I have installed Garuda Linux on my HP laptop. I used a USB and could install everything with wifi but when I reboot I have no wifi anymore. Tried several tips but with no success.
╰─λ inxi -Fxxxza
System:    Kernel: 5.11.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d89991dd-e859-4e70-b080-6830a0aac261
systemd.unified_cgroup_hierarchy=1 resume=UUID=7be651bc-1b99-4ed0-98c0-3b813d950b8b loglevel=3
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine:   Type: Convertible System: HP product: HP ENVY x360 Convertible v: Type1ProductConfigId
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: HP model: 80D0 v: 84.31 serial: <filter> UEFI: Insyde v: F.33 date: 02/26/2018
Battery:   ID-1: BAT0 charge: 27.0 Wh condition: 27.1/27.1 Wh (100%) volts: 12.9/11.4
model: 333-54-2A LE03048XL type: Li-ion serial: <filter> status: Unknown
CPU:       Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake family: 6
model-id: 4E (78) stepping: 3 microcode: E2 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19200
Speed: 2726 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 2726 2: 2739 3: 2747 4: 2711
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1916 class ID: 0300
Device-2: NVIDIA GM108M [GeForce 930M] vendor: Hewlett-Packard driver: nvidia v: 460.39
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1346 class ID: 0302
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo bus ID: 1-4:2 chip ID: 04f2:b50d
class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d70 class ID: 0403
Sound Server: ALSA v: k5.11.1-zen1-1-zen
Network:   Device-1: Intel Wireless 7265 driver: N/A modules: iwlwifi port: 4000 bus ID: 02:00.0
chip ID: 8086:095a class ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus ID: 03:00.0 chip ID: 10ec:8168 class ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus ID: 1-6:4
chip ID: 8087:0a2a class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives:    Local Storage: total: 238.47 GiB used: 7.9 GiB (3.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: L8H-256V2G-HP size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: SSD serial: <filter> rev: 2803
Partition: ID-1: / raw size: 229.41 GiB size: 229.41 GiB (100.00%) used: 7.9 GiB (3.4%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.45%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 229.41 GiB size: 229.41 GiB (100.00%) used: 7.9 GiB (3.4%) fs: btrfs
ID-4: /var/log raw size: 229.41 GiB size: 229.41 GiB (100.00%) used: 7.9 GiB (3.4%) fs: btrfs
ID-5: /var/tmp raw size: 229.41 GiB size: 229.41 GiB (100.00%) used: 7.9 GiB (3.4%) fs: btrfs
Swap:      Kernel: swappiness: 10 (default 60) cache pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors:   System Temperatures: cpu: 46.0 C mobo: 43.0 C
Info:      Processes: 207 Uptime: 26m wakeups: 1 Memory: 7.69 GiB used: 3.32 GiB (43.2%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1227 lib: 305 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.3.01
╰─λ sudo dmesg | grep wifi
[    5.901081] iwlwifi 0000:02:00.0: can't change power state from D3hot to D0 (config space inaccessible)
[    5.901371] iwlwifi 0000:02:00.0: HW_REV=0xFFFFFFFF, PCI issues?
[    5.903273] iwlwifi: probe of 0000:02:00.0 failed with error -5
