guys 1st of all i cannot upload image so i uploaded it to imgur website. guys please help and tell me why shell in my kitty terminal is like that? i didn't found solution to this anywhere and hope to find it here. you can see the neovim is not occupying the full terminal space and that is not just neovim but any other program will do the same even the shell. Please help
I have moved your thread (from Garuda Community to the Issues and Assistance category) and renamed it to something more specific.
Please also follow the issue template:
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
hi, this issue in terminal is always there for me whenever i use a wm. and this must be some config i am not aware of because if i download and install any ready made config of any wm then this issue disappears but i want to have my own config. and yes this is some config which needs to be done because i once cloned a github repo and used that config of someone else and this issue was gone. so please someone tells me what i need to setup.
Edit your post and format it nicely.
