Olat
29 January 2021 13:19
1
Hi Team!
Hope you're all having a fantastic day today!
I'm trying to use Mailspring on Garuda, but the following error appears:
After reading the suggested article, I checked if I have everything I need and it appears I do.
When I open the Add/Remove Software, I see that libsecret 0.20.4-1 is installed. Reinstalling both Mailspring and libsecret does not seem to help.
I'm an occasional Linux user and a total Garuda Linux noob, so sorry if what I'm asking is common knowledge - I'm trying to learn!
Thanks in advance!
Best,
Olat
petsam
29 January 2021 14:57
2
Olat:
They suggest having gnome-keyring
. Is it installed?
It also depends on your current DE. Post your info.
Edit: After a small research, it seems gnome-keyring
is required, even if KDE provides kwallet. kwallet is not capable to provide what is required from mailspring, or needs special configuration that I don’t know off.
Olat
29 January 2021 17:51
3
@petsam that did the trick! I installed gnome-keyring from Add/Remove Programs and Mailspring works like a charm now!
Thank you so so much! And what an awesome team you guys have, two issues I've been trying to solve and you guys responded ASAP!
Thanks again and I hope you have a great rest of your day!
