My laptop suddenly crashed and I forced shutdown. On restarting, I had no latte-docks. Performed a reset on latte dock through Garuda Assistant.
Now on opening any PWA or even browser, this is what I am getting:
Not sure what I am supposed to do.
╰─λ inxi -Faz
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=edc8611c-d94e-4567-85f8-02b07c91fda3 rw rootflags=subvol=@
quiet
cryptdevice=UUID=98382a7e-5fd2-4dca-b6e6-6aca242b8ece:luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece
root=/dev/mapper/luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece splash
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401II_GA401II
Mobo: ASUSTeK model: GA401II v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GA401II.219 date: 12/30/2020
ID-1: BAT0 charge: 59.1 Wh (79.9%) condition: 74.0/76.0 Wh (97.4%)
status: Not charging
Device-1: hid-dc:2c:26:05:66:0e-battery model: Keychron K2 serial: N/A
charge: N/A status: Discharging
Device-2: hidpp_battery_0
model: Logitech G304 Lightspeed Wireless Gaming Mouse serial: <filter>
Info: model: AMD Ryzen 5 4600HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1924 high: 2979 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1397 2: 1397
3: 1522 4: 1980 5: 2979 6: 1395 7: 2932 8: 1667 9: 1833 10: 1811 11: 2756
12: 1421 bogomips: 71866
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: HDMI-A-0 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 6-2.4:4 chip-ID: 0bda:8153 class-ID: 0000
IF: enp4s0f4u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 5-4:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 213.25 GiB (22.4%)
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
temp: 27.9 C scheme: GPT
used: 213.25 GiB (22.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece
ID-1: swap-1 type: zram size: 15.11 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 370 Uptime: 30m wakeups: 6 Memory: 15.11 GiB
used: 4.63 GiB (30.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1502 lib: 369 Shell: fish
v: 3.3.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.12
