Journal was floating with error?
My inxi
╭─gampel@garudacomp in ~
🕙 17:49:10
╰─λ garuda-inxi
Kernel: 6.14.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
clocksource: tsc avail: hpet,acpi_pm parameters: quiet
initcall_blacklist=simpledrm_platform_driver_init loglevel=3 ibt=off
root=UUID=fd644241-2723-4347-b0fc-747c588e12fa rw rootflags=subvol=@
initrd=@\boot\initramfs-linux-zen.img
Type: Desktop System: Micro-Star product: MS-7D54 v: 2.0
Mobo: Micro-Star model: MAG X570S TORPEDO MAX (MS-7D54) v: 2.0
Megatrends LLC. v: A.B0 date: 04/08/2025
Device-1: hidpp_battery_0 model: Logitech Wireless Illuminated Keyboard K800
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701035
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3598 min/max: 550/4208 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3598 2: 3598 3: 3598
4: 3598 5: 3598 6: 3598 7: 3598 8: 3598 9: 3598 10: 3598 11: 3598 12: 3598
bogomips: 86390
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
XT/6600M] vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1
bus-ID: 2f:00.0 chip-ID: 1002:73ff class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung C32F39M serial: <filter> built: 2019
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 70 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 19.1.7 DRM 3.61 6.14.10-zen1-1-zen) device-ID: 1002:73ff
API: Vulkan v: 1.4.313 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.1.2-arch1.1
device-ID: 1002:73ff surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.1.2-arch1.1 (LLVM
de: kscreen-console,kscreen-doctor gpu: amd-smi, amdgpu_top, corectrl, lact
bus-ID: 2f:00.1 chip-ID: 1002:ab28 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 0db0:a073 class-ID: 0300
Device-4: Razer USA Kraken Tournament Edition
lanes: 1 mode: 1.1 bus-ID: 3-6.1:4 chip-ID: 1532:0520 class-ID: 0300
API: ALSA v: k6.14.10-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
lanes: 1 port: d000 bus-ID: 28:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 4.66 TiB used: 1.92 TiB (41.1%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
model: WDS500G1XHE-00AFY0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 615400WD temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: A-Data model: SP900 size: 119.24 GiB
serial: <filter> fw-rev: 2a scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD30EZAX-00C8UB0 size: 2.73 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
used: 186.9 GiB (40.2%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 628 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
dev: /dev/nvme1n1p3 maj-min: 259:8
System Temperatures: cpu: 46.8 C mobo: 32.5 C gpu: amdgpu temp: 31.0 C
mem: 32.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 889
Memory: total: 32 GiB available: 31.26 GiB used: 4.68 GiB (15.0%)
Processes: 437 Power: uptime: 24m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2091 libs: 574 tools: octopi,pacseek,paru,yay
Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish
System install date:     2025-03-25
Last full system update: 2025-06-06
Yesterday, i make my daily update and after reboot i take a look inside the journal and was surprised about some messages about qml: 4.3.0 4.3.0 true. Now, today, also after update i have more qml errors.
And why garuda-inxi tells me this system is stalled this year, is also wrong, but that’s perhaps in another topic.
├󰅐 OS Age 303 days
Logfile from today
The journal spam about qml might be due to some kind of KDE customization or widget. You could try a different fresh user account with no customization (like a plain default panel and such) and see if there is anything wrong with the updates themselves. If that doesn’t have those things in the journal doing that, you can try to see what is causing them by adding customization you have in your primary user account to the fresh one. (Edit: be sure to slowly add customization to that fresh account to troubleshoot it)
Apart from that, have you tried a older snapshot to confirm it is an issue that surfaces after a recent update? If so, could you share some update logs to see what has been updated recently?
It’s on my metal mokka + metal dragon + and both vm.
Second user or create new user make no difference.
Every time after starting a app (firefox or systemsettings, garuda stuff) i have more messages like this. We had 2 days ago a lot of qt updates. For me, that’s the prob.
If i use a older snapshot (without these updates) no error messages in the journal.
I found the “problem”.. this horrible plasma6-applets-panel-colorizer.
Useless, if it generate this kind of messages. Deinstalled. Done.
Thx @Kayo
Ah, there’s been quite a few issues with that in the past, and I don’t use it personally with my Plasma configurations.
(explains why I didn’t notice those qml lines in my logs when I checked)
Not only in the past :upside_down_face:
