Last night my energy saving dim in KDE activated, and I shut down my computer through a command shutdown now
on KDE Connect on my phone. When i booted my computer this morning, dim was still active. I've gone into KDE settings and deactivated "dim screen" and played with the brightness slider which does nothing. This level of brightness is fine if i'm up past midnight like an insomniac, but during the day i won't be able to read my screen.
Anyone ever experienced this? How was it fixed?
Kernel: 6.4.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=f6cccf9c-8580-435e-8f33-927e3e31bb2d rw rootflags=subvol=@
rd.driver.pre=vfio-pci amd_iommu=on quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=2e9cba84-8fd3-4884-995e-6ac1c54716ad loglevel=3
vfio-pci.ids=10de:17c8,10de:0fb0 nvidia-drm.modeset=1 ibt=off
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F34 date: 06/10/2021
ID-1: hidpp_battery_0 charge: 89% condition: N/A volts: 4.1 min: N/A
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4147 high: 4265 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4210 2: 4175
3: 4018 4: 4242 5: 4242 6: 4242 7: 4241 8: 4239 9: 4243 10: 4241 11: 4249
12: 4241 13: 4124 14: 4241 15: 4242 16: 4242 17: 4044 18: 4243 19: 4244
20: 3500 21: 4210 22: 4147 23: 4239 24: 4265 25: 3500 26: 4241 27: 3500
28: 4227 29: 4241 30: 4239 31: 4237 32: 4223 bogomips: 223570
Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: Micro-Star MSI
driver: vfio-pci v: N/A alternate: nouveau,nvidia_drm,nvidia
non-free: 535.xx+ status: current (as of 2023-07) arch: Maxwell
code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s
lanes: 4 link-max: lanes: 16 bus-ID: 05:00.0 chip-ID: 10de:17c8
Device-2: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 0b:00.0
chip-ID: 10de:1e84 class-ID: 0300
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.1.3:9
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 5119x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: left model: Dell S2716DG
serial: <filter> built: 2016 res: 2560x1440 dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-2 note: disabled pos: primary,right model: VG27A
serial: <filter> built: 2020 res: 2560x1440 dpi: 109 gamma: 1.2
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX 2070
SUPER/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GM200 High Definition Audio vendor: Micro-Star MSI
driver: vfio-pci alternate: snd_hda_intel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 05:00.1 chip-ID: 10de:0fb0
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
bus-ID: 0b:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
Device-5: Texas Instruments ATH-G1WL
lanes: 1 mode: 1.1 bus-ID: 1-3.1.4:10 chip-ID: 0451:16ba class-ID: 0300
Device-6: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:2
chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
API: ALSA v: k6.4.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
Device-2: Intel 82575EB Gigabit Network driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 link-max: lanes: 4 port: c020 bus-ID: 07:00.0
chip-ID: 8086:10a7 class-ID: 0200
IF: enp7s0f0 state: down mac: <filter>
Device-3: Intel 82575EB Gigabit Network driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 link-max: lanes: 4 port: c000 bus-ID: 07:00.1
IF: enp7s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2:3 chip-ID: 2357:0604
Local Storage: total: 4.57 TiB used: 1.14 TiB (25.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SanDisk model: ADATA SX6000PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: V9002s85 temp: 39.9 C
model: WDS100T1XHE-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 614600WD temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
model: WD20EARX-00ZUDB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
used: 672.48 GiB (75.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
ID-4: /var/log raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 934 MiB (2.9%) priority: 100
ID-2: swap-2 type: partition size: 34.49 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 56.6 C mobo: 34.0 C gpu: nvidia temp: 50 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 576 Uptime: 27m wakeups: 6 Memory: total: 32 GiB
available: 31.28 GiB used: 12.98 GiB (41.5%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 alt: 11/12
clang: 15.0.7 Packages: pm: pacman pkgs: 2665 libs: 595
tools: octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.28
System install date: 2022-01-22
Last full system update: 2023-07-29
