JACK for Focusrite Scarlett 2i2 not working
System:    Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=439a289c-3fb5-4c9a-88fb-f4b3a8c855b9
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 3603 date: 03/19/2021
CPU:       Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 family: 19 (25)
model-id: 21 (33) stepping: 0 microcode: A201009 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 88632
Speed: 3616 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 3616 2: 3685
3: 3672 4: 3591 5: 3642 6: 3862 7: 3777 8: 3592 9: 3908 10: 3658 11: 3834 12: 3604
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics:  Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: Gigabyte driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:1b06 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.6x13.1") s-diag: 868mm (34.2")
Monitor-1: DP-0 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x13.0") diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Audio:     Device-1: NVIDIA GP102 HDMI Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0a:00.1 chip-ID: 10de:10ef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Device-3: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen type: USB driver: snd-usb-audio
bus-ID: 1-3:2 chip-ID: 1235:8202 class-ID: 0102
Device-4: Razer USA Kraken 7.1 V2 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-6:3 chip-ID: 1532:0510 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.2-zen1-1-zen running: yes
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:2723
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: d000
bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:4 chip-ID: 8087:0029
Drives:    Local Storage: total: 2.04 TiB used: 104.02 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDBRPG0010BNC-WRSN
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 111110WD temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BP240G4 size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0410 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DX001-1CM162 size: 931.51 GiB
serial: <filter> rev: CC43 scheme: MBR
Partition: ID-1: / raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 104.02 GiB (46.6%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 104.02 GiB (46.6%) fs: btrfs
ID-4: /var/log raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 104.02 GiB (46.6%)
ID-5: /var/tmp raw-size: 223.27 GiB size: 223.27 GiB (100.00%) used: 104.02 GiB (46.6%)
ID-1: swap-1 type: zram size: 15.6 GiB used: 2.5 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   Message: No sensor data found. Is lm-sensors configured?
Info:      Processes: 346 Uptime: 5m wakeups: 0 Memory: 15.6 GiB used: 3.92 GiB (25.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1749 pacman: 1744 lib: 499 flatpak: 5
Hello all, I am having issues starting JACK for audio recording. I am using a Focusrite Scarlett 2i2.
Here's what I have tried:
QJackCtl: Realtime, Alsa, and selected the 2i2 in the options.
Here is the error return:
16:42:28.133 Statistics reset.
16:42:28.133 ALSA connection change.
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
16:42:28.141 ALSA connection graph change.
16:43:30.797 JACK is starting...
16:43:30.797 /usr/bin/jackd -r -dalsa -dhw:USB -r48000
16:43:30.800 JACK was started with PID=21976.
no message buffer overruns
jackdmp 1.9.19
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2016 Grame.
Copyright 2016-2021 Filipe Coelho.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in non-realtime mode
self-connect-mode is "Don't restrict self connect requests"
audio_reservation_init
Device reservation request with priority 2147483647 denied for "Audio0": org.freedesktop.DBus.Error.UnknownMethod (Method RequestRelease is not implemented on interface org.freedesktop.ReserveDevice1)
Failed to acquire device name : Audio0 error : Method RequestRelease is not implemented on interface org.freedesktop.ReserveDevice1
Audio device hw:USB cannot be acquired...
Cannot initialize driver
JackServer::Open failed with -1
Failed to open server
16:43:30.886 JACK was stopped
16:43:32.880 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages window for more info.
I tried searching the error itself : But I only got this reddit thread: https://www.reddit.com/r/linuxaudio/comments/qtmynn/problems_starting_jackd_method_requestrelease_is/
And it didn't have a solution to my problem.
I have also tried using Cadence, and no joy. I am still new to linux and linux audio recording, so anything more that needs to be known, please let me know!
*I did notice that Jack is version 1 instead of Version 2. Will that make a difference? I am wanting record using Ardour, so that's my ultimate goal if there is a better route with pipewire and such. I am still newer to this,
Have you installed pipewire-jack?
https://wiki.archlinux.org/title/PipeWire#JACK_clients
That worked, had to use command line to start ardour.
