I just installed Garuda on my new Asus ROG Zephyrus (m.y. 2022, which is an "AMD Advantage" series notebook).
Out of necessity I have to use Wayland, and after installing it, when I open Dolphin the whole system freezes... or so I thought, because the RGB lighting of the keyboard continues normal, and I even managed to send files with KDE Connect (and they were received).
The problem is that within a second of opening Dolphin, the monitor freezes.
I'm sure it doesn't depend on using Garuda KDE Lite (it also happened to me on the previous notebook with Dr4goniz3d, but since it happened right away, I simply planed and reinstalled.
This is outpuf or garuda-inxi
Kernel: 6.1.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=271cc272-ac13-41fb-9f6c-68fcc2678b11
rw [email protected] quiet resume=UUID=7e406f9e-129d-463c-92c4-7bb11eab8ed0 loglevel=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 2 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402RJ_GA402RJ v: 1.0
Mobo: ASUSTeK model: GA402RJ v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
v: GA402RJ.316 date: 11/10/2022
ID-1: BAT0 charge: 37.8 Wh (48.8%) condition: 77.5/76.0 Wh (102.0%) volts: 15.9 min: 15.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging
Info: model: AMD Ryzen 9 6900HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3+ gen: 4
level: v3 note: check built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68)
stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2093 high: 3300 min/max: 1600/4934 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 1552 2: 2516 3: 1465 4: 3300 5: 1437 6: 3300
7: 1396 8: 3300 9: 2441 10: 1395 11: 1791 12: 1426 13: 1397 14: 1820 15: 1667 16: 3300
bogomips: 105400
Device-1: AMD Navi 23 [Radeon RX 6650 XT] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 03:00.0 chip-ID: 1002:73ef class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, DP-9 bus-ID: 07:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 52.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-3:2
chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7 compositor: kwin_wayland
gpu: amdgpu display-ID: 0
Monitor-1: eDP-2 model: TL140ADXP01 built: 2021 res: 2560x1600 dpi: 216 gamma: 1.2
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10 modes: max: 2560x1600 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon Graphics (rembrandt LLVM 15.0.7 DRM 3.49
6.1.9-zen1-1-zen) direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: snd_pci_acp6x v: kernel
alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.9-zen1-1-zen running: yes
Device-1: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 14c3:7922 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8 bus-ID: 5-1:2
chip-ID: 13d3:3568 class-ID: e001 serial: <filter>
Local Storage: total: 1.16 TiB used: 142.03 GiB (11.9%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD256 size: 238.3 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: V5MA010 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 937.22 GiB size: 937.22 GiB (100.00%) used: 142.03 GiB (15.2%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 937.22 GiB size: 937.22 GiB (100.00%) used: 142.03 GiB (15.2%) fs: btrfs
ID-4: /var/log raw-size: 937.22 GiB size: 937.22 GiB (100.00%) used: 142.03 GiB (15.2%)
ID-5: /var/tmp raw-size: 937.22 GiB size: 937.22 GiB (100.00%) used: 142.03 GiB (15.2%)
ID-1: swap-1 type: zram size: 14.86 GiB used: 28.5 MiB (0.2%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16.34 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 60.5 C mobo: N/A
Fan Speeds (RPM): cpu: 0
GPU: device: amdgpu temp: 53.0 C mem: 50.0 C fan: 0 watts: 4.00 device: amdgpu temp: 53.0 C
Processes: 415 Uptime: 30m wakeups: 319 Memory: 14.86 GiB used: 4.69 GiB (31.5%) Init: systemd
v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1414
pm: pacman pkgs: 1408 libs: 407 tools: yay pm: flatpak pkgs: 6 Client: shell wrapper
v: 5.1.16-release inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-02-04
Last full system update: 2023-02-05 ↻
