Hello Everyone,
I have been having this issue with Chromium recently. Whenever I start the program it just shows the animation of loading around the cursor(bouncing chromium symbol) and that's it, it doesn't open or show any error or anything. I have already tried updating the system with pacman and upd command. I have also reinstalled the chromium but it still doesn't work. Hopefully, someone can help me. Thank you!
SGS
9 October 2021 00:17
2
invalid_name:
Help us, where is your inxi -Faz output?
Post the output if you start chromium in the terminal.
Both as text!!!
Welcome
This is when I try to run it through terminal
'''chrome_crashpad_handler: --database is required
Try 'chrome_crashpad_handler --help' for more information.'''
inxi -Faz output:
System: Kernel: 5.14.9-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=1be4c085-de10-4f18-b0aa-13acba4ab1d8
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: UX330UAK v: 1.0 serial: <filter>
Mobo: ASUSTeK model: UX330UAK v: 1.0 serial: <filter> UEFI: American Megatrends v: UX330UAK.315
date: 04/19/2019
Battery: ID-1: BAT0 charge: 15.9 Wh (99.4%) condition: 16.0/57.1 Wh (28.0%) volts: 11.6 min: 11.6
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging cycles: 735
CPU: Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21599
Speed: 3100 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3100 2: 3101 3: 2665 4: 3100
Graphics: Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0bda:58d1 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.14.9-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel port: f040 bus-ID: 02:00.0
chip-ID: 8086:24f3 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:3
chip-ID: 8087:0a2b class-ID: e001
Drives: Local Storage: total: 238.47 GiB used: 30.07 GiB (12.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SNAT256G1002 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 7002 scheme: GPT
Partition: ID-1: / raw-size: 49.7 GiB size: 49.7 GiB (100.00%) used: 30.05 GiB (60.5%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 24.8 MiB (9.7%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 49.7 GiB size: 49.7 GiB (100.00%) used: 30.05 GiB (60.5%) fs: btrfs
ID-4: /var/log raw-size: 49.7 GiB size: 49.7 GiB (100.00%) used: 30.05 GiB (60.5%) fs: btrfs
ID-5: /var/tmp raw-size: 49.7 GiB size: 49.7 GiB (100.00%) used: 30.05 GiB (60.5%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 1.5 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3400
Info: Processes: 199 Uptime: 58m wakeups: 16 Memory: 7.65 GiB used: 3 GiB (39.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1196 lib: 317
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Try:
HOME=$(mktemp -d) chromium
and paste any and all terminal output.
It showed error with $ in the command. Without it, this is the output. It also opened a window of the chromium on the homepage of garuda linux
[134109:134109:1008/211307.992896:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
[134078:134144:1008/211311.002631:ERROR:chrome_browser_main_extra_parts_metrics.cc(228)] crbug.com/1216328: Checking Bluetooth availability started. Please report if there is no report that this ends.
[134078:134144:1008/211311.002665:ERROR:chrome_browser_main_extra_parts_metrics.cc(231)] crbug.com/1216328: Checking Bluetooth availability ended.
[134078:134144:1008/211311.002672:ERROR:chrome_browser_main_extra_parts_metrics.cc(234)] crbug.com/1216328: Checking default browser status started. Please report if there is no report that this ends.
[134078:134144:1008/211311.426898:ERROR:chrome_browser_main_extra_parts_metrics.cc(238)] crbug.com/1216328: Checking default browser status ended.
Oh, fish, is there anything you won’t mess around with?
This means there’s an issue with your Chromium profile data. You can clear it by moving/removing the $HOME/.config/chromium
directory.
Yupp. Once I moved the backup file, it works fine now. Can you explain a bit why was this an issue suddenly?
No idea. Likely some form of file corruption, e.g. the system crashed or you forced the system to power off.
Yeah, actually. I did force shut down the system because it froze. Anyways, thank you for the help and quick replies.
Saad
9 October 2021 13:48
10
I have been having similar problems where chromium and Google chrome don't open. Please can someone help me
What does starting it via command line output?
Did you read the other posts in the thread and try the same steps? If not, why not?
Saad
9 October 2021 17:09
13
Recently I have been having problems with chromium and Google chrome not opening, please I need help
filo
9 October 2021 17:15
14
Is your system fully updated?
They both had an issue recently, now should be solved.
Providing the inxi -Faz would be a way to check it
SGS
9 October 2021 17:22
15
Please, read, follow and if it fails answer!
Saad:
Yes I did that
And what was the output from the terminal? You have to provide more detail than “it doesn’t work”.
system
Closed
12 October 2021 13:32
19
