Hi, I've tried updating my system, and there is a conflict between jack2 and pipewire-jack. Its not teh first time this happenend and it solved itself last time. Now its not working, even through the garruda manager.
I've tried to uninstall pipewire-jack but it has a lot of dependencies, and so does jack2.
If i try to update through garuda assistant i get :
[2022-02-07 17:22:32] WARNING: failed to rate http(s) download (https://archmirror.it/repos/community/os/x86_
64/community.db): HTTP Error 403: Forbidden
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirr
orlist
# When: 2022-02-07 20:22:42 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-02-07 20:22:29 UTC
# Last Check: 2022-02-07 20:06:18 UTC
Server = https://mirror.luzea.de/archlinux/$repo/os/$arch
Server = https://archlinux.homeinfo.de/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://mirror.cyberbits.asia/archlinux/$repo/os/$arch
Server = https://archmirror.it/repos/$repo/os/$arch
:: Sincronizando a base de dados de pacotes...
core 136,9 KiB 120 KiB/s 00:01 [------------------------------------] 100%
extra 1554,2 KiB 551 KiB/s 00:03 [------------------------------------] 100%
community 6,1 MiB 2,31 MiB/s 00:03 [------------------------------------] 100%
multilib 148,9 KiB 113 KiB/s 00:01 [------------------------------------] 100%
chaotic-aur 1776,9 KiB 1588 KiB/s 00:01 [------------------------------------] 100%
--> Addressing jack2 conflict..
erro: alvo não encontrado: jack2
I usually upade through sudo pacman -Syu but this time it gave me those errors, then i tried sudo pacman -Syyu and did something but i got the "partial upgrade is not supported" and theni tried updating there and I'm not in this situation, ive tried to update pipewire-jack like some forums told me, and it tries but doenst to anything, no error and no update.
Trying to uninstall (-Rdd or -R) jack2 manually says "target not found" and trying to -Q or -Qi returns "package not found" checking pamac shows me jack2 is not installed
I'm kind of lost here, and from what ive seen my system will likelly break next restart. from the partial upgrade
sudo pacman -Syu
[sudo] senha para gibarel:
core está atualizado
extra 1554,3 KiB 810 KiB/s 00:02 [------------------------------------] 100%
community 6,1 MiB 2,30 MiB/s 00:03 [------------------------------------] 100%
multilib está atualizado
chaotic-aur 1777,0 KiB 1312 KiB/s 00:01 [------------------------------------] 100%
:: Iniciando atualização completa do sistema...
atenção: garuda-settings-manager-git: local (1.0.0.r1.g15c4106-3) é mais novo que chaotic-aur (1.0.0.r1.g15c4
106-1)
atenção: garuda-settings-manager-kcm-git: local (1.0.0.r1.g15c4106-3) é mais novo que chaotic-aur (1.0.0.r1.g
15c4106-1)
resolvendo dependências...
procurando pacotes conflitantes...
:: jack2 e pipewire-jack estão em conflito (jack). Remover pipewire-jack? [s/N] s
erro: falha ao preparar a transação (não foi possível satisfazer as dependências)
:: a remoção de pipewire-jack quebra a dependência "pipewire-jack" necessária por lib32-pipewire-jack
:: a remoção de pipewire-jack quebra a dependência "pipewire-jack" necessária por pipewire-support
sudo pacman -Syu
extra está atualizado
community está atualizado
chaotic-aur está atualizado
106-1)
15c4106-1)
erro: conflito de pacotes não solucionável detectado
erro: falha ao preparar a transação (dependências conflitantes)
sudo pacman -Rdd jack2
sudo pacman -S pipewire-jack
atenção: pipewire-jack-1:0.3.45-1 está atualizado -- reinstalando
Pacotes (1) pipewire-jack-1:0.3.45-1
Tamanho total instalado: 0,66 MiB
Alteração no tamanho: 0,00 MiB
:: Continuar a instalação? [S/n]
(1/1) verificando chaves no chaveiro [------------------------------------] 100%
(1/1) verificando integridade do pacote [------------------------------------] 100%
(1/1) carregando arquivos do pacote [------------------------------------] 100%
(1/1) verificando conflitos de arquivos [------------------------------------] 100%
(1/1) verificando espaço em disco disponível [------------------------------------] 100%
:: Executando hooks pré-transação...
==> root: 276
:: Processando alterações do pacote...
(1/1) reinstalando pipewire-jack [------------------------------------] 100%
:: Executando hooks pós-transação...
(1/7) Arming ConditionNeedsUpdate...
(2/7) Foreign/AUR package notification
alvr-git 16.0.0.rc2.r225.g4471de12-1
ckb-next-git 1:0.4.4.r147.gee8ca741-1
discover-overlay 0.3.3-3
epson-inkjet-printer-escpr 1.7.17-1
epson-inkjet-printer-escpr2 1.1.45-1
epsonscan2 6.6.40.0-2
ffmpeg-vulkan 2:4.4.1-1
godot-mono-bin 3.4-1
java-openjdk-bin 17.0.1.u12-1
jdk 17.0.1-1
jre 17.0.1-1
multimc-bin 1.6-1
nuclear-player-bin 0.6.17-2
parsec-bin 150_28-3
qt5-singlecoreapplication 2.6_20170914-1
sidequest-bin 0.10.26-1
snapd 2.53.4-1
snapd-glib 1.59-1
(3/7) Orphaned package notification...
amf-headers 1.4.23-1
asciidoc 10.1.1-1
boost 1.78.0-1
celt 0.11.3-4
cmake 3.22.2-1
ffnvcodec-headers 11.1.5.1-1
flatpak 1.12.4-1
go-tools 4:0.1.9-1
itstool 1:2.0.7-1
kfiredragonhelper 5.0.6-1
memavaild 0.6-1
meson 0.61.1-1
nasm 2.15.05-1
nohang 0.2.0-1
nuget 5.10.0-1
prelockd 0.9-1
python-docutils 1:0.16-2
python-html2text 2020.1.16-5
rebuild-detector 4.4.1-1
scons 4.3.0-3
snapd 2.53.4-1
snapd-glib 1.59-1
uresourced 0.4.0-1
vala 0.54.6-1
xorg-server-xvfb 21.1.3-1
zita-alsa-pcmi 0.4.0-1
zita-resampler 1.8.0-1
(4/7) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/nsswitch.conf.pacnew
/etc/default/grub.pacnew
/etc/default/grub-btrfs/config.pacnew
/etc/pamac.conf.pacnew
/etc/paru.conf.pacnew
Please check and merge
(5/7) Checking which packages need to be rebuilt
(6/7) Performing snapper post snapshots for the following configurations...
==> root: 277
(7/7) Syncing all file systems...
