So I updated my system the other day, but only just noticed that my time is out, my timezone data is correct still, but some reason it doesnt sync, having a look at the arch wiki i tried some things to fix it, no luck, ignores hardware time and manual inputted time, running tzselect gives me this output, which I of course say yes to since the information is correct, but it doesnt correct the time data which in this instance is universal time that is shown.
The following information has been given:
Australia
Western Australia (most areas)
Therefore TZ='Australia/Perth' will be used.
Selected time is now: Wed 29 Sep 2021 05:01:56 AWST.
Universal Time is now: Tue 28 Sep 2021 21:01:56 UTC.
Is the above information OK?
1) Yes
2) No
System: Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c3868d62-fbad-48e3-95fd-3cc8bbdf84a6 rw rootflags=subvol=@ quiet splash
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Hewlett-Packard product: HP Pavilion TS 15 Notebook PC
v: 0881100000305E00000620100 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 216C v: 30.26 serial: <filter> UEFI: Insyde v: F.19
date: 07/14/2016
Battery: ID-1: BAT0 charge: 14.7 Wh (100.0%) condition: 14.7/14.7 Wh (100.0%) volts: 16.9
min: 14.8 model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full
CPU: Info: Quad Core model: AMD A10-5745M APU with Radeon HD Graphics bits: 64 type: MCP
arch: Piledriver family: 15 (21) model-id: 13 (19) stepping: 1 microcode: 6001119
cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 16769
Speed: 2096 MHz min/max: 1100/2100 MHz boost: enabled Core speeds (MHz): 1: 2096
2: 2096 3: 2063 4: 2035
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Richland [Radeon HD 8610G] vendor: Hewlett-Packard driver: radeon
v: kernel bus-ID: 00:01.0 chip-ID: 1002:990f class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Realtek HP Truevision HD type: USB driver: uvcvideo bus-ID: 2-4:2
chip-ID: 0bda:571a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: ati,radeon
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.14.8-zen1-1-zen LLVM 12.0.1)
v: 4.3 Mesa 21.2.2 compat-v: 3.1 direct render: Yes
Audio: Device-1: AMD Trinity HDMI Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
driver: rt2800pci v: 2.3.0 port: 3000 bus-ID: 02:00.0 chip-ID: 1814:3290 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Bluetooth: Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A bus-ID: 02:00.1
chip-ID: 1814:3298 class-ID: 0d11
Report: bt-service: enabled,stopped note: tool can't run
Drives: Local Storage: total: 931.51 GiB used: 21.66 GiB (2.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 0002 scheme: GPT
Partition: ID-1: / raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 21.64 GiB (7.4%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.7 MiB (26.8%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 21.64 GiB (7.4%)
ID-4: /var/log raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 21.64 GiB (7.4%)
ID-5: /var/tmp raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 21.64 GiB (7.4%)
ID-1: swap-1 type: zram size: 6.97 GiB used: 768 KiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 51.6 C mobo: N/A
GPU: device: radeon temp: 49.0 C device: radeon temp: 48.0 C
Info: Processes: 224 Uptime: 19m wakeups: 5 Memory: 6.97 GiB used: 2.32 GiB (33.3%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1806 lib: 511 Client: Unknown Client: garuda-assistant inxi: 3.3.06
