Issues with game controller not working after recent update
So, firstly let me say a big “Thank you” to the Garuda team for this distro. It has worked very well for me since switching from Windows to Linux, and I appreciate all of the continued development!
My problem: I updated my system a few days ago (and again today, right before posting this), and ever since, my Saitek Cyborg EVO joystick is no longer being passed through Steam/Proton into the main game that I play, and I know the joystick is recognized by the system and functional, as I tested it in Settings> Input Devices>Game Controller
I researched this issue thinking it was a Steam problem, and applied every possible solution I could find to no avail. I’m starting to think it is a Proton issue (based on my research and the fact that the latest Proton build appears to be from 1/10/24). Any advice on what to try or what to check?
What I haven’t done yet and is my next course of action I think:
  1. uninstall/reinstall Proton and/or Steam
  2. Roll back to a Snapshot dated prior to 1/10/24
Garuda-inxi output:
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=77c09ea1-ce29-42c3-bca2-2d425312a722 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Micro-Star product: MS-7D53 v: 1.0
Mobo: Micro-Star model: MPG X570S EDGE MAX WIFI (MS-7D53) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.70
date: 07/03/2023
Device-1: hidpp_battery_0 model: Logitech G700s serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3746 high: 3863 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3600 6: 3675 7: 3800 8: 3800 9: 3626 10: 3800 11: 3594
12: 3800 13: 3592 14: 3800 15: 3863 16: 3800 bogomips: 121599
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: eVga.com.
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 2d:00.0 chip-ID: 10de:2482
Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.3:9
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 5360x1440 s-dpi: 109 s-size: 1249x342mm (49.17x13.46")
s-diag: 1295mm (50.98")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,left
model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2018 res: 3440x1440
hz: 60 dpi: 109 gamma: 1.2 size: 800x335mm (31.5x13.19")
diag: 867mm (34.1") modes: max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: Asus VH238 serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 96
gamma: 1.2 size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.274 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2482
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM 16.0.6)
Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
bus-ID: 2d:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3
chip-ID: 0db0:151f class-ID: 0300
Device-4: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 27:00.0
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2725
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:5 chip-ID: 8087:0032
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 35.52 TiB used: 637.23 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apacer model: APSFG-2T-CSUS
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.2.F.83 temp: 34.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWG480 size: 7.28 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 0601 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST20000NM007D-3DJ103
size: 18.19 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MD04ACA500
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Toshiba model: MD04ACA400
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 7200
serial: <filter> fw-rev: 5438 scheme: GPT
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 637.23 GiB (33.4%)
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 637.23 GiB (33.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
System Temperatures: cpu: 35.1 C mobo: N/A gpu: nvidia temp: 42 C
Processes: 409 Uptime: 24m wakeups: 0 Memory: total: 32 GiB
available: 31.26 GiB used: 4.59 GiB (14.7%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 2197 libs: 590
tools: octopi,pamac,paru Shell: fish v: 3.7.0 default: Bash v: 5.2.21
Garuda (2.6.22-1):
System install date:     2023-09-23
Last full system update: 2024-01-14 ↻
Thanks in advance for any advice.
Reboot.
I did, numerous times. I know, you see that I didn’t reboot when I posted that Gardua-inxi, but I did reboot after that before I posted here. No change.
I’ve also tried the following (with a reboot after each):
  1. reinstall Proton (specifically, proton-ge-custom, 2:GE.Proton8.27-1)
  2. removed the above version and installed proton-caller instead, which won’t even let the game boot, so I uninstalled it and reinstalled the former
  3. rolled back to a previous Snapshot from 1/10/24, which has 2:GE.Proton8.25-1, and after reboot, my joystick works perfectly as it did before the updates. So the solution was rolling back to a previous version via a Snapshot.
Of course there are multiple other updates that were rolled back to a previous version that could also have been the culprit (protontricks maybe, or one of the dependencies for Proton I suppose), but I’m assuming it was this. Maybe I’ll try to update everything except Proton and see what happens to know for sure. Would that help the Garuda Devs at all?
Not a dev but that would certainly be a step forward. Try to update everything one at a time you can use /var/log/garuda/garuda-update to see which softwares you should update and you would be able to pin down the problematic software.
UPDATE AS OF 1/20/24:
I think I’ve figured out where the problem lies on this issue. After doing some testing, I’ve discovered that if I use proton-ge-custom (an unsupported AUR package, which I is apparently maintained by Glorious Eggroll) I have no joystick input into the game despite having joystick recognition at the system level, verified through the game controller settings as stated previously. This was the compatibility tool that was being used by Steam.
If I change that to Proton 8.0-4, my joystick works as it should. This is the solution I’m currently implementing. Note that this is with my system updated as of yesterday, not using the Snapshot I had rolled back to (from 1/10/24, pre-update). I’m not sure if the Snapshot was using Proton 8.0-4 or the AUR package as I didn’t check that, and I don’t plan to roll back to that Snapshot just to see.
I will notify the package maintainer of my discovery. Thanks for the replies.
