Hi!, I am currently trying to setup a virtual machine with a iGPU passthrough. i have separate Gpu which i wanna keep for the host and pass my CPU’s integrated graphics to my virtual machine.
I can boot to my virtual machine without adding the iGPU to my Vm in Virt Manager with no issues. But when i do add it i can see my iGPU in the boot but it gives me these texts: Imgur: The magic of the Internet .
What have i done/checked:
- blacklisted i915
- Kernel parameters
- It doesn’t share a IOMMU group with any other devices.
- iGPU is compatible with MacOs 13
- iGPU uses vfio-pci drivers
Kernel: 6.10.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=5f7664c7-0382-499b-a6ec-951219fb7fa7 rw rootflags=subvol=@
i915.enable_gvt=1 i915.enable_guc=0 quiet loglevel=3 intel_iommu=on
iommu=pt vfio-pci.ids=8086:a2f0,8086:5912 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
wm: kwin_x11 tools: avail: gtklock, nwg-lock, swayidle, swaylock vt: 2
Type: Desktop Mobo: MSI model: B250M MORTAR (MS-7A69) v: 1.0
UEFI-[Legacy]: American Megatrends v: 2.20 date: 04/06/2017
Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
desc: 1x6 MiB
Speed (MHz): avg: 3696 high: 3699 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 3699 2: 3699 3: 3694
4: 3695 bogomips: 27199
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: vfio-pci
v: N/A alternate: i915 arch: Gen-9.5 process: Intel 14nm built: 2016-20
bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0380
Device-2: NVIDIA GP106 [GeForce GTX 1060 6GB]
vendor: ASUSTeK DUAL-GTX1060-O6G driver: nvidia v: 555.58.02
2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-1,DVI-D-1,HDMI-A-2 empty: DP-2,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-3: AMD Caicos PRO [Radeon HD 7450] vendor: Micro-Star MSI
driver: N/A alternate: radeon, amdgpu arch: TeraScale-2 code: Evergreen
process: TSMC 32-40nm built: 2009-15 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 03:00.0 chip-ID: 1002:677b class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 6400x1440 s-dpi: 92 s-size: 1767x402mm (69.57x15.83")
s-diag: 1812mm (71.34")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,top-center
model: Mi Monitor serial: <filter> built: 2021 res: 2560x1440 dpi: 108
gamma: 1.2 size: 600x330mm (23.62x12.99") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 640x480
Monitor-2: DVI-D-1 mapped: DVI-D-0 note: disabled pos: top-left
model: BenQ ZOWIE XL LCD serial: <filter> built: 2017 res: 1920x1080 dpi: 92
gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9
Monitor-3: HDMI-A-2 mapped: HDMI-1 note: disabled pos: bottom-r
model: Acer K242HL serial: <filter> built: 2014 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77") diag: 609mm (24")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 memory: 5.86 GiB
API: Vulkan v: 1.3.279 layers: 16 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: nvidia v: 555.58.02 device-ID: 10de:1c03
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256
bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM 18.1.8)
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: vfio-pci alternate: snd_hda_intel,snd_soc_avs bus-ID: 00:1f.3
Device-2: NVIDIA GP106 High Definition Audio
vendor: ASUSTeK DUAL-GTX1060-O6G driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f1
Device-3: AMD Caicos HDMI Audio [Radeon HD 6450 / 7450/8450/8490 OEM R5
230/235/235X OEM] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:aa98 class-ID: 0403
Device-4: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0951:16a4 class-ID: 0300
API: ALSA v: k6.10.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF-ID-1: tap-easytether state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: iwd, NetworkManager, systemd-timesyncd
Local Storage: total: 2.05 TiB used: 476.6 GiB (22.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK1N.2 temp: 44.9 C
scheme: MBR
model: WD10EZEX-60ZF5A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
used: 476.6 GiB (51.2%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.51 GiB used: 5.94 GiB (38.3%)
System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 21%
Memory: total: 16 GiB available: 15.51 GiB used: 6.46 GiB (41.6%)
Processes: 358 Power: uptime: 6h 37m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2291 libs: 612
tools: octopi,pamac,paru Compilers: clang: 18.1.8 gcc: 14.1.1
Shell: garuda-inxi default: Zsh v: 5.9 running-in: kitty inxi: 3.3.35
System install date: 2024-01-30
Last full system update: 2024-08-02
Relevant software: snapper NetworkManager dracut(custom) mkinitcpio nvidia-dkms
