KDE is supposed to have full native support for both of these image formats in basically all their apps. However, some time in the semi-recent past, I noticed that thumbnails were not being generated for new .jxl or .avif images and I thought it could be my converter was producing corrupted outputs, since they also would fail to display in Gwenview. Then I tried some older .jxl and .avif images I had made that were correctly displaying their thumbnails and they also failed in Gwenview! I think the thumbnails only displayed because they had been created when everything was working and were not wiped out.
I waited a while to see if maybe it was an error that would get fixed in some future update to any of the related software packages, but it has been months and nothing. I have no idea what caused this to happen and I can’t find anyone else reporting similar errors here or any of the KDE-related sites I checked.
The only thing I can possibly think of is the mess that occurred during the Plasma upgrade (edit: I think it was the QT5 one) a decent while back where some of us, including myself, had to manually remove packages that were no longer supported/compatible or had newer versions of them that didn’t follow the standard versioning convention or whatever the issue was. But, if I removed something related to Gwenview and Dolphin’s ability to decode those images, which I think is something like kimageformat-plugins, wouldn’t that also affect regular .jpgs and .pngs and such? Those work fine, like expected.
The specific error I get is: “Gwenview cannot display documents of type image/jxl.” (or avif)
Here is my garuda-inxi:
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=942d2fc8-c9b0-49b6-a858-bd341f497451 rw rootflags=subvol=@
resume=UUID=057a3668-d800-479b-8dd4-ced1dec5c5c3 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: ASUSTeK model: SABERTOOTH Z77 v: Rev 1.xx
UEFI: American Megatrends v: 1504 date: 08/03/2012
Info: model: Intel Core i5-2300 bits: 64 type: MCP arch: Sandy Bridge
desc: 1x6 MiB
Speed (MHz): avg: 2351 high: 3173 min/max: 1600/6300 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3173 2: 1648 3: 2936
4: 1648 bogomips: 23076
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: ASRock
active: DP-3,HDMI-A-1 empty: DP-1,DP-2,Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:73ef class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com. driver: N/A
alternate: nouveau non-free: 545.xx+ status: current (as of 2024-04;
EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.0 chip-ID: 10de:1c82 class-ID: 0300
Screen-1: 0 s-res: 5120x1552 s-dpi: 96 s-size: 1354x410mm (53.31x16.14")
s-diag: 1415mm (55.7")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,top-left
model: Dell S2722DGM serial: <filter> built: 2022 res: 2560x1440 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r
model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2018 res: 2560x1080
hz: 60 dpi: 97 gamma: 1.2 size: 673x284mm (26.5x11.18")
diag: 730mm (28.8") modes: max: 2560x1080 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.0-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6650 XT (radeonsi
navi23 LLVM 17.0.6 DRM 3.57 6.9.3-zen1-1-zen) device-ID: 1002:73ef
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6650 XT (RADV NAVI23) driver: mesa radv v: 24.1.0-arch1.1
device-ID: 1002:73ef surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.0-arch1.1 (LLVM
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: NVIDIA GP107GL High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.1
chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
Info: services: NetworkManager, smbd, systemd-networkd, systemd-timesyncd
Local Storage: total: 1.4 TiB used: 645.62 GiB (45.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDS721010CLA332
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3GC scheme: MBR
model: WD3000GLFS-01F8U0 size: 279.46 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 10000 serial: <filter>
fw-rev: 3V01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Intel model: SSDSC2CW240A3
tech: SSD serial: <filter> fw-rev: 400i scheme: GPT
ID-1: / raw-size: 188.84 GiB size: 188.84 GiB (100.00%)
used: 148.27 GiB (78.5%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 188.84 GiB size: 188.84 GiB (100.00%)
ID-4: /var/log raw-size: 188.84 GiB size: 188.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 188.84 GiB size: 188.84 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 28 MiB (0.1%) priority: 100
ID-2: swap-2 type: partition size: 34.43 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 40.0 C
Memory: total: 32 GiB available: 31.29 GiB used: 3.6 GiB (11.5%)
Processes: 235 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,upowerd
Packages: 2501 pm: pacman pkgs: 2478 libs: 625 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 23 Compilers: clang: 17.0.6
gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.34
System install date: 2022-11-08
Last full system update: 2024-06-05
Failed units: anbox-container-manager.service systemd-networkd-wait-online.service
Thanks in advance.
