I am copying an image file to a USB 2.0 flash drive formatted as NTFS. Started copying over 800MBps and gradually came down to 7.8MBps. Inxi is below.
It gave this Journal error:
Dec 04 19:07:03 heinrich-ms7c02 (udev-worker)[116913]: host9: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.2/0000:12:00.0/usb1/1-3/1-3:1.0/host9/scsi_host/host9/link_power_management_policy}, ignoring: No such file or directory
Dec 04 19:12:30 heinrich-ms7c02 sudo[117352]: heinrichjvr : a password is required ; TTY=pts/0 ; PWD=/home/heinrichjvr ; USER=root ; COMMAND=/usr/bin/true
Dec 04 19:12:36 heinrich-ms7c02 sudo[117582]: heinrichjvr : a password is required ; TTY=pts/0 ; PWD=/home/heinrichjvr ; USER=root ; COMMAND=/usr/bin/true
Dec 04 19:23:58 heinrich-ms7c02 systemd-coredump[117767]: Process 4728 (Thunar) of user 1000 dumped core.
Stack trace of thread 117203:
#0 0x00007ff78740b1bb g_mutex_lock (libglib-2.0.so.0 + 0xb31bb)
#1 0x0000562e6370a6d6 n/a (thunar + 0x586d6)
#2 0x0000562e63735e17 n/a (thunar + 0x83e17)
#3 0x00007ff78826f1fb n/a (libexo-2.so.0 + 0xf1fb)
#4 0x00007ff78758242e n/a (libgio-2.0.so.0 + 0x7a42e)
#5 0x00007ff7875b5db8 n/a (libgio-2.0.so.0 + 0xaddb8)
#6 0x00007ff7873e64d3 n/a (libglib-2.0.so.0 + 0x8e4d3)
#7 0x00007ff7873e39f5 n/a (libglib-2.0.so.0 + 0x8b9f5)
#8 0x00007ff7872029eb n/a (libc.so.6 + 0x8c9eb)
#9 0x00007ff7872867cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 4748:
#0 0x00007ff787278f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007ff787410276 n/a (libglib-2.0.so.0 + 0xb8276)
#2 0x00007ff7873b2b97 g_main_loop_run (libglib-2.0.so.0 + 0x5ab97)
#3 0x00007ff78761a14c n/a (libgio-2.0.so.0 + 0x11214c)
#4 0x00007ff7873e39f5 n/a (libglib-2.0.so.0 + 0x8b9f5)
#5 0x00007ff7872029eb n/a (libc.so.6 + 0x8c9eb)
#6 0x00007ff7872867cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 4728:
#2 0x00007ff7873b0162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007ff7875e7b16 g_application_run (libgio-2.0.so.0 + 0xdfb16)
#4 0x0000562e636d717a n/a (thunar + 0x2517a)
#5 0x00007ff78719dcd0 n/a (libc.so.6 + 0x27cd0)
#6 0x00007ff78719dd8a __libc_start_main (libc.so.6 + 0x27d8a)
#7 0x0000562e636d7285 n/a (thunar + 0x25285)
Stack trace of thread 4746:
#0 0x00007ff78728473d syscall (libc.so.6 + 0x10e73d)
#1 0x00007ff78740b2b7 g_cond_wait (libglib-2.0.so.0 + 0xb32b7)
#2 0x00007ff78737d1b4 n/a (libglib-2.0.so.0 + 0x251b4)
#3 0x00007ff7873e5a7e n/a (libglib-2.0.so.0 + 0x8da7e)
so.6 + 0x8c9eb)
Stack trace of thread 4747:
#3 0x00007ff7873b01b2 n/a (libglib-2.0.so.0 + 0x581b2)
ELF object binary architecture: AMD x86-64
Inxi:
╭─heinrichjvr@heinrich in ~ took 8ms
╰─λ garuda-inxi
Kernel: 6.1.64-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e430d727-5111-4d94-8122-55b81fdb8080 rw rootflags=subvol=@
quiet resume=UUID=fd6c4d21-749e-4d17-b36d-7b44a32d1fd2 loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.J1
date: 05/06/2023
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2980 high: 3500 min/max: 1600/3500 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1420 2: 3500
3: 3500 4: 3500 bogomips: 27958
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: DVI-D-1 empty: DP-1,DVI-D-2,HDMI-A-1
bus-ID: 10:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 40.0 C
Display: x11 server: X.Org v: 21.1.9 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: DVI-D-1 mapped: DVI-D-0 model: Samsung SyncMaster
serial: <filter> built: 2009 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x250mm (17.44x9.84") diag: 509mm (20") ratio: 16:9 modes:
max: 1600x900 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (polaris10
LLVM 16.0.6 DRM 3.49 6.1.64-1-lts) device-ID: 1002:67df memory: 3.91 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 570 Series (RADV POLARIS10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:67df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
lanes: 8 link-max: lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:aaf0
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 30:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.64-1-lts status: kernel-api with: aoss
Message: No PCI device data found.
IF-ID-1: enp18s0f0u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Spreadtrum Unisoc Phone driver: rndis_host v: kernel type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:7 chip-ID: 1782:5d20
Local Storage: total: 4.79 TiB used: 4.26 TiB (88.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Mushkin model: MKNSSDHL250GB-D8
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S1111A0L temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 model: Flash USB Disk size: 14.65 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 6.80 scheme: MBR
model: WD50NDZW-11BCSS0 size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 4800 serial: <filter> fw-rev: 1034 scheme: GPT
ID-1: / raw-size: 223.79 GiB size: 223.79 GiB (100.00%)
used: 109.21 GiB (48.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 223.79 GiB size: 223.79 GiB (100.00%)
ID-4: /var/log raw-size: 223.79 GiB size: 223.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 223.79 GiB size: 223.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 591 MiB (7.5%) priority: 100
System Temperatures: cpu: 35.5 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 2
Processes: 265 Uptime: 1h 38m wakeups: 0 Memory: total: 8 GiB
available: 7.68 GiB used: 1.69 GiB (22.0%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1445 libs: 486 tools: octopi,paru Shell: Bash
v: 5.2.21 running-in: xfce4-terminal inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-14
Last full system update: 2023-12-04 ↻
Failed units: run-media-heinrichjvr-KANE_LYNCH.mount systemd-vconsole-setup.service
╭─heinrichjvr@heinrich in ~ took 1s
╰─λ
