Hello again! I’ve got an issue with alacritty migrate.
sudo alacritty migrate
Configuration file migration failed:
"/root/.config/alacritty/alacritty.toml": already in TOML format
If I reopen alacritty it still says the same warning
YAML config “/home/user/.config/alacritty/alacritty/yml” is deprecated, please migrate to TOML unsing ‘alacritty migrate’
when I those
it gets replaceed by the following error message
[ERROR]
($ALACRITTY_LOG) :
unable to loead config
“/home/user/.config/alacritty/alacritty.yml” : Config error : duplicate entry with key “window” at line 6 column 1
micro ~/.config/alacritty/alacritty.yaml
shows the env: entry at line 6
and the toml file does not exist at all.
[🔴] × garuda-inxi
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 13.2.1 clocksource: tsc avail: acpi_pm
root=UUID=48637f32-6542-4b8d-9034-f859ede8855e rw
rootflags=subvol=@ quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=73407c84-654f-4dc0-9a0c-af4b77f8503c
loglevel=3 ibt=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: bspwm
v: 0.9.10 with: xfce4-panel tools: avail: xautolock vt: 7
Type: Laptop System: Hewlett-Packard product: HP
EliteBook Folio 9480m v: A3009DD10303
serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 22DA v: KBC Version 92.15
serial: <superuser required> part-nu: K6E26UC#ABD
uuid: <superuser required> UEFI: Hewlett-Packard
v: M85 Ver. 01.33 date: 10/27/2015
ID-1: BAT0 charge: 30.8 Wh (95.1%)
condition: 32.4/32.4 Wh (100.0%) volts: 16.4 min: 14.8
model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i7-4600U bits: 64 type: MT MCP
arch: Haswell gen: core 4 level: v3 note: check
built: 2013-15 process: Intel 22nm family: 6
model-id: 0x45 (69) stepping: 1 microcode: 0x26
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4
smt: enabled cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2096 high: 2097 min/max: 800/3300
scaling: driver: intel_cpufreq governor: performance
cores: 1: 2096 2: 2097 3: 2095 4: 2096 bogomips: 21550
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1
sse4_2 ssse3
Device-1: Intel Haswell-ULT Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel
arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Chicony HP HD Webcam driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 2-7:5 chip-ID: 04f2:b477 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.11 compositor: Picom
v: git-c4107 driver: X: loaded: intel
unloaded: modesetting alternate: fbdev,vesa dri: i965
Screen-1: 0 s-res: 1366x768 s-dpi: 96
s-size: 361x203mm (14.21x7.99") s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP1
model: ChiMei InnoLux 0x14a4 built: 2014 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 355mm (14") ratio: 16:9 modes: 1366x768
API: Vulkan v: 1.3.276 layers: 3 device: 0
type: integrated-gpu name: Intel HD Graphics 4400 (HSW
GT2) driver: mesa intel v: 24.0.1-arch1.1
device-ID: 8086:0a16 surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM 16.0.6)
API: OpenGL Message: Unable to show GL data. glxinfo
is missing.
Device-1: Intel Haswell-ULT HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio
vendor: Hewlett-Packard 8 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api
Server-1: JACK v: 1.9.22 status: off tools: N/A
Server-2: PipeWire v: 1.0.3 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with:
1: pulseaudio-alsa type: plugin 2: pulseaudio-jack
type: module tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0
chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
chip-ID: 8086:08b1 class-ID: 0280
Info: services: NetworkManager, systemd-timesyncd,
wpa_supplicant
Device-1: Intel Bluetooth wireless interface
driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 2-4:3 chip-ID: 8087:07dc
Report: btmgmt ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no
software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 238.47 GiB used: 56.13 GiB (23.5%)
SMART Message: Required tool smartctl not installed.
Check --recommends
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk
model: SD7TB3Q-256G-1006 size: 238.47 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0306 scheme: GPT
ID-1: / raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
used: 56.13 GiB (24.5%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB
size: 252 MiB (98.46%) used: 570 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 229.42 GiB
size: 229.42 GiB (100.00%) used: 56.13 GiB (24.5%)
ID-4: /var/log raw-size: 229.42 GiB
ID-5: /var/tmp raw-size: 229.42 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 7.64 GiB
used: 1.52 GiB (19.8%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4
ID-2: swap-2 type: partition size: 8.8 GiB
used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
System Temperatures: cpu: 42.0 C mobo: N/A
Memory: total: 8 GiB available: 7.64 GiB
used: 3.94 GiB (51.6%)
Processes: 240 Power: uptime: 19h 27m
states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 3.02 GiB
services: upowerd,xfce4-power-manager Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1484 libs: 442
tools: pamac,paru Compilers: clang: 16.0.6 gcc: 13.2.1
Shell: garuda-inxi default: fish v: 3.7.0
running-in: alacritty inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2021-09-03
Last full system update: 2024-02-20 ↻
Relevant software: timeshift NetworkManager mkinitcpio
also tried the migrate -i option with and without sudo
λ alacritty migrate -i
"/home/user/.config/alacritty/alacritty.yml": parsing error: Config error: duplicate entry with key "window" at line 6 column 1
sudo alacritty migrate -i
[sudo] password for user:
thank you very for the awesome support!
best regards
algori
