hello, i accessed my computer after a long time (last accessed around October 2023) and after getting it, i went for a full system upgrade,
i was using latte dock even after the release of garuda raptor where it officially ended all supports with latte dock, but it went good for a long time with out any issues until this update
after the update was finished, i rebooted my computer to find out the new fresh formatted garuda look where the late dock stopped working and the icons had totally changed. eventually i worked around with it(the latte dock thing) but one thing that caught my attention was that the default garuda raptor had background blur (active blur plugin )enabled and the menus were blurred but it seems too be a bit different here.
the terminal and the application launcher widget seems to be perfectly blurred
but other applications like dolphin, system settings and the menus are not blurred
(this does not goes the panels)
and note: desktop effects are enabled for that
along with this , the active blur plugin is also not working after the update, it just makes everything black and shows no wallpaper
i tried too check the compositor, but i cant find any options like latency, scale method, rendering backend or that “prefer smoother animations” that used to be there
i just want my blurred application background back
here is my garuda-inxi
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9e335fc5-a078-4f7e-9a75-6945c86d4bac rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A wm: kwin_x11 with: latte-dock
Type: Desktop System: Dell product: OptiPlex 7050 v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: Dell model: 0D24M8 v: A01 serial: <filter> part-nu: 07A1
uuid: 4c4c4544-0046-3710-8031-b5c04f384e32 UEFI: Dell v: 1.27.0
date: 09/18/2023
Info: model: Intel Core i3-6100 socket: U3E1 bits: 64 type: MT MCP
arch: Skylake-S gen: core 6 level: v3 note: check built: 2015
process: Intel 14nm family: 6 model-id: 0x5E (94) stepping: 3
microcode: 0xF2
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 max: 800 base/boost: 800/4200 scaling:
driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 6399
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0300
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 380x237mm (14.96x9.33")
s-diag: 448mm (17.63")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: HDMI built: 2020 res: 1440x900
dpi: 64 size: 575x323mm (22.64x12.72") modes: max: 1440x900 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:1912 memory: 15.12 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 530 (SKL GT2) driver: mesa intel v: 24.0.2-arch1.2
device-ID: 8086:1912 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM
Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 8087:0a2b
Local Storage: total: 596.18 GiB used: 108.53 GiB (18.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Ant Esports model: 690 NEO SATA 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 8B0 temp: 40 C
SMART: yes state: enabled health: PASSED on: 66d 12h cycles: 1563
read: 57.3 MiB written: 48.1 MiB
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Bics size: 119.24 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 0015 drive-rev: V0718B0 temp: 34 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 64d 20h cycles: 1721
read: 175.8 MiB written: 39 MiB
ID-1: / raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
used: 108.49 GiB (46.3%) fs: btrfs block-size: 4096 B dev: /dev/sda4
maj-min: 8:4
used: 45.6 MiB (47.5%) fs: vfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
maj-min: 8:4
ID-4: /var/log raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
maj-min: 8:4
ID-5: /var/tmp raw-size: 234.38 GiB size: 234.38 GiB (100.00%)
maj-min: 8:4
ID-1: swap-1 type: zram size: 15.49 GiB used: 915.5 MiB (5.8%)
System Temperatures: cpu: 32.0 C mobo: N/A
Memory: total: 16 GiB available: 15.49 GiB used: 6.79 GiB (43.9%)
igpu: 32 MiB
Processes: 252 Power: uptime: 10h 34m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
Packages: 1684 pm: pacman pkgs: 1677 libs: 463 tools: octopi,paru
pm: flatpak pkgs: 7 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-06-17
Last full system update: 2024-03-10 ↻
Windows dual boot: Yes
any help would be appreciated, and sorry for my bad English
