je n’arrive pas à démarrer sur là dernier iso. ça fonctionne sur celle de janvier
Kernel: 6.15.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=1deaef80-bcee-4256-8001-61ef84255a0e rw rootflags=subvol=@
loglevel=3 nvidia-drm.modeset=1 ibt=off
Desktop: Sway v: 0.5.1 with: waybar tools: swayidle avail: gtklock vt: 1
lm: greetd Distro: Garuda base: Arch Linux
Type: Laptop System: Razer product: Blade 18 - RZ09-0509 v: 10.04
Mobo: Razer model: KI8100 v: 4 serial: <superuser required>
part-nu: RZ09-0509TFK3 uuid: <superuser required> UEFI: Razer v: 1.04
date: 05/06/2024
ID-1: BAT0 charge: 47.6 Wh (49.5%) condition: 96.1/91.7 Wh (104.8%)
volts: 15.3 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: not charging cycles: 22
Info: model: Intel Core i9-14900HX bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 800 min/max: 800/5600:5800:4100 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 800
bogomips: 154828
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Razer USA driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-2 empty: DP-4,HDMI-A-2 bus-ID: 0000:00:02.0 chip-ID: 8086:a788
Device-2: NVIDIA AD104M [GeForce RTX 4080 Max-Q / Mobile]
vendor: Razer USA driver: nvidia v: 575.64 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ ports: active: none
empty: DP-1, DP-2, DP-3, HDMI-A-1, eDP-1 bus-ID: 0000:01:00.0
chip-ID: 10de:27e0 class-ID: 0300
Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 30c9:009e
Display: wayland server: Xwayland v: 24.1.8 compositor: Sway v: 0.5.1
driver: gpu: i915 display-ID: 1
Monitor-1: eDP-2 model: BOE Display 0x0c87 built: 2023 res:
mode: 2560x1600 hz: 300 scale: 100% (1) dpi: 168 gamma: 1.2
size: 388x242mm (15.28x9.53") diag: 457mm (18") ratio: 16:10
modes: 2560x1600
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080 Laptop
GPU/PCIe/SSE2 memory: 11.71 GiB
API: Vulkan v: 1.4.313 layers: 11 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 25.1.4-arch1.1
device-ID: 8086:a788 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 4080 Laptop GPU driver: nvidia v: 575.64
device-ID: 10de:27e0 surfaces: N/A device: 2 type: cpu name: llvmpipe
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
gpu: nvidia-settings,nvidia-smi wl: kanshi, swaymsg, wdisplays
Device-1: Intel Raptor Lake High Definition Audio vendor: Razer USA
snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
class-ID: 0401
Device-2: NVIDIA AD104 High Definition Audio vendor: Razer USA
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:22bc
Device-3: Razer USA BlackShark V2 HS USB
lanes: 1 mode: 1.1 bus-ID: 1-2.3:6 chip-ID: 1532:056e class-ID: 0300
API: ALSA v: k6.15.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
port: 3000 bus-ID: 0000:54:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp84s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 7 AX1775 /AX1790 /BE20 /BE401/BE1750 2x2
driver: iwlwifi v: kernel bus-ID: 0000:55:00.0 chip-ID: 8086:272b
IF: wlp85s0f0 state: up mac: <filter>
Device-1: Intel BE200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0036
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Supported mdraid levels: raid0
Device-1: md126 maj-min: 9:126 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 7814032384 chunk-size: 64k
Components: Online:
0: nvme1n1 maj-min: 259:1 size: 3.64 TiB
1: nvme0n1 maj-min: 259:0 size: 3.64 TiB
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 4784 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme0n1 maj-min: 259:0 size: 3.64 TiB state: S
1: nvme1n1 maj-min: 259:1 size: 3.64 TiB state: S
Local Storage: total: raw: 7.51 TiB usable: 238.47 GiB
used: 118.03 GiB (49.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 990 PRO 4TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 39.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: JMicron Tech model: Generic
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: N/A
serial: <filter> fw-rev: 0209 scheme: GPT
ID-1: / raw-size: 237.42 GiB size: 237.42 GiB (100.00%)
used: 118.03 GiB (49.7%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 1.05 GiB size: 1.05 GiB (99.80%)
used: 616 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 237.42 GiB size: 237.42 GiB (100.00%)
ID-4: /var/log raw-size: 237.42 GiB size: 237.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 237.42 GiB size: 237.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.97 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.5 C mobo: N/A
Memory: total: 32 GiB note: est. available: 30.97 GiB used: 7.14 GiB (23.1%)
Processes: 529 Power: uptime: 20h 24m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.31 GiB services: upowerd
Packages: pm: pacman pkgs: 1387 libs: 427 tools: pacseek,paru,yay
Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
running-in: kitty inxi: 3.3.38
System install date: 2025-05-10
Last full system update: 2025-06-21 ↻
Windows dual bo
