Hi, newbie here
I am totally new to linux and decided to use garuda as my first distro.
The issue in hand is the following: When I connect my JBL quantum 200 headset, the system doesn't detect its microphone. Keep in mind it detects the headset as headphones and I can listen through them.
Any help would be appreciated, thanks.
garuda inxi, I think:
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b6fb8ae3-ea66-4e2c-821d-7b2771c302a6 rw [email protected]
resume=UUID=ae522201-9794-47b8-b6f4-827e937fbc08 loglevel=3
Type: Laptop System: ASUSTeK product: ROG Strix G531GT_G531GT v: 1.0
Mobo: ASUSTeK model: G531GT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G531GT.308 date: 02/01/2021
ID-1: BAT0 charge: 23.2 Wh (78.6%) condition: 29.5/50.5 Wh (58.3%)
volts: 12.5 min: 12.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4057 high: 4098 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4019 2: 4011 3: 3996
4: 4096 5: 4091 6: 4083 7: 4098 8: 3995 9: 4081 10: 4077 11: 4080
12: 4062 bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
IF: eno2 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 476.94 GiB used: 100.53 GiB (21.1%)
model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
rev: P1MA0V4 temp: 49.9 C scheme: GPT
used: 100.53 GiB (21.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.61 GiB used: 1.82 GiB (24.0%)
System Temperatures: cpu: 69.0 C pch: 68.0 C mobo: N/A
Fan Speeds (RPM): cpu: 5000
Processes: 333 Uptime: 1h 53m wakeups: 11 Memory: 7.61 GiB
used: 5.32 GiB (69.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1805 lib: 546 Shell: fish
Garuda (2.5.3-1):
System install date: 2022-01-31
Last full system update: 2022-01-31
