Kernel: 6.9.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
root=UUID=fcc9b47c-a4d0-441c-85e4-ac6806928db3 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> part-nu: SKU uuid: <superuser required> UEFI: American Megatrends
v: 5003 date: 10/07/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check
built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 2
microcode: 0xA20120E
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3920 high: 4349 min/max: 2200/4549 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3460 3: 4330 4: 4319 5: 4325 6: 3745
7: 3461 8: 3459 9: 4339 10: 3458 11: 4325 12: 4325 13: 4309 14: 3471 15: 4349 16: 3645
bogomips: 108805
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI driver: nvidia v: 555.52.04
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0b:00.0 chip-ID: 10de:2684
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 compositor: kwin_wayland
driver: X: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
display-ID: 0
Monitor-1: HDMI-A-1 res: 5120x1440 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.52.04 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2 memory: 23.43 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 12 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 4090
driver: nvidia v: 555.52.04 device-ID: 10de:2684 surfaces: xcb,xlib,wayland
Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:22ba class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: b58e:9e84
Device-4: SAVITECH SA9123 USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2:3 chip-ID: 262a:9113 class-ID: 0102
Device-5: FiiO BTR7 driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 7-4.1:5 chip-ID: 2972:0047 class-ID: 0300
API: ALSA v: k6.9.5-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp6s0 state: down mac:
<filter>
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5:3 chip-ID: 8087:0025 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1 lmp-v: 10 status:
Local Storage: total: 15.46 TiB used: 2.5 TiB (16.2%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital model: WD BLACK SN850X 4000GB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: 624311WD temp: 60.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB size: 3.64 TiB
fw-rev: 4B2QJXD7 temp: 51.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN008-2DR166 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5980 serial: <filter>
fw-rev: SC60 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
fw-rev: 3B6Q scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD2003FZEX-00SRLA0 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 1.5 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD20EZRZ-00Z5HB0 size: 1.82 TiB
fw-rev: 0A80 scheme: MBR
ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.31 TiB (36.0%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.31 TiB (36.0%) fs: btrfs
ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.31 TiB (36.0%) fs: btrfs
ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.31 TiB (36.0%) fs: btrfs
ID-1: swap-1 type: zram size: 31.25 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 65.9 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 4.38 GiB (14.0%)
Processes: 430 Power: uptime: 1h 39m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.46 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256
Packages: 1915 pm: pacman pkgs: 1904 libs: 540 tools: octopi,pacseek,pamac,paru pm: flatpak
pkgs: 11 Compilers: clang: 17.0.6 gcc: 14.1.1 Client: shell wrapper v: 5.2.26-release
inxi: 3.3.34
System install date: 2024-06-09
Last full system update: 2024-06-20
when adaptive sync is on always it causes the mouse to lag on desktop only, when playing games clicking the windows button also blacks out the screen due to adaptive sync, can anyone check if the bug is the same
