garuda-inxi command response:
root=UUID=c49dd7d1-5112-4225-9750-3d32456cdd3d rw rootflags=subvol=@
Type: Laptop System: Dell product: G3 3590 v: N/A
Mobo: Dell model: 0954F4 v: A00 serial: <superuser required> UEFI: Dell
v: 1.11.1 date: 08/19/2020
ID-1: BAT0 charge: 27.7 Wh (100.0%) condition: 27.7/51.0 Wh (54.2%)
volts: 12.7 min: 11.4 model: SMP DELL PN1VN96 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 803 high: 830 min/max: 800/4100 scaling:
5: 830 6: 800 7: 800 8: 800 bogomips: 38400
ports: active: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 bus-ID: 0000:01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-3: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:4
chip-ID: 1b3f:2247 class-ID: 0102 serial: <filter>
Device-4: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:7 chip-ID: 0c45:671f
class-ID: 0e02
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1520x285mm (59.84x11.22")
s-diag: 1546mm (60.89")
Monitor-1: DP-1 pos: left res: 1920x1080 hz: 60 dpi: 82
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-1-0 pos: right res: 1920x1080 hz: 60 dpi: 82
Monitor-3: eDP-1 pos: primary,center res: 1920x1080 hz: 60 dpi: 142
device: 2 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland,device-1
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
GT2) device-ID: 8086:3e9b memory: 30.46 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3 chip-ID: 8086:a348
class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-4: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 1038:12ad class-ID: 0300
Device-5: Realtek Audio USB driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 0bda:4938
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:03:00.0
chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 0cf3:e009
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.0
lmp-v: 9 status: discoverable: no pairing: no class-ID: 7c010c
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 12.25 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B tech: SSD serial: <filter> fw-rev: 10410104 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 02 scheme: GPT
used: 12.25 GiB (5.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 67.0 C pch: 64.0 C mobo: N/A
Processes: 275 Uptime: 1h 29m wakeups: 0 Memory: total: 32 GiB
available: 31.19 GiB used: 5.14 GiB (16.5%) Init: systemd v: 254
pm: pacman pkgs: 1405 libs: 441 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date: 2023-11-16
Last full system update: 2023-11-16 ↻
hi, i noticed that one of my drives is requesting a password to be accessed but i dont recall setting one (i installed the os last night), and ive tried a few different solutions but none seem to be working, i can provide more details if needed, also im running off of single boot if that helps.
