Hello, I'm new to Garuda and so far I love it !
But I'm here because I have an issue
I guess I did play around a little too much and now my settings are kind of messed up.
I did try to reset all settings with Garuda assistant but it did not help.
As you can see in the screenshot, the buttons on the Konsole window for example looks generic and not the 3 dots, also look at the latte-dock, everything seems to be cramped in the corner and I can't even read the text. Is there anything I can do other than fresh re-install?
filo
1 April 2022 12:58
2
Hi there, welcome.
Your garuda-inxi is missing in the post...
Did you logoff/logon after resetting with Garuda Assistant?
Oups, sorry for that. Yeah I did a reboot to be sure. Here is the garuda-inxi
root=UUID=331cf3ea-c83a-449c-8bca-ffbcf66a6c2a rw rootflags=subvol=@
loglevel=3 intel_iommu=on rd.driver.pre=vfio-pci kvm.ignore_msrs=1
Type: Desktop System: Micro-Star product: MS-7C04 v: 1.0
Mobo: Micro-Star model: MPG Z390I GAMING EDGE AC (MS-7C04) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.60
date: 08/08/2019
ID-1: hidpp_battery_0 charge: 84% condition: N/A volts: 4.0 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xEC
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4985 high: 5009 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4986 2: 5001 3: 5004
4: 5009 5: 5002 6: 5001 7: 4999 8: 4978 9: 5000 10: 5001 11: 5006
12: 5001 13: 4890 14: 4907 15: 4997 16: 4992 bogomips: 115200
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: DP-1,HDMI-A-1
empty: HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e98
class-ID: 0380
Device-2: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A]
vendor: Micro-Star MSI driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
Screen-1: 0 s-res: 4530x4075 s-dpi: 91 s-size: 1262x1135mm (49.69x44.69")
s-diag: 1697mm (66.82")
Monitor-1: DP-2 pos: primary,top-left res: 1920x1080 hz: 144 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
Monitor-2: DP1 pos: top-right res: 2560x1440 hz: 60 dpi: 108
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-3: HDMI1 pos: bottom-l res: 3840x2160 hz: 30 dpi: 325
size: 300x260mm (11.81x10.24") diag: 397mm (15.63") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: C-Media JUST MIXER5 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.1:6 chip-ID: 0d8c:0133
Device-4: Thesycon System & Consulting GmbH SMSL USB AUDIO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:5 chip-ID: 152a:85dd
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-14:9 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 4.78 TiB used: 169.25 GiB (3.5%)
model: PC SN720 SDAPNTW-256G-1006 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 10110006 temp: 62.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 55.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
used: 169.25 GiB (18.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 31.21 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 54.0 C pch: 72.0 C mobo: N/A gpu: nvidia
temp: 44 C
Processes: 360 Uptime: 39m wakeups: 7 Memory: 31.21 GiB
used: 4.74 GiB (15.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1781 lib: 529 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-29
Last full system update: 2022-04-01
filo
1 April 2022 13:20
4
Wow, I think you played around a lot with it!
You could try to set back these settings (System Settings, Appearence):
Global Theme = Sweetified Plasma
Windows Decorations = Sweet-Dark
Application Style = kvantum-dark
Gnome/GTK Application Style = Sweet-Dark
Plasma Style = Sweet
Colors = Sweetified
Icons = BeautyLine
I’m going a bit by heart here and copying from previous posts, since I’m not on the system at the moment.
Probably you should also change something else, but most likely you’ll see it or remember it during the other updates…
That did the trick for all the theme related issues ! Thanks a lot !!!
I still have that issue in the latte-dock, not sure what to do for that one.
It's only happening when the focused window is on the primary screen (where also indeed the latte-dock is)
When I edit the latte-dock layout, I'm getting this
filo
1 April 2022 13:51
6
Check if this helps…
That’s a different problem anyway, maybe you’d better create a new topic with all the needed information.
Try also to give a look at this one:
That did the trick. I removed the top bar from my 3rd screen (I don't need it anyway) and it looks like it did a reset and went back to normal !
Thanks again for all the help !
system
Closed
3 April 2022 14:15
8
