Issue with Minecraft. How do I install java 17?
I want to play modded minecraft but I need java 17 for it to work
Garuda-inxi:
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=84c2d676-7cb0-47ef-a50a-f71fbbc1a646 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.30
date: 08/31/2020
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4116 high: 4127 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4119 2: 4127
3: 4125 4: 4108 5: 4124 6: 4125 7: 4124 8: 4125 9: 4124 10: 4078 11: 4097
12: 4124 bogomips: 86399
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1
bus-ID: 2b:00.0 chip-ID: 10de:2484 class-ID: 0300
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DP-2 mapped: DP-3 note: disabled pos: primary,right
model: Samsung LF24T35 serial: <filter> built: 2021 res: 1920x1080 dpi: 92
gamma: 1.2 size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9
Monitor-2: HDMI-A-2 mapped: HDMI-1 note: disabled pos: left
model: Dell SE2417HG serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 545.29.06
device-ID: 10de:2484 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 2b:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 5
lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 1038:1250 class-ID: 0300
Device-4: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 03f0:078b class-ID: 0300
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: enp42s0 state: down mac: <filter>
Device-3: TP-Link 802.11ac NIC driver: rtl88x2bu type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 2357:0138
IF: wlp2s0f0u6 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
Local Storage: total: 1.14 TiB used: 109.85 GiB (9.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kikwot model: FS810 250GB
tech: SSD serial: <filter> fw-rev: A25D scheme: GPT
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD
used: 109.85 GiB (47.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 62.0 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 427 Uptime: 21m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 7.82 GiB (25.0%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1873
pm: pacman pkgs: 1858 libs: 534 tools: octopi,pamac,paru pm: flatpak
pkgs: 15 Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-17
Last full system update: 2023-11-26 ↻
I see there is package extra/jre17-openjdk 17.0.9.u8-2, maybe that?
How are you installing Minecraft? All up to date launchers should have the proper dependencies listed.
I haven’t played Minecraft in years, but most people seem to use Prism Launcher now for mods.
More info on Minecraft and launchers here Minecraft - ArchWiki
how would I install this package?
yay -S jdk17-openjdk
If you need several different java versions, I can highly recommend SDKMAN (https://sdkman.io/).
You can actually have several different versions of java downloaded straight from pacman and use the one you want using archlinux-java shell script provided by the java-runtime-common package.
