My JamesDSP keeps on crashing at what seems to be random events, often by other programs making a sound or starting up. Sometimes i wont launch at all. Same if I use my BT headset or wired sound output.
I had this issue since Garuda installation 6 month ago and I cant figure out what causes the crashes..
Operating System: Garuda Linux
KDE Plasma Version: 5.25.4
KDE Frameworks Version: 5.96.0
Qt Version: 5.15.5
Kernel Version: 5.18.16-zen1-1-zen (64-bit)
Graphics Platform: X11
Processors: 12 × Intel® Core™ i5-10400F CPU @ 2.90GHz
Memory: 15,5 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 2060/PCIe/SSE2
Manufacturer: LENOVO
Product Name: 90N9000BMW
System Version: IdeaCentre G5 14IMB05
LANGUAGE = "en_US:sv",
LC_ALL = (unset),
LC_ADDRESS = "sv_SE.UTF-8",
LC_NAME = "sv_SE.UTF-8",
LC_MONETARY = "sv_SE.UTF-8",
LC_PAPER = "sv_SE.UTF-8",
LC_IDENTIFICATION = "sv_SE.UTF-8",
LC_TELEPHONE = "sv_SE.UTF-8",
LC_MEASUREMENT = "sv_SE.UTF-8",
LC_TIME = "sv_SE.UTF-8",
LC_NUMERIC = "sv_SE.UTF-8",
LANG = "en_SE.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=1e99006d-725d-4fa7-b4ff-750cc38389f2 rw rootflags=subvol=@
quiet
cryptdevice=UUID=ab008767-f17d-43ac-8512-fdc409a3a677:luks-ab008767-f17d-43ac-8512-fdc409a3a677
root=/dev/mapper/luks-ab008767-f17d-43ac-8512-fdc409a3a677 quiet splash
resume=/dev/mapper/luks-056ea933-4ab6-4668-ab12-370357a405a7 loglevel=3
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Desktop System: LENOVO product: 90N9000BMW v: IdeaCentre G5 14IMB05
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: LENOVO model: 370A v: SDK0J40700 WIN 3258175487150 serial: N/A
UEFI: LENOVO v: O4HKT22A date: 06/08/2020
Info: model: Intel Core i5-10400F socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 3 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3870 high: 4099 min/max: 800/4300 base/boost: 2871/8300
scaling: driver: intel_pstate governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 4086 2: 4093 3: 2878 4: 4099 5: 3727 6: 4098
7: 4020 8: 3674 9: 4032 10: 3676 11: 4098 12: 3967 bogomips: 69597
filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ZOTAC
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f08 class-ID: 0300
Screen-1: 0 s-res: 4080x2160 s-dpi: 94 s-size: 1103x584mm (43.43x22.99")
s-diag: 1248mm (49.14")
Monitor-1: DP-0 pos: middle-c res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.04x11.26") diag: 584mm (22.99") modes: N/A
Monitor-2: DP-3 pos: bottom-r res: 1080x1920 hz: 60 dpi: 96
size: 286x509mm (11.26x20.04") diag: 584mm (22.99") modes: N/A
Monitor-3: DP-4 pos: bottom-l res: 1080x1920 hz: 60 dpi: 96
Monitor-4: HDMI-0 pos: primary,top-center res: 1920x1080 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: Lenovo driver: snd_hda_intel
bus-ID: 1-1:2 v: kernel chip-ID: 0d8c:0014 alternate: snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:c822
bus-ID: 1-2:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Local Storage: total: 1.38 TiB used: 237.05 GiB (16.8%)
model: MZVLB512HBJQ-000L7 size: 476.94 GiB block-size: physical: 512 B
rev: 5M2QEXF7 temp: 46.9 C scheme: GPT
SMART: yes health: PASSED on: 150d 8h cycles: 620 read-units: 83,839,121
[42.9 TB] written-units: 39,919,837 [20.4 TB]
model: WD10EZEX-08WN4A0 family: Blue size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 1A02 temp: 47 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 14d 6h cycles: 561
ID-1: / raw-size: 459.64 GiB size: 459.64 GiB (100.00%) used: 237.05 GiB
(51.6%) fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ab008767-f17d-43ac-8512-fdc409a3a677
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 720 KiB
(0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 459.64 GiB size: 459.64 GiB (100.00%) used: 237.05
GiB (51.6%) fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 459.64 GiB size: 459.64 GiB (100.00%) used: 237.05
ID-5: /var/tmp raw-size: 459.64 GiB size: 459.64 GiB (100.00%) used: 237.05
ID-1: swap-1 type: zram size: 15.45 GiB used: 226.8 MiB (1.4%)
ID-2: swap-2 type: partition size: 16.99 GiB used: 0 KiB (0.0%)
mapped: luks-056ea933-4ab6-4668-ab12-370357a405a7
System Temperatures: cpu: 55.0 C mobo: N/A gpu: nvidia temp: 53 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 352 Uptime: 2d 1h 1m wakeups: 0 Memory: 15.45 GiB used: 7.47 GiB
(48.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 2216 pacman: 2208 lib: 562
flatpak: 8 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2022-05-04
Last full system update: 2022-08-04
