Maybe just you and me ![]()
But I am also doing it to improve the toolchain builders. I suspect that it is better to wait until code freeze to really start testing it as a user.
Dr460nized. ![]()
I was supposed to start long ago, I am late to the party but should join within 2 weeks probably. KDE-git is a must for all my tests, just life is in the way a lot recently.
And Iāll check that then.
I mean the bar ![]()
Terminal must be konsole.
Reboot must be restart.
Itās not easy for an old man like me to remember all the different words for the same thing ![]()
Wait:
i3status
waybar
dock
there are more, I am sure ![]()
Correct for both.
Top Panel. loll
With Plasma instead of Latte-Dock, the panel at the top is called Top Panel and the āpanelā at the bottom is called āPanelā by KDE, everything is a Panel in KDE. To make things worse for your memory, with Plasma 6 they are renaming the dock to call it āDockā. A bottom āPanelā will still be available, but the floating option of it will be called āDockā.
How confusing. ![]()
They can call it all they want⦠my brain calls it āI miss latte-dockā ! ![]()
Not only you do! ![]()
I liked latte for how good it looked but it used to burn my laptop ![]()
But itās floating not docked. Screams in shock and horror.
Have to wonder what else is growing in that garden.
SDDM show standard wallpaper fixed and reboot, fine.
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:291:9: KQuickControlsAddons.EventGenerator is not a type
fixed after update and reboot.
Window decoration plastik was removed for breeze, and close button works now.
Is it possible things changed since your original post, @dr460nf1r3 ?
I try to install from fresh and I get this:
āāfrank@frank in ~ as
took 3s
[] Ć sudo pacman -S (cat kf6 extra plasma) --overwrite ā*ā
warning: kemoticons-5.111.0-1 is up to date ā reinstalling
warning: kinit-5.111.0-1 is up to date ā reinstalling
resolving dependenciesā¦
:: There are 2 providers available for qt6-multimedia-backend:
:: Repository extra
- qt6-multimedia-ffmpeg 2) qt6-multimedia-gstreamer
Enter a number (default=1): 1
looking for conflicting packagesā¦
:: kirigami-addons and kirigami-addons5 are in conflict. Remove kirigami-addons5? [y/N] y
:: removing kirigami-addons5 breaks dependency ākirigami-addons5ā required by kdeconnectāāfrank@frank in ~ as
took 34s
:: Repository extra
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
After last update, I got standard log in page again, but US upper left, can not change it to de, and password failed (back to log in).
Some little red text, canāt read with my weak eyes ![]()
I can see in TTY that my password fit, log in work.
But I canāt boot system.
chroot work, so I can update later the system and log in again ![]()
But the fun fact is reduced immensely. ![]()
I update the system via chroot some days ago, got german login standard page, but login failed.
Yesterday next update, login page change to US, only US as option in the selection menu.
I overwrote the partition with Hyprland today as I am not experienced enough to solve this kind of problem. ![]()
the kirigami-addons5 issue is kinda nasty.
there is a kde git repo kirigami-addons5 that fixes these conflicts, but first must be installed. (or the arch one removed first)
there has been some issues here and there, because upstream is not yet on āfreeze modeā (should happen at first alpha release, i think) : Schedules/Plasma 6 - KDE Community Wiki
I have been fixing things but sometimes its necessary to āreinstall the same packageā. Sorry for this, I havenāt communicated it here. Will do in the future!
Iām wondering if Iāll need the -git version on a clean install with kde-unstable repo & testing uncommented in pacman.conf from the beginning?
hum⦠If I understood your question correctly, arch kde-unstable and testing are not needed (arch kde-unstable has kf6 from git though currently, I think)
Its just an issue with kirigami-addons5 right now.
But I do the disclaimer again⦠things are pretty unstable right now, building/packaging wise, because development is going on in full swing and no API is frozen yet. (the desktop itself seems pretty stable, as in havenāt seen crashes recently)
IIRC, kde-unstable itself is listed among Archās Testing repos, and Iāll need them enabled but with kde-unstable repo placed above them in pacman.conf.
The last time I ran unstable was with GNOME and IIRC testing repos needed enabling. But itās been a few years and @ 71 I donāt mind admitting my mindās not as sharp as it once wasāif it ever was. ![]()
Thanks alex. ![]()
EDIT: @alexjp , from Arch Testing subforumā¦
V1del is a forum moderator. ![]()
Itās also in the wiki. I guess 71 aināt too shabby. ![]()
This thread is about a different repo altogether, see post #1:
During the last weeks, we have been working on building KDE 6 and a new repo called
chaotic-aur-kde. @alexjp did most of the work by bringing up the needed PKGBUILDs to build via our infra.
The instructions you are reading on the Arch forums are different because they are using different repos than the one that this thread is about.
