Hello.
So today I have got this KDE connect error after every reboot it crashes and asks to restart application. Also it comes up with a pop up in notification Dr Konki crash
Below is the SS
root=UUID=0b3ee793-04a5-4396-a397-8dbad9c6feeb rw rootflags=subvol=@
resume=UUID=684fccb6-7d6a-4eda-8875-5b25dc60d985 loglevel=3 i8042.nokbd
Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
v: 0884110000385910000610100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 183E v: 56.32 serial: <superuser required>
UEFI: Insyde v: F.22 date: 11/22/2012
ID-1: BAT0 charge: 15.6 Wh (100.0%) condition: 15.6/15.6 Wh (100.0%)
volts: 12.4 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full
Info: model: Intel Core i3-3110M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1237 high: 1345 min/max: 1200/2400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1345 2: 1209 3: 1197
4: 1197 bogomips: 19155
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Thames [Radeon HD 7500M/7600M Series]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 1002:6840 class-ID: 0300
Device-3: Suyin HP TrueVision HD Integrated Webcam type: USB
driver: uvcvideo bus-ID: 2-1.5:3 chip-ID: 064e:e263 class-ID: 0e02
loaded: modesetting,radeon alternate: fbdev,intel,vesa gpu: i915
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x034d built: 2012 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 22.0.0 compat-v: 3.1 direct render: Yes
Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 1814:3290 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8136
Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.1 chip-ID: 1814:3298
class-ID: 0d11
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 931.51 GiB used: 12.37 GiB (1.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001
ID-1: / raw-size: 915.01 GiB size: 915.01 GiB (100.00%)
used: 12.37 GiB (1.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 915.01 GiB size: 915.01 GiB (100.00%)
ID-4: /var/log raw-size: 915.01 GiB size: 915.01 GiB (100.00%)
ID-5: /var/tmp raw-size: 915.01 GiB size: 915.01 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 67.0 C mobo: N/A gpu: radeon temp: 61.0 C
Processes: 253 Uptime: 13m wakeups: 1 Memory: 7.66 GiB
used: 2.96 GiB (38.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: 1377 pacman: 1373 lib: 357 flatpak: 4 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-04-02
Last full system update: 2022-04-02
Can someone please help me with this. I have even tried reinstall KDE connect but it still crashes.
