Hi, I’m a total newcomer to Linux in general, and have decided to give it a shot after owning and tinkering around with a Steam Deck (mainly for gaming).
I’ve been having trouble setting up / installing NVIDIA drivers onto my installation of Garuda. My gaming experience have been kind of disappointing so far (I’m assuming it is due to drivers). Tried playing Cuphead which ran at around 5-6frames per second, and Smite which ran at around 20-30, which is quite disappointing to see considering the build of this computer. (EDIT: Forgot to mention that this is a dualboot alongside a Windows10 installation.)
-I’ve tried installing drivers using “sudo pacman -S nvidia nvidia-settings” but to no awail, this method of installation actually messes up my OS. After running this command, I can only boot into an empty environment. Only cursor shows up, nothing else, and I have to resort into using a snapshot to boot.
-I’ve also tried following the installation process through the official arch wiki (NVIDIA - ArchWiki), but have gotten stuck at the part where when opening the installer, says I need to exit X before installing.
-Using the default drivers that come with Garuda, is the only thing that has gotten the installation of my drivers correctly. I know because this is the only way I have ever gotten more than one connected display to post.
-What I’ve also tried is booting onto other Kernels such as LTS, but all kernels other than Zen, just result in only one of my displays getting to post.
Here’s my garuda-inxi :
╭─kew@Kew in ~
╰─λ garuda-inxi
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/.snapshots/21/snapshot/boot/vmlinuz-linux-zen
root=UUID=e92ed620-1d43-403e-8469-1a3aead20570 quiet loglevel=3 ibt=off
rootflags=defaults,noatime,compress=zstd,subvol=@/.snapshots/21/snapshot
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: ASRock model: B650 PG Lightning
Megatrends LLC. v: 2.02 date: 11/17/2023
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3603 high: 5444 min/max: 400/5573 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3641 2: 5444 3: 400
4: 4846 5: 5035 6: 400 7: 3560 8: 400 9: 4404 10: 5332 11: 5313 12: 5119
13: 5087 14: 4524 15: 3755 16: 400 bogomips: 143731
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: 545.xx+ status: current (as of 2024-02)
arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie:
active: DP-1,DP-3,HDMI-A-1 empty: DP-2 bus-ID: 01:00.0 chip-ID: 10de:2786
Device-2: Oculus VR Rift CV1 Sensor driver: uvcvideo type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.1:5 chip-ID: 2833:0211
class-ID: ef00 serial: <filter>
Device-3: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.2:4
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Device-4: Oculus VR Rift CV1 Sensor driver: uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-2:3 chip-ID: 2833:0211
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau d-rect: 5760x1080
display-ID: 0
Monitor-1: DP-1 pos: center res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-3 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.3.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: NV194 device-ID: 10de:2786 memory: 11.67 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM 16.0.6)
Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.6
Device-3: Texas Instruments PCM2902 Audio Codec
lanes: 1 mode: 1.1 bus-ID: 5-1.1:3 chip-ID: 08bb:2902 class-ID: 0300
Device-4: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 370.97 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:10 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 32.9 C
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 37.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: M3 size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 0707
scheme: MBR
ID-1: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 25.6 MiB (26.6%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:2
ID-2: /home raw-size: 213.02 GiB size: 213.02 GiB (100.00%)
used: 21.12 GiB (9.9%) fs: btrfs dev: /dev/nvme2n1p5 maj-min: 259:6
ID-3: /var/log raw-size: 213.02 GiB size: 213.02 GiB (100.00%)
ID-4: /var/tmp raw-size: 213.02 GiB size: 213.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.96 GiB used: 3.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 65.2 C mobo: N/A
Memory: total: 32 GiB note: est. available: 30.96 GiB used: 7.12 GiB (23.0%)
Processes: 361 Power: uptime: 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.36 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1372 libs: 458 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-16
Last full system update: 2024-02-16
Failed units: snapper-cleanup.service systemd-remount-fs.service
I’m eager to learn how to troubleshoot this issue.
Cheers!
