Hello, i've some problems after reinstall Garuda Linux with zed free.
I've installed it with the debian package first and get this error.
zed_free: error while loading shared libraries: libldap_r-2.4.so.2: cannot open shared object file: No such file or directory
So i've tried to reinstall openldap and libldap but nothing.
Someone can help me for this error ? thank's
Don’t install package archives intended for different distributions. It will expect a different version of libraries and/or the local system will have no idea how to handle dependencies.
Instead, use the AUR package: https://aur.archlinux.org/packages/zedfree/
Thank's for your reply
The command inxi -Faz
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f2ddd5b6-40b5-49da-8251-4c4b7455fac5
systemd.unified_cgroup_hierarchy=1 resume=UUID=e319ff5a-ce39-4ce7-a73b-3795275a09e4 loglevel=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP ProBook 450 G6 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: HP model: 8538 v: KBC Version 51.1E.00 serial: <superuser required> UEFI: HP
v: R71 Ver. 01.03.00 date: 04/29/2019
Battery: ID-1: BAT0 charge: 41.6 Wh (100.0%) condition: 41.6/41.6 Wh (100.0%) volts: 13.0 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: B (11) microcode: EA cache: L1: 256 KiB L2: 1024 KiB
L3: 8 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31999
Speed: 4272 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 4272 2: 4384 3: 3182 4: 4402
5: 4240 6: 4520 7: 4442 8: 3913
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Lite-On HP HD Camera type: USB driver: uvcvideo bus-ID: 1-2:2 chip-ID: 04ca:7095
class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: i915
note: n/a (using device driver) display-ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:9df0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives: Local Storage: total: 700.51 GiB used: 25.11 GiB (3.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-000H1 size: 476.94 GiB
rev: EXA73H1Q temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 5A scheme: GPT
Partition: ID-1: / raw-size: 206.22 GiB size: 206.22 GiB (100.00%) used: 25.11 GiB (12.2%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 580 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 206.22 GiB size: 206.22 GiB (100.00%) used: 25.11 GiB (12.2%) fs: btrfs
ID-4: /var/log raw-size: 206.22 GiB size: 206.22 GiB (100.00%) used: 25.11 GiB (12.2%)
ID-5: /var/tmp raw-size: 206.22 GiB size: 206.22 GiB (100.00%) used: 25.11 GiB (12.2%)
ID-1: swap-1 type: partition size: 17.05 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 15.5 GiB used: 1.3 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 49.0 C pch: 37.0 C mobo: 0.0 C
Info: Processes: 348 Uptime: 2h 8m wakeups: 2 Memory: 15.5 GiB used: 5.17 GiB (33.4%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 2015 note: see --pkg
apt: 1 pacman: 2014 lib: 358 Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole
inxi: 3.3.09
So i've installed the debian package and after remove to install the Aur zedfree but it's the same
Just tried on a VM.
It wants 2.4, installed is 2.6.
i want understand your problem,
when this error occured ? on boot ..., in installation garuda process ...,
have you install garuda yet
The error is comming when i launch the zed_free command.
Installation is ok.
And sure i'm already on Garuda
Bro
30 November 2021 13:42
8
I have not inspected it, but you may be able to make a small change in the PKGBUILD.
libldap24
is in the AUR - the Zed PKGBUILD should likely include it as a dependency.
AdminSec:
it’s the same
It will be worth reporting this to the AUR package maintainer so it can be fixed for everyone.
This appears to resolve the dependency. The application does launch, beyond that
So how i can install it with the dependency ?
i've just added that to the pkgbuild
depends=("libxslt" "qt5-base" "hicolor-icon-theme" "libldap24")
But same error after makepkg -si
Ok so, here are the commands to make zed work
git clone https://aur.archlinux.org/libldap24.git
cd libldap24
gpg --recv-keys 7F67D5FD1CE1CBCE
makepkg -si
git clone https://aur.archlinux.org/zedfree.git
cd zedfree
makepkg -si
Thank's all for your help !
Did you report the need for the additional dependency to the AUR package maintainer? If not, please do so.
system
Closed
2 December 2021 20:24
13
