Hi Guys, good afternoon from Chile.
I have an issue, and I’m searching and searching, but the solutions are too old for my issue, and there are no longer available ion 2023, thbis, because all the answers are related with Latte Dock pannel, but now, this isn’t in use.
I have two monitors, in the primary one, is all normal, i can close the windows, drag trhem, everything normal. But, in myu second screen, i can’t close, or minimize the windows.
Do you know some answer for this problem? i’m going crazy with this.
Thanks!
Kayo
14 December 2023 22:08
2
Hello, please post your garua-inxi
as stated in the new thread template.
Sounds like your monitors are overlapping. Check your display config (right click on the desktop). You should see your screens in an overlay at the top. Make sure they aren’t overlapping.
Sorry, i didn’t read that part: here is the ionfo that all of you asked.
LANGUAGE = "en_US",
LC_ALL = (unset),
LC_ADDRESS = "es_CL.UTF-8",
LC_NAME = "es_CL.UTF-8",
LC_MONETARY = "es_CL.UTF-8",
LC_PAPER = "es_CL.UTF-8",
LC_IDENTIFICATION = "es_CL.UTF-8",
LC_TELEPHONE = "es_CL.UTF-8",
LC_MEASUREMENT = "es_CL.UTF-8",
LC_TIME = "es_CL.UTF-8",
LC_NUMERIC = "es_CL.UTF-8",
LANG = "en_US"
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.6.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=60798c1b-f44d-49e6-8329-02238293d0b1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: PRIME B560M-A v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 0403
date: 01/26/2021
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 3 microcode: 0xF8
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1654 high: 4303 min/max: 800/4300 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 4303 3: 800
4: 800 5: 800 6: 800 7: 4128 8: 800 9: 4220 10: 800 11: 800 12: 800
bogomips: 69597
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: DP-2,HDMI-A-1 empty: DP-1,DP-3
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Sunplus Innovation HD 720P webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10.3:6
chip-ID: 1bcf:2701 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: DP-2 note: disabled pos: primary,right
model: ViewSonic VX2718 series serial: <filter> built: 2021 res: 1920x1080
dpi: 80 gamma: 1.2 size: 609x348mm (23.98x13.7") diag: 690mm (27.2")
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: left
model: Asus VP247 serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 94
gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 545.29.06 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: Sunplus Innovation HD 720P webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.6-zen1-1-zen status: kernel-api with: aoss
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 3.86 TiB used: 115.42 GiB (2.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: G325E1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFMC0.0 temp: 40.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0A-00JH30
tech: SSD serial: <filter> fw-rev: 0400 scheme: MBR
model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
model: WD10EZEX-00BBHA0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-1: / raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
used: 115.42 GiB (23.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /home raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-3: /var/log raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-4: /var/tmp raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.48 GiB used: 351.8 MiB (2.2%)
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 335 Uptime: 1h 18m wakeups: 0 Memory: total: 16 GiB
available: 15.48 GiB used: 6.04 GiB (39.0%) Init: systemd v: 255
pm: pacman pkgs: 1515 libs: 479 tools: octopi,pamac,paru Shell: fish
v: 3.6.4 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-10-24
Last full system update: 2023-12-18 ↻
Kayo
18 December 2023 20:53
7
Firstly, you need to reboot after your update so you can use the most latest kernel. After that, see if your issue persists.
Also, you are running an outdated version of your BIOS (looks to be the oldest listed on the site for that board). I would highly suggest updating this as this can cause numerous problems if left outdated.
ASUS Prime series is expertly engineered to unleash the full potential of AMD and Intel processors. Boasting a robust power design, comprehensive cooling solutions and intelligent tuning options, Prime series motherboards provide daily users and DIY...
system
Closed
1 January 2024 20:54
8
