Ok new install:
inxi:
root=UUID=3c88b928-4cf2-4914-97d1-9b2c285f07b5 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 wm: muffin dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire 7741 v: V1.26 serial: <filter>
Mobo: Acer model: JE70_CP v: V1.26 serial: <filter> BIOS: Phoenix v: 1.26
date: 04/28/2011
ID-1: BAT0 charge: 46.0 Wh (100.0%) condition: 46.0/45.4 Wh (101.4%)
volts: 12.3 min: 10.8 model: Panasonic AS10D51 type: Li-ion serial: <filter>
status: full
Info: model: Intel Pentium P6200 bits: 64 type: MCP arch: Westmere level: v1
built: 2010-11 process: Intel 32nm family: 6 model-id: 0x25 (37) stepping: 5
microcode: 0x7
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB
desc: 1x3 MiB
Speed (MHz): avg: 2133 min/max: 933/2133 base/boost: 2130/3200 scaling:
driver: acpi-cpufreq governor: performance volts: 3.3 V ext-clock: 100 MHz
cores: 1: 2133 2: 2133 bogomips: 8511
Flags: ht lm nx pae sse sse2 sse3 ssse3
Device-1: Intel Core Processor Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-5.75
process: Intel 45nm built: 2010 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0046
Device-2: Alcor Micro Acer Integrated Webcam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.5:4
chip-ID: 058f:b002 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.9 driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: LVDS-1 model: AU Optronics 0x139e built: 2009 res: 1600x900
hz: 60 dpi: 106 gamma: 1.2 size: 382x214mm (15.04x8.43") diag: 438mm (17.2")
ratio: 16:9 modes: 1600x900
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 128 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Acer Incorporated ALI 5 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:3b56 class-ID: 0403
Server-1: PipeWire v: 0.3.83 status: n/a (root, process) with:
Device-1: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe vendor: Acer
Incorporated ALI Aspire 7740G driver: tg3 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 14e4:1692
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 link-max: gen: 2 speed: 5 GT/s
bus-ID: 04:00.0 chip-ID: 8086:2725 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.4:3 chip-ID: 8087:0032
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 953.87 GiB used: 9.4 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: AA20
scheme: MBR
ID-1: / raw-size: 97.79 GiB size: 97.79 GiB (100.00%) used: 9.4 GiB (9.6%)
fs: btrfs block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 97.79 GiB size: 97.79 GiB (100.00%)
used: 9.4 GiB (9.6%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 97.79 GiB size: 97.79 GiB (100.00%)
maj-min: 8:1
ID-4: /var/tmp raw-size: 97.79 GiB size: 97.79 GiB (100.00%)
maj-min: 8:1
ID-1: swap-1 type: zram size: 7.44 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2 dev: /dev/zram0
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 221 Uptime: 7m wakeups: 1 Memory: total: 8 GiB
available: 7.44 GiB used: 1.61 GiB (21.7%) igpu: 128 MiB Init: systemd
v: 254 default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages:
pm: pacman pkgs: 1251 libs: 369 tools: paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2024-01-12
Last full system update: 2024-01-12
Is partially upgraded: Yes
Error:
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
warning: garuda-settings-manager: local (1.0.2-5) is newer than garuda (1.0.2-3)
:: Replace mhwd-db-garuda-git with garuda/mhwd-db-garuda? [Y/n] y
:: Replace onevpl with extra/libvpl? [Y/n] y
:: Replace sweet-kde-theme-git with chaotic-aur/plasma5-themes-sweet-kde-git? [Y/n] y
resolving dependencies...
:: There are 2 providers available for dbus-units:
:: Repository core
1) dbus-broker-units 2) dbus-daemon-units
Enter a number (default=1): 1
1
:: removing sweet-kde-theme-git breaks dependency 'sweet-kde-theme-git' required by sweet-theme-full-git
Says teh same with option 2
