]
      F4DDD6DDCEC320B665F502AAE8F18BA1615137BC
uid           [marginal] Ionut Biru <[email protected]>
sub   rsa2048 2011-04-19 [E]
gpg: key AF7EF7873CFD4BB6: 1 duplicate signature removed
gpg: key AF7EF7873CFD4BB6: "Jonathan Conder <[email protected]>" 1 signature cleaned
gpg: key B7310AE5F04569AE: "Giovanni Scafora <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-10-15 [SC]
      F648622B1715468FD654F45CB7310AE5F04569AE
uid           [ unknown] Giovanni Scafora <[email protected]>
sub   rsa2048 2011-10-15 [E]
gpg: key E48D0A8326DE47C5: "Morgan Adamiec <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2021-07-10 [SC]
      F850562FCDA369F80D33000AE48D0A8326DE47C5
uid           [  full  ] Morgan Adamiec <[email protected]>
uid           [ unknown] Morgan Adamiec <[email protected]>
sub   rsa4096 2021-07-29 [A]
sub   rsa4096 2021-07-10 [E]
gpg: key 905A8C3700E16349: "sudoforge <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2022-06-09 [C] [expires: 2025-01-31]
      FAD824618B562B99CCCE05FB905A8C3700E16349
uid           [ unknown] sudoforge <[email protected]>
sub   ed25519 2022-06-09 [A] [expires: 2025-01-31]
sub   ed25519 2022-06-09 [S] [expires: 2025-01-31]
sub   cv25519 2022-06-09 [E] [expires: 2025-01-31]
gpg: error retrieving '[email protected]' via WKD: Connection refused
gpg: error reading key: Connection refused
gpg: key C8880A6406361833: "Tom Gundersen <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-05-28 [SCEA]
      FB871F0131FEA4FB5A9192B4C8880A6406361833
uid           [  undef ] Tom Gundersen <[email protected]>
gpg: key 6E80CA1446879D04: "Jonas Witschel <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2019-09-04 [C] [expires: 2024-06-29]
      FE2E6249201CA54A4FB90D066E80CA1446879D04
uid           [ unknown] Jonas Witschel <[email protected]>
uid           [  full  ] Jonas Witschel <[email protected]>
uid           [marginal] Jonas Witschel <[email protected]>
sub   rsa4096 2019-09-04 [S] [expires: 2024-06-29]
sub   rsa4096 2019-09-04 [E] [expires: 2024-06-29]
gpg: key E074B83653CBB7BA: "Tim Meusel <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2020-11-15 [SC] [expires: 2025-11-14]
      FE5AFA6D5DE0070ADFA21BC5E074B83653CBB7BA
uid           [  full  ] Tim Meusel <[email protected]>
sub   rsa4096 2020-11-16 [S] [expires: 2025-11-15]
sub   cv25519 2020-11-15 [E] [expires: 2025-11-14]
gpg: key 57F3D9CC660431DD: "Nico Jensch <[email protected]>" not changed
gpg:              unchanged: 1
gpg: error retrieving '[email protected]dr460nf1r3.org' via WKD: No data
gpg: key 95A6D49D0BBD2A8B: "Nico Jensch (Chaotic-AUR '22) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key FBA220DFC880C036: "Nico Jensch (Chaotic-AUR) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key FA1A593985BF2B72: public key "[email protected] <[email protected]>" imported
gpg:               imported: 1
pub   rsa2048 2019-08-13 [SC]
      CEDFFAE09EA27C2ECF84C699FA1A593985BF2B72
uid           [ unknown] [email protected] <[email protected]>
sub   rsa2048 2019-08-13 [E]
gpg: key 3056513887B78AEB: "Pedro Henrique Lara Campos <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key D6C9442437365605: "TNE <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 749E88C8EC38D662: "Naman (Keygen for Chaotic AUR) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key FAF4946E8D60D074: "SGS Garuda Linux <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 8ADB4AEC585061CF: "Nico Jensch (Chaotic-AUR birdrepo builder) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 07D06351CA5B31BE: "Torsten KeĂźler <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2022-12-07 [SC] [expires: 2023-12-07]
      04CF0CD6F6EE93AE1896F58407D06351CA5B31BE
uid           [  full  ] Torsten KeĂźler <[email protected]>
sub   cv25519 2022-12-07 [E] [expires: 2023-12-07]
gpg: key 632C3CC0D1C9CAF6: "BallĂł György <[email protected]>" not changed
gpg:              unchanged: 1
pub   rsa4096 2022-12-09 [SC] [expires: 2025-01-01]
      14E46FE5FD69F2E287E244DB632C3CC0D1C9CAF6
uid           [  full  ] BallĂł György <[email protected]>
sub   rsa4096 2022-12-09 [A] [expires: 2025-01-01]
sub   rsa4096 2022-12-09 [E] [expires: 2025-01-01]
gpg: key 76A5EF9054449A5C: "Pierre Schmitz <[email protected]>" not changed
gpg: key 7F2D434B9741E8AC: "Pierre Schmitz <[email protected]>" not changed
gpg:              unchanged: 2
pub   ed25519 2022-10-31 [SC] [expires: 2037-10-27]
      3E80CA1A8B89F69CBA57D98A76A5EF9054449A5C
uid           [  full  ] Pierre Schmitz <[email protected]>
uid           [ unknown] Pierre Schmitz <[email protected]>
sub   ed25519 2022-10-31 [A] [expires: 2037-10-27]
sub   cv25519 2022-10-31 [E] [expires: 2037-10-27]
gpg: key 6BA0F5A2037F4F41: "Johannes Löthberg (Arch Linux Master Key) <[email protected]>" not changed
gpg:              unchanged: 1
pub   ed25519 2022-10-24 [SC]
      69E6471E3AE065297529832E6BA0F5A2037F4F41
uid           [  full  ] Johannes Löthberg (Arch Linux Master Key) <[email protected]>
sub   cv25519 2022-10-24 [E]
gpg: key 67D8BDF42AD93F4E: "Levon 'noptrix' Kayan (BlackArch Master) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key D295AA940EFDDF62: "Javier 'nrz' (BlackArch Master) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 63EC0ADBEA87E4E3: "Evan Teitelman <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 66E0CDBD1E01F333: "Evan Teitelman (BlackArch Master) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key 7533BAFE69A25079: "Levon 'noptrix' Kayan (BlackArch Developer) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key C75E985FF8B993B4: "Javier 'nrz' (BlackArch Developer) <[email protected]>" not changed
gpg:              unchanged: 1
gpg: key C65009B64EB7BB3C: "Evan Teitelman (BlackArch Developer) <[email protected]>" not changed
gpg:              unchanged: 1
Why have you installed unstable kde packages?
I think I know what you are talking about
I was doing an update, and it asked me Garuda is up-to-date, but there was an option
like never ask again/ignore/ something else
and I think by mistake I hit I Ignore
Was that it ?
Hummm, it would be surprising you mistakenly installed kde-git through garuda-update. That being said maybe you installed a dev or git package for some other reason and that package required the entire kde-git packages. I've seen that once.
I'll tell you what: if you don't explicitly need kde-git packages, you should revert back to standard kde 5.26.5 packages.
No, I don't think I need it
But can u tell me whats the difference ? is the KDE Git Better ?
"Better" is really subjective when we talk about git packages. loll
KDE git is the development branch of KDE packages, it contains all sorts of untested code, it can cause a bunch of undesired side effects like breaking other applications you use and causing visual glitches, suspend/resume/hibernate, login, lock screen issues, etc. etc. Almost anything could be impacted, it's like rolling dice, maybe you're lucky maybe you're not.
KDE git packages are almost only used for people who test that kind of stuff or test other packages with upcoming untested KDE code.
Ok so I Have tried all Garuda Flavors
  1. Mate was very good, but it stopped working
  2. Garuda Qtile it Loads to a Black screen and I posted for help, no one got back to me
  3. I don't mind the reinstalling // But none of them are surviving :slight_smile:
Any recommendations ?
Thank you
Have you already "tested" everything from Manjaro or EnOS?
MX Linux, Mint, Ubuntu...?
There are so many others and they are all bug free. :wink:
I did, BUT I LOVE Garuda and I made up my mind I enjoy my time with Garuda
I think you should go back to Mate, since you seemed to be very happy with it. It is very stable. Next time something breaks, roll back a snapshot or figure out how to fix it.
I Might do that But I would like to give KDE Dr460nized and Garuda Qtile another chance if only someone can tell me why Garuda Qtile loads up to a black screen ?
Very much depends your taste, I happily use the Sway edition.
It doesn't offer much for "ricing", and you'll end up head deep in your dotfiles, on the other hand it seems to be harder to wreck (I haven't yet managed to, that must mean something LOL).
"if it ain't broke... keep trying"
The hard and fast way to learn. Who cares how it works as long as it does.
Exactly, don't think to the bugs.
Make up your mind on what edition you like the most (excluding those for experienced users) and go for it!
I think most of the errors were determined by the fact that you are experiencing a lot. So, if you start from scratch and try to be let's say less "experimental" you will gain for sure stability (there are so many happy users for every edition).
Try also to take every "issue" as an opportunity to learn: try to solve it by yourself, search in the forum, search in the Arch Wiki and read it a lot and carefully! You'll love it.
