Hello, I've run into a few problems in recent updates, none of them are system-breaking but I worry that the Snapper one may become a problem in the future.
Since some updates in the last week or so I've run into 1 concerning issue and 1 annoying issue. The annoying issue is that my Grub is verbose unless I uncomment the splash, on just this 1 machine. All other machines I use Garuda on (2 laptops) have no issues with quiet with #splash. I've posted the kernel paramaters here, if anyone can see why I get a verbose startup I'd love to know. I think I added the loglevel=3 :
quiet quiet rd.udev.log_priority=3 vt.global_cursor_default=0 nvidia-drm.modeset=1 loglevel=3 # Modified by garuda-migrations: splash
The more concerning issue is with Garuda Update. It's not running the os-prober at the end anymore, which I believe isn't adding the Snapper Snapshots to Grub so that they are bootable. But I don't know if the problem is with Grub, with a Hook, or with the Update script. If I can't pinpoint what is causing the problem, I don't know how to start troubleshooting it. If it's a Grub issue, is it somehow related to why silent is being ignored? Let me know what I can add, please and thanks!
Kernel: 6.4.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c44d8c49-a931-4efd-b6a6-a1f296c8e7fb
rw rootflags=subvol=@ quiet quiet rd.udev.log_priority=3 vt.global_cursor_default=0
nvidia-drm.modeset=1 loglevel=3 quiet
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASRock model: Z490 Phantom Gaming 4/ac serial: <superuser required>
UEFI: American Megatrends v: L1.23 date: 12/04/2020
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake gen: core 10 level: v3
note: check built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 5
microcode: 0xF6
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4749 high: 5100 min/max: 800/5100 scaling: driver: intel_cpufreq
governor: performance cores: 1: 4700 2: 4699 3: 4700 4: 4704 5: 4700 6: 4700 7: 5100 8: 4699
9: 4700 10: 5100 11: 4701 12: 4696 13: 4699 14: 4700 15: 4700 16: 4699 bogomips: 121596
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Gigabyte driver: nvidia v: 535.54.03
alternate: nouveau,nvidia_drm non-free: 535.xx+ status: current (as of 2023-07) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-3,HDMI-A-1
empty: DP-1,DP-2,HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:2206 class-ID: 0300
Device-2: HTC (High Tech ) Vive driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12.1.2:15 chip-ID: 0bb4:2c87 class-ID: 0102
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3.1:7 chip-ID: 046d:082d class-ID: 0102
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 60 s-size: 812x457mm (31.97x17.99") s-diag: 932mm (36.68")
Monitor-1: DP-3 mapped: DP-4 note: disabled pos: primary model: AOC 1601W serial: <filter>
built: 2019 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled model: LG (GoldStar) TV SSCR2
serial: <filter> built: 2022 res: 1920x1080 dpi: 61 gamma: 1.2 size: 1600x900mm (62.99x35.43")
diag: 1836mm (72.3") ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: ASRock driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1
chip-ID: 10de:1aef class-ID: 0403
Device-3: Logitech G560 Gaming Speaker driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10.1:8 chip-ID: 046d:0a78 class-ID: 0300
Device-4: HTC (High Tech ) Vive driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
Device-5: HTC (High Tech ) Vive driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-12.1.5:16 chip-ID: 0bb4:2c87 class-ID: 0300 serial: <filter>
Device-6: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvide
Device-7: Texas Instruments PCM2912A Audio Codec driver: snd-usb-audio type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.4.4:8 chip-ID: 08bb:2912 class-ID: 0102
API: ALSA v: k6.4.3-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:0d4d class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.3.4:7 chip-ID: 0bda:8153 class-ID: 0000
IF: enp36s0u1u3u4 state: down mac: <filter>
IF-ID-3: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-4: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: HTC (High Tech ) Vive Hub Bluetooth 4.1 (Broadcom BCM920703) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12.2:12 chip-ID: 0bb4:0306
Report: bt-adapter ID: hci1 rfk-id: 2 state: up address: N/A
Device-2: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0aaa class-ID: e001
Report: ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 23.76 TiB used: 1.33 TiB (5.6%)
ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Crucial model: CT2000P3SSD8 size: 1.82 TiB
fw-rev: P9CR30A temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 2TB size: 1.82 TiB
fw-rev: 4B2QEXM7 temp: 29.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWR180 size: 7.28 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: 0603
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra USB 3.0 size: 115.69 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: FireCuda Dock size: 3.64 TiB block-size:
physical: 4096 B logical: 512 B type: USB rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1
tech: N/A serial: <filter> fw-rev: 235C scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: Extreme 55AE size: 1.82 TiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1
tech: N/A serial: <filter> fw-rev: 3001 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 vendor: Seagate model: Backup+ Hub BK size: 7.28 TiB block-size:
physical: 4096 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> fw-rev: D781 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.12 TiB (61.7%) fs: btrfs
dev: /dev/sdd2 maj-min: 8:50
ID-2: /boot/efi ra
w-size: 300 MiB size: 299.4 MiB (99.80%) used: 2.5 MiB (0.8%) fs: vfat
dev: /dev/sdd1 maj-min: 8:49
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.12 TiB (61.7%) fs: btrfs
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.12 TiB (61.7%) fs: btrfs
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.12 TiB (61.7%) fs: btrfs
ID-1: swap-1 type: zram size: 31.24 GiB used: 7 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 35.0 C pch: 53.0 C mobo: N/A gpu: nvidia temp: 42 C
Processes: 404 Uptime: 39m wakeups: 0 Memory: total: 32 GiB available: 31.24 GiB
used: 5.8 GiB (18.6%) Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman pkgs: 2049 libs: 553 tools: octopi,paru,yay
pm: appimage pkgs: 0 Client: shell wrapper v: 5.1.16-release inxi: 3.3.28
System install date: 2022-06-02
Last full system update: 2023-07-14
