Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2604
date: 02/25/2022
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3670 high: 4170 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3378 2: 3369
3: 3805 4: 3895 5: 3594 6: 4170 7: 3692 8: 3627 9: 3744 10: 3557 11: 3593
12: 3617 bogomips: 86241
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Sapphire driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 09:00.0
chip-ID: 1002:731f class-ID: 0300
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Asus MX239 serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 528x310mm (20.79x12.2") diag: 612mm (24.1") ratio: 15:9 modes:
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 13.0.1 DRM 3.44
5.17.5-zen1-1-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab38
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-5:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.13 TiB used: 509.19 GiB (44.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHGP31-1000GM-2 size: 931.51 GiB block-size: physical: 512 B
rev: 41061C20 temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BP240G4
type: SSD serial: <filter> rev: 0410 scheme: GPT
ID-1: / raw-size: 97.16 GiB size: 97.16 GiB (100.00%)
used: 19.05 GiB (19.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-f67fb17e-b2e2-4b91-9070-bd9fecb58eb5
used: 720 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 103.32 GiB (46.2%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-1193a6aa-4ce9-483a-8bef-63caff32ae67
ID-4: /var/log raw-size: 97.16 GiB size: 97.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.16 GiB size: 97.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.59 GiB used: 1.83 GiB (11.8%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 49.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1724
Processes: 397 Uptime: 3h 6m wakeups: 1 Memory: 15.6 GiB
used: 3.7 GiB (23.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1838 lib: 520 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-08
Last full system update: 2022-05-08
Hello,
I am having troubles getting my KDE connect and Google Pixel 4a working on my Garuda Dragonized.
My problem: the computer isn't recognized by the phone and the phone cannot see the computer during the connection process. Both are on the same network and no firewall or VPN is running.
Thank you,
Jim
