Hello,
I noticed last days I cannot launch nautilus. I have to start it from command line but I see there there’s no space left on device.
$ df -h
System plików rozm. użyte dost. %uż. zamont. na
dev 3,6G 0 3,6G 0% /dev
run 3,6G 1,9M 3,6G 1% /run
efivarfs 148K 29K 115K 20% /sys/firmware/efi/efivars
/dev/nvme0n1p2 468G 214G 253G 46% /
tmpfs 3,6G 47M 3,6G 2% /dev/shm
tmpfs 1,0M 0 1,0M 0% /run/credentials/systemd-journald.service
/dev/nvme0n1p2 468G 214G 253G 46% /srv
/dev/nvme0n1p2 468G 214G 253G 46% /home
/dev/nvme0n1p2 468G 214G 253G 46% /root
tmpfs 3,6G 64K 3,6G 1% /tmp
/dev/nvme0n1p2 468G 214G 253G 46% /var/cache
/dev/nvme0n1p2 468G 214G 253G 46% /var/log
/dev/nvme0n1p2 468G 214G 253G 46% /var/tmp
/dev/nvme0n1p1 300M 592K 299M 1% /boot/efi
tmpfs 731M 731M 16K 100% /run/user/1000
Kernel: 6.13.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 rw rootflags=subvol=@
resume=UUID=8f7c97f0-2758-4001-95b0-57f15fb14228 loglevel=3 ibt=off
Desktop: GNOME v: 47.4 tk: GTK v: 3.24.48 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1300
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1300 serial: <superuser required>
part-nu: C178 uuid: <superuser required> UEFI: HUAWEI v: 1.06
date: 09/14/2020
ID-1: BAT0 charge: 15.6 Wh (31.2%) condition: 50.0/54.9 Wh (91.0%)
volts: 7.4 min: 7.6 model: SUNWODA HB4593R1ECW-22S0 type: Li-ion
serial: <filter> status: discharging cycles: 612
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: powersave cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
bogomips: 71864
Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Huaqin driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 33.0 C
Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:5451
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0893 built: 2019 res: 2160x1440
dpi: 185 gamma: 1.2 size: 296x197mm (11.65x7.76") diag: 356mm (14")
ratio: 3:2 modes: max: 2160x1440 min: 640x480
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1636
Info: Tools: api: vulkaninfo wl: wdisplays x11: xdpyinfo, xprop, xrandr
Audio vendor: Huaqin driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: Huaqin driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
vendor: Huaqin driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.4-zen1-1-zen status: kernel-api tools: N/A
vendor: & Tele RSH driver: rtw_8822ce v: kernel modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 1358:c123
Local Storage: total: 476.94 GiB used: 213.17 GiB (44.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1027 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21117000 temp: 36.9 C scheme: GPT
used: 213.16 GiB (45.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 7.13 GiB used: 612 MiB (8.4%) priority: 100
System Temperatures: cpu: 34.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): fan-1: 2746 fan-2: 3180
Memory: total: 8 GiB note: est. available: 7.13 GiB used: 3.22 GiB (45.1%)
Processes: 373 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.81 GiB services: gsd-power,
Packages: 1878 pm: pacman pkgs: 1834 libs: 462
tools: gnome-software,pamac,paru pm: flatpak pkgs: 44 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: Bash v: 5.2.37 running-in: terminology
inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2022-04-09
Last full system update: 2025-02-28 ↻
Failed units: syncthing@przemyslaw.service
cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=BB21-9F2B /boot/efi vfat umask=0077 0 2
UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 / btrfs subvol=/@,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 /home btrfs subvol=/@home,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 /root btrfs subvol=/@root,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 /srv btrfs subvol=/@srv,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 /var/cache btrfs subvol=/@cache,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 /var/log btrfs subvol=/@log,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 /var/tmp btrfs subvol=/@tmp,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=8f7c97f0-2758-4001-95b0-57f15fb14228 swap swap defaults,noatime 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
My tmpfs is full. I can open nautilus without problem when I reboot system but tmpfs still have 100% full. Haw can I fix that?
Regards.
