Issues with locales: LibreOffice won't open any file with non-english characters in filename or path
Hello!
So i have this issue that LibreOffice won’t open any file if the filename or the file path has a non-english character like “ñ”, “š” or any japanese character. But LO shows perfectly fine any special character in the documents. When I try to open one I just received an error message that says the following:
“/home/user/???.odt was started with an invalid parameter” if the filename has a special character or even
“there’s no file home/user/???/name.odt”
I’ve searched a lot in different forums but didn’t get anyway to solve it. I’ve notice that changing the system language to english this files open normaly, but not when I have the system in my language, in basque. Also, I have some errors shown in locale -a command, but i haven’t been able to fix them or to finding any solution on any forum nor the wiki. Also, at the begining of the garuda-inxi it shows a warning about the locale, so maybe there’s the issue
This is what I get with locale -a and localectl status comands
locale -a
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_COLLATE to default locale: No such file or directory
C
C.utf8
POSIX
ca_ES.utf8
en_GB.utf8
en_US.utf8
es_ES.utf8
eu_ES.utf8
gl_ES.utf8
ja_JP.utf8
lv_LV.utf8
pt_PT.utf8
localectl status
System Locale: LANG=eu_ES.UTF-8
VC Keymap: eu
X11 Layout: (unset)
LANGUAGE = "eu:es:en_US",
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = (unset),
LC_COLLATE = (unset),
LC_TIME = "eu_ES.UTF-8",
LC_MESSAGES = (unset),
LC_MONETARY = (unset),
LC_ADDRESS = (unset),
LC_IDENTIFICATION = (unset),
LC_MEASUREMENT = (unset),
LC_PAPER = (unset),
LC_TELEPHONE = (unset),
LC_NAME = (unset),
LANG = "eu_ES.UTF-8@euro"
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=687c1e5f-6fd1-49db-8c68-ddf00ee5bac9 rw rootflags=subvol=@
resume=UUID=eef151b2-ca3b-4eda-9dd7-3b73fb9f3938 loglevel=3
mitigations=off ibt=off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: Micro-Star product: GS66 Stealth 10SE v: REV:1.0
Mobo: Micro-Star model: MS-16V1 v: REV:1.0 serial: <filter>
part-nu: 16V1.1 uuid: 2421bd77-b700-c74a-8139-1cc650c3f2e1
UEFI: American Megatrends v: E16V1IMS.112 date: 11/19/2020
ID-1: BAT1 charge: 37.1 Wh (52.5%) condition: 70.7/95.0 Wh (74.5%)
volts: 15.3 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-10875H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xFC
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2081 high: 4918 min/max: 800/5100 base/boost: 2178/8300
scaling: driver: intel_pstate governor: performance volts: 0.7 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 4901
7: 4891 8: 800 9: 800 10: 800 11: 800 12: 800 13: 4918 14: 4894 15: 800
16: 4896 bogomips: 73598
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Bison HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5 chip-ID: 5986:2127
Device-4: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 534d:2109
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
gpu: i915,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: not-matched mapped: HDMI-A-1 pos: left res: 1920x1080 hz: 75
dpi: 102 size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
Monitor-2: not-matched mapped: eDP-1 pos: primary,right res: 1920x1080
hz: 240 dpi: 142 size: 344x194mm (13.54x7.64") diag: 395mm (15.55")
modes: N/A
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
device-ID: 8086:9bc4 memory: 15.21 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 10 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 24.2.2-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 560.35.03
device-ID: 10de:1f15 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.2-arch1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: MacroSilicon USB Video
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: n/a (root, process) with:
Device-2: Intel Killer E3100X 2.5 Gigabit Ethernet driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 3d:00.0
chip-ID: 8086:3101 class-ID: 0200
IF: enp61s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 1.84 TiB used: 490.2 GiB (26.0%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 39.9 C
SMART: yes health: PASSED on: 80 hrs cycles: 887
read-units: 29,367,707 [15.0 TB] written-units: 6,539,787 [3.34 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1032 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11111000 temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 191d 22h cycles: 2,934
read-units: 30,664,113 [15.7 TB] written-units: 28,668,838 [14.6 TB]
ID-1: / raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
used: 490.2 GiB (54.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:7
used: 588 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:6
ID-3: /home raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
maj-min: 259:7
ID-4: /var/log raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
maj-min: 259:7
ID-5: /var/tmp raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
maj-min: 259:7
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.28 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
System Temperatures: cpu: 70.0 C pch: 48.0 C mobo: N/A
Memory: total: 32 GiB available: 31.16 GiB used: 6.22 GiB (20.0%)
igpu: 64 MiB
Processes: 368 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2263 libs: 609 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.32
System install date:     2022-12-17
Last full system update: 2024-09-28
Windows dual boot:       Yes
Your configuration is curiously wrong. Did you blind-copy it from somewhere or manually edit at any point? Can you show this output?
cat /etc/locale.conf
For example, here’s mine.
LANG=en_US.UTF-8
LC_ADDRESS=en_US.UTF-8
LC_IDENTIFICATION=en_US.UTF-8
LC_MEASUREMENT=en_US.UTF-8
LC_MONETARY=en_US.UTF-8
LC_NAME=en_US.UTF-8
LC_NUMERIC=en_US.UTF-8
LC_PAPER=en_US.UTF-8
LC_TELEPHONE=en_US.UTF-8
LC_TIME=en_US.UTF-8
This is a hint to a problem, it should not have these values. Remove them from the file, then run
locale-gen
Finally, logout (or preferably reboot) to apply fully.
Pretty spicy, is your cooler ok?
Thank you for answering!
I did not edit any of the configuration of the locale, so I don’t know… The output for cat /etc/locale.config is just this:
LANG=eu_ES.UTF-8
Therefore, I have no values to erase from the file, and generating doesn’t change anything.
Also, thanks for pointing it out, I’ll definitely check that
Can you copy the config contents sent above, but with eu_ES.UTF-8 for your own locale instead, followed by locale-gen?
I’ve solve it, thank you.
So I tried that after reading your first message, but it didn’t work. I coppied this to the locale.conf file, run locale-gen and restarted.
LANG=eu_ES.UTF-8
LC_ADDRESS=eu_ES.UTF-8
LC_IDENTIFICATION=eu_ES.UTF-8
LC_MEASUREMENT=eu_ES.UTF-8
LC_MONETARY=eu_ES.UTF-8
LC_NAME=eu_ES.UTF-8
LC_NUMERIC=eu_ES.UTF-8
LC_PAPER=eu_ES.UTF-8
LC_TELEPHONE=eu_ES.UTF-8
LC_TIME=eu_ES.UTF-8
Today i did it again, but after restarting I’ve noticed that garuda-inxi gives this output at the begining:
LANGUAGE = “eu:en_US”,
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = “eu_ES.UTF-8”,
LC_TIME = “eu_ES.UTF-8”,
LC_MONETARY = “eu_ES.UTF-8”,
LC_ADDRESS = “eu_ES.UTF-8”,
LC_IDENTIFICATION = “eu_ES.UTF-8”,
LC_MEASUREMENT = “eu_ES.UTF-8”,
LC_PAPER = “eu_ES.UTF-8”,
LC_TELEPHONE = “eu_ES.UTF-8”,
LC_NAME = “eu_ES.UTF-8”,
LANG = “eu_ES.UTF-8@euro”
perl: warning: Falling back to the standard locale (“C”).
So I’ve copied the parameters that give “unset” (LC_ALL; LC_CTYPE; LC_COLLATE and LC_MESSAGES) and added them to the locale.conf, run locale-gen, then restarted, and now everything works.
Thank you for your time!
