╭─fenris@fenris in ~ as 🧙 took 0s
╰─λ sudo garuda-inxi
Kernel: 6.15.9-zen1-1.1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=9a84ff09-2e69-42ea-b974-85d5f9a637fc rw rootflags=subvol=@
quiet rd.luks.uuid=3594f570-93c8-4a63-b099-34ce9110cbe1
rd.luks.uuid=72f3aff6-7ac6-43ad-bd47-ee4e2308a0a7
resume=/dev/mapper/luks-72f3aff6-7ac6-43ad-bd47-ee4e2308a0a7 loglevel=3
with: plank,xfce4-panel tools: xfce4-screensaver avail: xautolock
Type: Mini-pc Mobo: AZW model: EQ serial: N/A
uuid: 68ce8b00-6aeb-11ef-8ec5-a4a2b6b92601 UEFI: American Megatrends LLC.
v: FP7T107 date: 07/22/2024
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404108
Speed (MHz): avg: 741 min/max: 416/4937 boost: enabled
base/boost: 3300/4925 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 741 2: 741 3: 741 4: 741 5: 741
6: 741 7: 741 8: 741 9: 741 10: 741 11: 741 12: 741 13: 741 14: 741
15: 741 16: 741 bogomips: 105408
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
active: HDMI-A-1,HDMI-A-2 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
DP-7, Writeback-1 bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 50.0 C
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.1.4:10
chip-ID: 041e:40a1 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.18 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1017x286mm (40.04x11.26")
s-diag: 1056mm (41.59")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Samsung LS32B30
serial: <filter> built: 2025 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 184mm (7.2")
ratio: 16:9, 16:10 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,left model: HP LA2206
serial: <filter> built: 2011 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 20.1.8 DRM 3.63 6.15.9-zen1-1.1-zen) device-ID: 1002:1681
memory: 3.91 GiB unified: no
API: Vulkan v: 1.4.321 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 25.1.7-arch1.1
device-ID: 1002:1681 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: JMTek LLC. LCS USB Audio
lanes: 1 mode: 1.1 bus-ID: 7-1.1.3:9 chip-ID: 0c76:2018 class-ID: 0300
Device-5: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
Device-6: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 7-1.2:4 chip-ID: 0d8c:0102 class-ID: 0300
API: ALSA v: k6.15.9-zen1-1.1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.7 status: n/a (root, process) with:
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 8087:0029
Local Storage: total: 4.55 TiB used: 3.09 TiB (67.9%)
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731130WD temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 42.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 0202 scheme: MBR
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 772.44 GiB (41.9%)
fs: btrfs block-size: 4096 B dev: /dev/dm-1 maj-min: 253:1
mapped: luks-3594f570-93c8-4a63-b099-34ce9110cbe1
used: 776 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
used: 772.44 GiB (41.9%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
maj-min: 253:1 mapped: luks-3594f570-93c8-4a63-b099-34ce9110cbe1
ID-1: swap-1 type: partition size: 21.25 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-0 maj-min: 253:0
mapped: luks-72f3aff6-7ac6-43ad-bd47-ee4e2308a0a7
ID-2: swap-2 type: zram size: 19.3 GiB used: 1.13 GiB (5.8%) priority: 100
System Temperatures: cpu: 54.9 C mobo: 43.8 C gpu: amdgpu temp: 52.0 C
Memory: total: 20 GiB available: 19.31 GiB used: 14.47 GiB (74.9%)
Processes: 597 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 7.69 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1711 libs: 395 tools: pamac,paru,yay
pm: flatpak pkgs: 0 Compilers: gcc: 15.1.1 Shell: Bash (sudo) v: 5.3.3
running-in: xfce4-terminal inxi: 3.3.38
Garuda (2.7.5-1):
System install date: 2025-05-22
Last full system update: 2025-08-12
Failed units: vmware.service
20/21 checks run in 1.04 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- Failed systemd services found: vmware.service
╭─fenris@fenris in ~ as 🧙 took 5s
I keep trying to use paru to install octave, but I keep getting errors like this:
╰─λ paru octave
error: error sending request for url (https://aur.archlinux.org/rpc): error trying to connect: unexpected EOF: error trying to connect: unexpected EOF: unexpected EOF
╭─fenris@fenris in ~ as 🧙 took 1m3s
[🔴] × paru octave
error: error sending request for url (https://aur.archlinux.org/rpc): error trying to connect: Connection reset by peer (os error 104): error trying to connect: Connection reset by peer (os error 104): Connection reset by peer (os error 104): Connection reset by peer (os error 104)
╭─fenris@fenris in ~ as 🧙 took 2m31s
Some times it would work, sometimes it wouldn’t. Then when I try to put in my selections, they time out.
I only seem to be having this problem on my desktop not my surface pro. Paru works every time on my surface which has Garuda on it. The system however doesn’t.
Any ideas as to why this is happening?
Thanks
Also, what happened to this forum, using ~~~ doesn’t seem to work anymore make neat and tidy text for garuda-inxi?
