Dear Garuda team,
before I describe my issues, I first want to thank you for this amazing distribution. I tried to switch from Windows to linux in the past couple of years and always had a very unsatisfying experience. This distribution finally changed it - you are doing everything right! Like the Garuda center, snapper and other stuff providing a nice user experience. Thank you!!
I’m using KDE Dragonized edition.
Now to my issues ![]()
- I have an nvidia rtx 4090 and an intel integrated-gpu.
- My main gaming monitor is connected to the nvidia card with a resolution of 5120x1440 @ 120 hz.
- The other two monitors, 1080p each, are connected to the intel igpu with 60hz and 75 hz.
I want to start telling you what is working:
- If i disable the integrated GPU completely and use nvidia with x11 session all is fine.
- If i want to use wayland (only nvidia gpu activated) the session starts, but my screen is not recognized and i only have a 4:3 1024x768 resolution. xrandr says connected to unknown.
- As soon as i activate the intel integrated-gpu more problems occur.
My problems are similar to the ones in this post.
https://forum.garudalinux.org/t/system-lags-when-starting-any-program/31989
Steam kinda freezes / locks up the UI for up to 40 seconds. Launching games from Steam takes ages. This happens even without activating the monitors connected to the integrate gpu (disabled monitors in kde settings). The mere presence of the intel gpu and its driver seem to cause this?!
- Starting games through bottles is fine if nvidia card is running alone.
As soon as the intel gpu is there, in-game 3d graphics start to tear and stutter.
So what is my goal?
I want to use the intel igpu to run the 2 smaller screens and handle the content for them like video decoding and stuff (Kodi for example) and accelerate them.
The nvidia card should only run the gaming monitor and my games.
I’m happy to use x11 but would prefer wayland.
I’ve looked a lot around the internet and found stuff like x11 multiseat, but that’s not really what i want…
I hope you have some advice / solutions for me :).
here comes garuda-inxi
root=UUID=69cfa927-5888-4db9-9f92-e09f791bd5c0 rw rootflags=subvol=@
resume=UUID=86a67afa-ea0f-4d3a-b772-92916a536b68 loglevel=3 ibt=off
Mobo: ASUSTeK model: ROG MAXIMUS XI HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1802
date: 12/01/2020
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 801 high: 824 min/max: 800/5100 scaling:
5: 800 6: 800 7: 800 8: 800 9: 824 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 bogomips: 115200
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0380
Device-2: NVIDIA AD102 [GeForce RTX 4090] vendor: ASUSTeK driver: nvidia
v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2684
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
Screen-1: 0 s-res: 7040x2520 s-dpi: 80 s-size: 2235x800mm (87.99x31.50")
s-diag: 2374mm (93.46")
Monitor-1: DP-2 pos: primary,bottom-l res: 5120x1440 hz: 120 dpi: 130048
size: 1x1mm (0.04x0.04") diag: 1mm (0.06") modes: N/A
Monitor-2: HDMI-1-1 pos: bottom-r res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-3: HDMI-1-2 pos: top-center res: 1920x1080 dpi: 93
Monitor-4: None-2-1 size-res: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB
API: Vulkan v: 1.3.269 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 545.29.02
device-ID: 10de:2684 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
v: 23.2.1-arch1.2 device-ID: 8086:3e98 surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-2: NVIDIA AD102 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22ba
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 11.03 TiB used: 208.76 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT4000P3PSSD8
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 35.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT4000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 42.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: M4-CT128M4SSD2
tech: SSD serial: <filter> fw-rev: 040H scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WDS100T3 XHC-00SJG0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1
tech: N/A serial: <filter> fw-rev: 3106 scheme: GPT
ID-1: / raw-size: 84.65 GiB size: 84.65 GiB (100.00%)
used: 19.56 GiB (23.1%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 84.65 GiB size: 84.65 GiB (100.00%)
ID-4: /var/log raw-size: 84.65 GiB size: 84.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 84.65 GiB size: 84.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.18 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.3 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 45.0 C mobo: 29.0 C gpu: nvidia temp: 53 C
Fan Speeds (rpm): cpu: 0 gpu: nvidia fan: 0%
Processes: 327 Uptime: 30m wakeups: 0 Memory: total: 32 GiB
available: 31.18 GiB used: 4.01 GiB (12.9%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1542
pm: pacman pkgs: 1536 libs: 501 tools: octopi,pamac,paru pm: flatpak pkgs: 6
Shell: fish v: 3.6.1 default: Bash v: 5.2.15 running-in: konsole
inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-11-02
Last full system update: 2023-11-02
