KDE 5.25 has no custom shortcuts anymore
  Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=1e990d50-f7c1-4ded-a883-784141da6847 rw rootflags=subvol=@
    systemd.unified_cgroup_hierarchy=1 loglevel=3 quiet radeon.dpm=0
  Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2
  Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 3401
    date: 12/04/2017
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
    built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
    microcode: 0x8001129
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 2853 high: 3447 min/max: 1550/3500 boost: disabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 2804 2: 2798
    3: 2796 4: 2807 5: 2797 6: 2800 7: 2795 8: 2796 9: 2801 10: 2796 11: 2799
    12: 3447 bogomips: 83840
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
  Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: Sapphire
    driver: amdgpu v: kernel arch: GCN 5 process: GF 14nm built: 2017-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: HDMI-A-1,HDMI-A-2 bus-ID: 0a:00.0 chip-ID: 1002:687f
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
    alternate: fbdev,vesa gpu: amdgpu d-rect: 4480x1080 display-ID: 0
  Monitor-1: DP-1 pos: right res: 2560x1080 size: N/A modes: N/A
  Monitor-2: DP-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  OpenGL:
    renderer: AMD Radeon RX Vega (vega10 LLVM 13.0.1 DRM 3.46 5.18.6-zen1-1-zen)
    v: 4.6 Mesa 22.1.2 direct render: Yes
  Device-1: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
    v: kernel bus-ID: 1-2:2 pcie: chip-ID: 19f7:0003 gen: 3 class-ID: 0300
    speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:aaf8 class-ID: 0403
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
  Device-3: RODE Microphones NT-USB type: USB
  Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
    v: 0.8 bus-ID: 1-3:3 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
  Local Storage: total: 2.61 TiB used: 1.88 TiB (71.9%)
    rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: ST1500LM006 HN-M151RAD
    size: 1.36 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: 0008 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT120BX100SSD1
    type: SSD serial: <filter> rev: MU01 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 QVO 1TB
    used: 179.68 GiB (77.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 15.56 GiB used: 3 MiB (0.0%) priority: 100
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 54.0 C
    mem: 50.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1266
  Processes: 401 Uptime: 59m wakeups: 6 Memory: 15.56 GiB
  used: 6.78 GiB (43.6%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 2209
  pacman: 2164 lib: 469 flatpak: 45 Shell: fish v: 3.4.1 default: Bash
  v: 5.1.16 running-in: kitty inxi: 3.3.19
e[1;34mGaruda (2.6.4-2):e[0m
e[1;34m  System install date:e[0m     2021-12-14
e[1;34m  Last full system update:e[0m 2022-06-26 e[1;31m↻
e[1;34m  Is partially upgraded:  e[0m No
e[1;34m  Relevant software:      e[0m NetworkManager
e[1;34m  Windows dual boot:      e[0m No/Undetected
e[1;34m  Snapshots:              e[0m Snapper
e[1;34m  Failed units:           e[0m
As you can see in the image below, I am missing the custom shortcuts menu item.
It appears to have been moved to the normal shortcuts item, with no way to add new custom shortcuts.
As you can see my old custom shortcut is still available (and functional), but there is no option to add additional ones.
It used to be the case that you could create shortcuts that would execute arbitrary commands, but no longer. Is there a way to fix this?
It looks like you are missing the package khotkeys
I looked for that before but it is definitely installed.
I'll try reinstalling it just in case
Please always post terminal or other texts as text, just like garuda-inxi, not as images.
Can you try just rebooting your machine to see if it makes a difference? Your inxi indicates you took an update but did not reboot afterward.
I tried reproducing this on one of my KDE installs, but I cannot--mine are working correctly and provide the option that you indicate is missing:
I've had this problem for a while (since updating to 5.25 I think), rebooting does not do anything.
The image you provided allows you to set a keybinding for the 'search' action. I can do the same:
The option to add a new action is missing :frowning:
Weird... I can see mine just fine (searching "custom shortcuts" in settings brought it up). The only thing that I can see from your garuda-inxi that could be a factor that is different, is that you are on a Wayland session. Makes me wonder if this somehow is a Wayland session specific bug since you already checked for khotkeys.
Oh good point. Let me check if it works in X
Edit: Yes, it works.
What's even weirder is that the shortcuts keep working when in Wayland, so I don't understand why the option to set them is disabled in Wayland. Thanks for the help, at least now I know to go into X when I need to edit my shortcuts :sweat_smile:
As Kayo mentioned it could be a Wayland bug. I haven’t seen that issue logged on bugs.kde.org, but I’m new to learning Wayland so I don’t know if bugs are logged at the same place as X.
Either way it could be worth you give them a shout about it. :slight_smile:
