java --version
Unrecognized option: --version
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
Welcome to garuda
can you provide your
as per the forum template
Welcome ![]()
java -version
openjdk version "19.0.2" 2023-01-17
OpenJDK Runtime Environment Temurin-19.0.2+7 (build 19.0.2+7)
OpenJDK 64-Bit Server VM Temurin-19.0.2+7 (build 19.0.2+7, mixed mode, sharing)
man java
java -h
Please, follow the template.
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
Hi there, see
https://wiki.archlinux.org/title/java
For installing java
I hope this solves your problem.
