KDE freezes when plugging in power or attaching usb c power bank for charging
Has happened doing nothing or when running a game using steam.
Did not happen before KDE 6 was released & could be part of another exploit.
Much appreciated.
Kernel: 6.8.4-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=fb43e97c-1c95-43a6-9b71-d8cab7643f3d rw rootflags=subvol=@
quiet rd.luks.uuid=c8705c43-0d63-4823-a778-b7a9496c2a7a quiet
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: ASUSTeK product: ZenBook UX425UG_Q408UG v: 1.0
Mobo: ASUSTeK model: UX425UG v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: UX425UG.301
date: 12/05/2021
ID-1: BATT charge: 7.1 Wh (18.0%) condition: 39.5/63.1 Wh (62.6%)
volts: 12.0 min: 12.0 model: ASUSTeK UX425 type: Li-ion serial: <filter>
status: charging cycles: 124
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 592 high: 1713 min/max: 400/4056 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1713 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 1397 9: 400 10: 400 11: 400 12: 400
bogomips: 50325
Device-1: NVIDIA TU117M [GeForce MX450] vendor: ASUSTeK driver: nvidia
v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 02:00.0
chip-ID: 10de:1f9c class-ID: 0302
Device-2: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 46.0 C
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
gpu: nvidia,amdgpu display-ID: 0
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
renoir LLVM 17.0.6 DRM 3.57 6.8.4-hardened1-1-hardened)
device-ID: 1002:164c memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:164c surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce MX450 driver: nvidia v: 550.67
device-ID: 10de:1f9c surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.8.4-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Message: No PCI device data found.
Device-1: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.1:7
IF: enp4s0f4u1u1 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 26.63 GiB (2.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 47.9 C
ID-1: / raw-size: 97.54 GiB size: 97.54 GiB (100.00%) used: 26.6 GiB (27.3%)
mapped: luks-c8705c43-0d63-4823-a778-b7a9496c2a7a
used: 26.3 MiB (27.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
used: 26.6 GiB (27.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.17 GiB used: 321.2 MiB (4.4%)
System Temperatures: cpu: 58.5 C mobo: N/A gpu: amdgpu temp: 47.0 C
Memory: total: 8 GiB note: est. available: 7.17 GiB used: 2.55 GiB (35.6%)
Processes: 344 Power: uptime: 3m states: freeze,mem suspend: s2idle
wakeups: 0 services: org_kde_powerdevil, power-profiles-daemon, upowerd
Packages: pm: pacman pkgs: 1542 libs: 494 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.25-1):
System install date:     2023-09-20
Last full system update: 2024-04-12
Try new USB cables, faulty/damaged cables can cause the computer to freeze.
Also be sure to test alternate kernels.
Try a different power manager than powerdevil.
Have you tested running your laptop with the battery removed to see if the same thing occurs?
Or try X11 from login page.
Tested two different new usb c cables, one with a ferrite choke and one without; power from ugreen power adapter & from wall and power from shargeek storm 2 battery; both usb c ports freeze kde when plugged in with a source of power.
Plugging in a usb cable to power source before or during boot up or when turned off does not cause this issue.
Using usb c port for ethernet or some other use case does not freeze kde.
Have not tried the wm: kwin_wayland string yet.
Not sure what removing the battery would accomplish in this issue that has not already been proved by testing other usbc devices cables and power sources.
Much appreciated.
This often helps determine if a setting in your power saving utility is responsible.
Having some other small issues with install; figured this would be helpful in bug fixes; have another bug to post. Likely will do a new installation with the new “Bird Of Prey” ISO guessing this will fix the issue. If not will try removing the battery.
Much appreciated.
