KDE Desktop Effects are Resetting from a Graphics Reset
Kernel: 6.13.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=85752c7c-353e-4927-afc2-e6e662305529 rw rootflags=subvol=@
quiet resume=UUID=864c3b84-001b-4689-b518-eef386196427 loglevel=3
mem_sleep=s2idle hush ibt=off
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
Mobo: ASUSTeK model: ROG STRIX B650E-I GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 3014 date: 07/17/2024
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2988 min/max: 545/5573 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2988 2: 2988 3: 2988
4: 2988 5: 2988 6: 2988 7: 2988 8: 2988 9: 2988 10: 2988 11: 2988 12: 2988
13: 2988 14: 2988 15: 2988 16: 2988 bogomips: 143724
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2,
HDMI-A-1, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: LG (GoldStar) HDR 4K serial: <filter> built: 2021
res: mode: 2560x1440 hz: 60 scale: 150% (1.5) to: 1707x960 dpi: 139
gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 806mm (31.7") ratio: 16:9
modes: max: 3840x2160 min: 640x480
navi22 LLVM 19.1.7 DRM 3.60 6.13.4-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.4.303 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: N/A device-ID: 1002:73df
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
chip-ID: 0b05:1a5c class-ID: 0300
Device-3: Turtle Beach Stealth 600PC Gen 3
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 10f5:224c class-ID: 0300
API: ALSA v: k6.13.4-zen1-1-zen status: kernel-api
Server-1: JACK v: 1.9.22 status: off with: nsmd status: off
tools: jack_control,qjackctl
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:15f3
lanes: 1 bus-ID: 0b:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp11s0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:4
chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 1.82 TiB used: 573.65 GiB (30.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 46.9 C
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 573.65 GiB (31.4%)
used: 573.65 GiB (31.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.99 GiB used: 256 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.62 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 58.6 C mobo: 58.0 C gpu: amdgpu temp: 52.0 C
mem: 52.0 C
Memory: total: 32 GiB note: est. available: 30.99 GiB
used: 12.27 GiB (39.6%)
Processes: 409 Power: uptime: 1h 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1980 libs: 582 tools: octopi,pamac,paru
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date:     2024-06-02
Last full system update: 2025-02-28
This issue started last night and only seems to happen randomly while gaming. The only game I have is Diablo 4 and it’s running through Lutris using Proton Experimental. Whenever the reset happens, the top panel sits above whatever window is open, even in D4 which causes the game to render beyond the screen unless I have it in windowed mode. So far, the only recourse I’ve found is turning the compositor off using ALT-SHIFT-F12. Rebooting the system temporarily fixes the issue, with compositor on, until it happens again
Any idea why turning the compositor off fixes this? Even then, I’m not entirely certain it’s fixed since I found this recourse only a while ago. Is there a fix for this other than turning off the compositor?
TIA!
EDIT: Even with compositor off, I’m still getting random freezes in-game due to desktop effects being reset from graphics reset. I’ve done some more digging around and found someone suggesting turning on contrast desktop effect, so I’ve done that and rebooted. We’ll see if it works.
