Hello,
I am trying to install Garuda LInux as a second OS on my 2019 Macbook Pro 16" using this guide.
However, I am not able to get past the installation from Live USB. The guides I have followed all suggest that I should be able to leave the default EFI partition as is and just install the base system on a free partition. When I tried doing this (using guided disk install), the installer makes it all the way to 91% and then hangs at the step of "Installing bootloader". At this point, the whole system is frozen, fans are at 100%, and nothing is responsive. I've left it here for 10 minutes with no progress.
After doing a reboot, and using rEFInd, I selected the Garuda install but I was thrown into a grub-rescue shell and I was unable to find any boot directory on the partition.
My second attempt at installing Garuda, I did a manual disk partition and I selected the main partition for Garuda and I did not make a partition for EFI and as such the bootloader install was skipped.
Doing this, I was able to finally complete the full install to 100%. However, upon restart, I am brought to a grub shell, and again, there are no boot files to use. I tried to issue a "boot" command, but grub keeps telling me: you need to load kernel first. However, I am still unable to find any vmlinuz or initrd files to supply grub. At this point, I am stuck and don't know how to move forward. All guides I've read online for Ubuntu say that their installer is okay with just using the main macOS EFI.
My third attempt, as with the second I did a manual partition install and put the base OS on my main partition. However, I also allocated a second partition with 300mb, FAT32, boot flag, mount point at: /boot/efi
Doing this, I actually got stuck at 89% for "configuring GRUB" and it froze here.
