Issue with my usb audio/headset
I'm having an issue with my usb audio/headset going silent and having to switch outputs to get audio back. When this happens, videos in discord and on my web browser won't play. For reference, I have a Sennheiser GSP 670 headset.
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=eba8e8c6-ff8b-43cc-85da-d14dcc6a3f2b rw [email protected]
loglevel=3 amdgpu.ppfeaturemask=0xffffffff ibt=off
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
UEFI: American Megatrends v: P5.01 date: 01/18/2023
Device-1: hidpp_battery_0 model: Logitech Illuminated LiviIlluminated
LiviIllum serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: discharging
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4030 high: 4841 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4841 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 4564 8: 4564 9: 3700 10: 4550 11: 3700
12: 4547 13: 3700 14: 3700 15: 3700 16: 3700 17: 3700 18: 3700 19: 4529
20: 4550 21: 3700 22: 4549 23: 4547 24: 3700 bogomips: 177590
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: XFX RX-79XMERCB9
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 11:00.0 chip-ID: 1002:744c class-ID: 0300
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung serial: <filter>
built: 2019 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 1630mm (64.2") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 7900 XTX (gfx1100
LLVM 15.0.7 DRM 3.52 6.3.2-zen1-1-zen) direct-render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 13:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: DSEA A/S EPOS GSA 70 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 1395:0300 class-ID: 0300 serial: <filter>
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api with: aoss
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 8087:0029
Hardware-1: Advanced Micro Devices [AMD] Device driver: ahci v: 3.0
port: N/A bus-ID: 0c:00.0 chip-ID: 1022:7916 rev: N/A class-ID: 0104
Hardware-2: Advanced Micro Devices [AMD] Device driver: ahci v: 3.0
port: N/A bus-ID: 0d:00.0 chip-ID: 1022:7916 rev: N/A class-ID: 0104
Local Storage: total: 20.47 TiB used: 1.39 TiB (6.8%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Sabrent model: Rocket Q
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.1 temp: 26.9 C
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Sabrent model: Rocket Q
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS200T2B0A-00SM50 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
ID-6: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
ID-7: /dev/sdd maj-min: 8:48 vendor: HGST (Hitachi) model: HUH721212ALE604
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> fw-rev: 5006 scheme: GPT
used: 18.74 GiB (4.0%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 31.27 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 38.6 C mobo: N/A gpu: amdgpu temp: 47.0 C
mem: 64.0 C
Processes: 503 Uptime: 10m wakeups: 2 Memory: available: 31.27 GiB
used: 5.87 GiB (18.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1912
libs: 554 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-05-15
Last full system update: 2023-05-17 ↻
lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 003 Device 002: ID 1395:0300 DSEA A/S EPOS GSA 70
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 1058:263a Western Digital Technologies, Inc. Game Drive
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 2dc8:3109 8BitDo IDLE
Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Hi there, welcome to the forum!
Let me preface the following by saying that I have no experience in this topic... :wink:
Your description makes me think of a USB power saving problem.
Giving a (very quick) read at this:
https://wiki.archlinux.org/title/Power_management#USB_autosuspend
And this:
https://www.kernel.org/doc/html/v4.16/driver-api/usb/power-management.html
I would suggest trying the kernel boot parameter:
usbcore.autosuspend=-1
Alright, I'll give it a try and report back!
Unfortunately, this did not fix the issue. It does seem to have had an effect on how often it happens. (going from random 1-5 minutes to 10-15 minutes)
  1. Create a text file named:
snd_hda_intel.conf
  1. Insert this line:
options snd_hda_intel power_save=0
  1. Save it in:
/etc/modprobe.d
Reboot: This should keep your Intel audio alive. Cross your fingerrs. :crossed_fingers:
Thank you! I will try this and report back.
Unfortunately, this did not work. I still have to switch between chat and game outputs to bring audio back.
When audio dies, can you check to see if there's an error added to dmesg?
Sure, I'll do that as soon as it happens next.
I see alot of this, but it may be related to corectrl and that the full gamut of features for the RX 7900XTX has not been exposed and implemented yet.
[20235.754278] amdgpu: manual fan speed control should be enabled first
[20235.754305] amdgpu: manual fan speed control should be enabled first
[20235.754363] amdgpu 0000:11:00.0: amdgpu: [smu_v13_0_set_power_limit] Set power limit Failed!
[20235.754483] amdgpu 0000:11:00.0: amdgpu: [smu_v13_0_set_power_limit] Set power limit Failed!
Aside from the problem being sporadic, dmesg shows nothing new after an hour of monitoring.
Just a quick update.
There were some updates for AMDGPU and PowerDevil today, and since those updates, the problem seems to have resolved itself. It's been four hours and no sound input/output issue. Thank you to everyone who gave advice!
Nevermind, it's still happening. It's just much more predictable now.
Have you tried using other USB ports? Literally grasping at straws here.
Great Question, and yes I have tried that. I've purchased a new headset just in case it's only specific to the Sennheiser GSP670.
This is my wpctl status output.
wpctl status
PipeWire 'pipewire-0' [0.3.70, [email protected], cookie:#########]
└─ Clients:
31. pipewire                            [0.3.70, [email protected], pid:5241]
33. WirePlumber                         [0.3.70, [email protected], pid:5239]
34. WirePlumber [export]                [0.3.70, [email protected], pid:5239]
65. xdg-desktop-portal                  [0.3.70, [email protected], pid:5424]
66. Plasma PA                           [0.3.70, [email protected], pid:5530]
67. Steam Voice Settings                [0.3.70, [email protected], pid:6071]
68. Steam                               [0.3.70, [email protected], pid:6071]
69. Chromium input                      [0.3.70, [email protected], pid:6464]
70. Brave input                         [0.3.70, [email protected], pid:14676]
71. WEBRTC VoiceEngine                  [0.3.70, [email protected], pid:49121]
73. Chromium input                      [0.3.70, [email protected], pid:49185]
74. wpctl                               [0.3.70, [email protected], pid:52323]
Audio
├─ Devices:
│      40. EPOS GSA 70                         [alsa]
│      41. HDA ATI HDMI                        [alsa]
│      42. Starship/Matisse HD Audio Controller [alsa]
├─ Sinks:
│      32. Starship/Matisse HD Audio Controller Digital Stereo (IEC958) [vol: 0.40]
│      47. EPOS GSA 70 Chat                    [vol: 1.00]
│  *   48. EPOS GSA 70 Game                    [vol: 1.00]
│      50. HDA ATI HDMI Digital Stereo (HDMI 4) [vol: 0.45]
├─ Sink endpoints:
├─ Sources:
│      46. Starship/Matisse HD Audio Controller Analog Stereo [vol: 1.00]
│  *   49. EPOS GSA 70 Chat                    [vol: 1.00]
├─ Source endpoints:
└─ Streams:
Video
├─ Devices:
├─ Sinks:
├─ Sink endpoints:
├─ Sources:
└─ Streams:
Settings
└─ Default Configured Node Names:
0. Audio/Sink    alsa_output.usb-Sennheiser_EPOS_GSA_70_A002731213801204-00.stereo-game
Just picked up an Audeze Maxwell headset and it looks like the issue only affects the previous Sennheiser GSP670 for whatever reason. Now I just need to figure out how to setup Dolby Atmos in Linux>
lsusb
Bus 003 Device 006: ID 3329:4b19 Audeze Inc Audeze Maxwell Dongle
Bus 001 Device 004: ID 2dc8:3109 8BitDo IDLE
