Hello. When i'm trying to instal a global theme i have this error. I don't know what to do and this error is also here when i want to download some icones. If someone can help me please, thanks
Please provide your garuda-inxi
, as requested in the topic template.
hoow i do that
Open a terminal, enter garuda-inxi and copy the output here in the forum formatted like this:
text
The same info can be retreived from the Garuda Assistant -> System Specs
Kernel: 6.3.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=4d5d47c4-1a68-4950-9fcf-fbcb1a98265c rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ROG Strix G513IC_G513IC v: 1.0
Mobo: ASUSTeK model: G513IC v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513IC.329 date: 03/01/2023
ID-1: BAT0 charge: 53.4 Wh (100.0%) condition: 53.4/56.0 Wh (95.3%)
volts: 17.2 min: 15.9 model: AS3GWZC3KC G513-36 type: Li-ion
serial: <filter> status: full
ID-2: hidpp_battery_0 charge: 24% condition: N/A volts: 3.7 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 4284 high: 4294 min/max: 1400/4299 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4276 2: 4276
3: 4279 4: 4279 5: 4279 6: 4275 7: 4276 8: 4276 9: 4292 10: 4294 11: 4293
12: 4292 13: 4292 14: 4292 15: 4294 16: 4291 bogomips: 92625
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a5 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 64.0 C
Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.2.3:10
chip-ID: 1532:0e03 class-ID: 0102
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.83x15.00")
s-diag: 1468mm (57.81")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,top-left
model: Samsung LC34G55T serial: <filter> built: 2022 res: 3440x1440 hz: 100
dpi: 109 gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: max: 3440x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: bottom-r model: BOE Display 0x090f
built: 2020 res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.1-zen2-1-zen) direct-render: Yes
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Device-5: Elgato Systems GmbH Wave XLR driver: snd-usb-audio type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.2.2:9
chip-ID: 0fd9:007d class-ID: fe01 serial: <filter>
Device-6: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-7: Logitech G935 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 3-2:11 chip-ID: 046d:0a87 class-ID: 0300
API: ALSA v: k6.3.1-zen2-1-zen status: kernel-api with: aoss
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:5 chip-ID: 13d3:3563
Local Storage: total: 476.94 GiB used: 76.83 GiB (16.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 36.9 C scheme: GPT
used: 76.83 GiB (16.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.05 GiB used: 210 MiB (1.4%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 64.0 C
Fan Speeds (RPM): cpu: 1900
Processes: 431 Uptime: 1h 17m wakeups: 10 Memory: available: 15.05 GiB
used: 8.96 GiB (59.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1451
libs: 453 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2023-05-11
Last full system update: 2023-05-12
Unfortunately I cannot find that theme in the AUR repository (often installing from there, when possible is less error-prone).
Often these errors generate from the KDE side and there is nothing we can do other than wait and try again.
I don't know if this is the case.
You could also try downloading the file, extracting it and moving the contents in the appropriate folders, but being this a global theme, there will be several sub-folders to properly locate where to copy the files into.
Unfortunately today I'm not on my machine and cannot help more.
This could be e.g.
- what you find in aurorae/themes/ should go into /usr/share/aurorae/themes/
- color-schemes/ into /usr/share/color-schemes/
- plasma/ into into /usr/share/plasma/
Once everything is copied, you can apply things from the System Settings (you should see "Plasma Deck" listed at that time).
But you'll have to play with it a little bit, if you want or, as said, wait and try again later or tomorrow.
That is perfectly normal. It will go away after awhile. Happens with themes, Icons, Cursors, Widgets, ETC... Basically what filo said.
Hmmm so it's just a ramdom issue and i need to force the installation sometimes until it's work ?
Wait or force (by "force" here I mean the manual process, not the "retry").
I'm curious, I like learning and so I always try BUT I always keep note of what I do and keep "backups" (e.g. before you replace a file, always make a copy), so I can revert anything.
This is a good way of learning at least something (even if you fail), but I use Linux only at home, I woudn't do that at work...
If you don't feel confident, don't have the time, etc. it's perfectly fair to wait...
I'm used to "dev" if i can say that but on linux er im still discovdring it. I take some risks because im kinda confident but I prefer to stay safe with some stuff. So it's better to wait I guess. I don't know how to force it. If someome explain me i can try for sure
This happens on the KDE Store occasionally, which is where it grabs the theme. Either the server is having a glitch (happens all the time, just wait and try again later) or the author didn't properly configure/package the theme correctly. Wait it out for them to fix, or best find the actual author's github/git page and report the issue.
Okay i see. I never had this issue before so. Thanks for the answer
