Issues with files and programs not opening after using a browser for a few hours
All of these KDE / Window Manager specific issues are similar and happening together except for the bleechbit issue that happens everytime until run miltiple times which makes it stop happening on some systems.
Bleechbit crashes each time run until it does not then it runs fine; running bleechbit multiple times usually fixes this or fixed it once; Bleechbit Firefox options disappeared entirely after unchecking a few of then running bleechbit.
Files will not launch and hang on attempt until stopping the use of that folder and creating a new folder and placing files into that folder from folders where files work. (problem corrects itself after rebooting…usually)
In Librewolf
After Downloading and saving 9 or so Video & subtitle & Transcript files from Coursera into one folder; then changing folders and doing the same for the next folder; the file names saved are only the first 2 characters and the remaining files must be copy and pasted manually from the copied and saved file name after that point.
Looks like this is being done remotely in real time because creating documents now creates the file with the name and also another file that is not labeled and with no text in the actual file.
Long time no post; things have been going well mostly other then these issues; was having a considerable amount of issues for a long time.
Much appreciated.
Kernel: 6.9.9-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 14.1.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=8ce260fd-1bad-4769-927f-1b285b84e21b rw rootflags=subvol=@
quiet rd.luks.uuid=fea446ef-393c-4abf-8798-e0ed260636ee loglevel=3
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: ASUSTeK product: ZenBook UX425UG_Q408UG v: 1.0
Mobo: ASUSTeK model: UX425UG v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: UX425UG.301
date: 12/05/2021
ID-1: BATT charge: 21.9 Wh (56.0%) condition: 39.1/63.1 Wh (61.9%)
volts: 12.0 min: 12.0 model: ASUSTeK UX425 type: Li-ion serial: <filter>
status: discharging cycles: 124
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 778 high: 1979 min/max: 400/4056 scaling:
4: 1979 5: 400 6: 400 7: 1388 8: 400 9: 1368 10: 400 11: 1403 12: 400
bogomips: 50324
Device-1: NVIDIA TU117M [GeForce MX450] vendor: ASUSTeK driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 02:00.0
chip-ID: 10de:1f9c class-ID: 0302
Device-2: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 42.0 C
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.3-arch1.1
renoir LLVM 18.1.8 DRM 3.57 6.9.9-hardened1-1-hardened)
device-ID: 1002:164c memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.3-arch1.1
device-ID: 1002:164c surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce MX450 driver: nvidia v: 555.58.02
device-ID: 10de:1f9c surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.1.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.9.9-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Message: No PCI device data found.
Device-1: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1:5 chip-ID: 0b95:1790
IF: enp4s0f4u1c2 state: up speed: 1000 Mbps duplex: half mac: <filter>
Local Storage: total: 931.51 GiB used: 22.14 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 38.9 C
ID-1: / raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
used: 22.11 GiB (22.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-fea446ef-393c-4abf-8798-e0ed260636ee
used: 26.3 MiB (27.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
ID-4: /var/log raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.54 GiB size: 97.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.17 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.4 C mobo: N/A gpu: amdgpu temp: 43.0 C
Memory: total: 8 GiB note: est. available: 7.17 GiB used: 3.5 GiB (48.8%)
Processes: 338 Power: uptime: 1h 1m states: freeze,mem suspend: s2idle
wakeups: 0 services: org_kde_powerdevil, power-profiles-daemon, upowerd
Packages: pm: pacman pkgs: 1390 libs: 388 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date:     2024-06-26
Last full system update: 2024-07-16
Failed units:            nmb.service
Please write to the respective developers or open error descriptions in Github or Gitlab, etc…
As mentioned in the template, please always only report one problem per topic, but this is irrelevant here because we do not support these programmes here in the forum.
All of these issues are likely memory leak specific to KDE or Dolphin.
Also having issues with copying files after downloading anything from Brave.
Happened after downloading multiple tracks from beatport as well as other similiar operations.
Was able to copy the files eventually with Beatport and move them after about an hour of shenanigans.
Get can not copy or can not right dialogs for files that have been recently downloaded.
Apart from that, I can’t understand your issues here.
There is nothing more to write.
Its an exploit or malware issue; some sort of memory leak from a downloaded file; which allows manipulation of Dophin or KDE.
This is so detrimental to workflow that will likely need to stop using Linux.
Can see that happening for pro audio issues; not something like this.
Evidence?
Probably something similar to this previous exploit as far as duplication pathway. ~ https://www.zdnet.com/article/unpatched-kde-vulnerability-disclosed-on-twitter/
It’s not an evidence and your link said
"The exploitation scenario involves some social engineering to trick a user into downloading these malicious files, but the advantage to this technique is that the user does not have to interact or open these files.
Some security experts have played down the bug’s importance because it requires tricking users into downloading .desktop and .directory files – both of which are very uncommon downloads and will arrouse suspicions with most tech-savvy Linux users."
You are the administrator.
Do not use TwX, do not download files from anywhere and you are safe from malware etc…
You are, so far, the only one here with this problem, what might be the reason? :thinking:
Having issues with loading Twitter / X Login page and many other Java Script Sites in Fire Dragon as well. Librewolf works better but will not work with many; Java Script Should be replaced by HTML5 it is not secure. ~ https://medium.com/@spider65535/man-in-the-middle-attack-using-beef-js-hook-and-xerosploit-ecd0c41d0299
Solved the problem for this specific issue by changing the file name which contained some strange arrows; this seems to be happening often in Garuda not sure of the reason why it is causing issues; also error notifications were not very helpful in solving this issue.
When moving files to partitions that are not a Linux format this causes issues and sometimes the arrows are difficult to notice at a glance. Much appreciated.
This is because Linux and Windows use very different file naming conventions.
You can mitigate this somewhat by using Windows specific mount options in fstab, or by running a bash script to detect bad file names before transferring any files to a Windows file system. I would also have the script scan for any files larger than 4 GB in size before transferring from Linux to a fat based storage device such as a thumb drive. Windows file systems are very fragile and easily corrupted, best not to use Windows file systems with Linux period.
