Issue: Updating software after system update after one year
Hello Garuda Linux Forum,
I’ll admit I haven’t dabbled with Garuda in quite some time, and applied a recent garuda-update in the konsole.
Kernel: 6.5.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=73c5507d-4265-4269-ac80-cbf5d27d3c33 rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F15
date: 01/04/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2687 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3700 2: 2200
3: 2200 4: 2200 5: 2874 6: 3700 7: 2200 8: 2200 9: 3700 10: 2200 11: 2874
12: 2200 bogomips: 88633
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0d:00.0
chip-ID: 1002:73df class-ID: 0300
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LCD TV built: 2013
res: 1920x1080 hz: 60 dpi: 3048 gamma: 1.2 size: 16x9mm (0.63x0.35")
diag: 6mm (0.2") ratio: 15:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon RX 6700 XT
(navi22 LLVM 16.0.6 DRM 3.54 6.5.2-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab28
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.5.2-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:0608
IF: wlp10s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 0e8d:0608
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 3.64 TiB used: 42.1 GiB (1.1%)
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234140WD temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
fw-rev: 234140WD temp: 27.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 42.1 GiB (2.3%)
used: 42.1 GiB (2.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 42.8 C mobo: 33.0 C gpu: amdgpu temp: 36.0 C
mem: 30.0 C
Processes: 317 Uptime: 5m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 2.2 GiB (7.0%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1473 libs: 412 tools: octopi,pamac,paru
inxi: 3.3.29
System install date:     2022-06-17
Last full system update: 2023-09-11
Is partially upgraded:   Yes
While everything seems to be working as should upon startup (including software itself), for every time I attempt an update on the software (this time using an update tool to manually select updates), I receive a notification from the System Maintenance tool, issuing the following…
Dependency resolution failed:<br/><br/>plasma-framework &lt;- latte-dock: could not satisfy dependencies
Nevertheless, my system overall seems to be up to date, though please correct me if I’m wrong, and perhaps if I missed an integral system upgrade or configuration that might be the cause of this issue.
My experience with this distro has been stellar, even as we speak - I’m just concerned regarding upon the current issue, and hopefully preventing it from impacting anything else in the long-run.
Thank you,
You’ll need to remove Latte Dock cause it’s not supported by Plasma 6. If you don’t mind me asking how old is the ISO you used to install Garuda?
Originally, the ISO used dates back to May/June 2022.
I say originally, because an issue around that time occurred where I had to chroot my system and update GRUB after making an update about a month later.
It’s all in garuda-inxi
I don’t mean this in a bad way, but if you haven’t used or updated a rolling Linux distribution for so long, you should reinstall it. Even if an update were to run now,
which hasn’t happened (partially upgraded), new problems will surely arise over time.
You can of course keep trying, but I don’t know what would motivate us to solve one problem after another for you under these circumstances?
Back up your important data beforehand. :slight_smile:
Could I just simply remove Latte Dock like suggested above?
Don’t know if this info helps…
-> Refreshing mirrorlists using rate-mirrors, please be patient..🍵
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
:: Replace appstream-qt with extra/appstream-qt5? [Y/n] y
:: Replace attica with extra/attica5? [Y/n] y
:: Replace bluez-qt with extra/bluez-qt5? [Y/n] y
:: Replace breeze with extra/breeze5? [Y/n] y
:: Replace dbus-python with extra/python-dbus? [Y/n] y
:: Replace frameworkintegration with extra/frameworkintegration5? [Y/n] y
:: Replace kactivities with extra/kactivities5? [Y/n] y
:: Replace kactivities with extra/plasma-activities? [Y/n] y
:: Replace kactivities-stats with extra/kactivities-stats5? [Y/n] y
:: Replace kactivities-stats with extra/plasma-activities-stats? [Y/n] y
:: Replace karchive with extra/karchive5? [Y/n] y
:: Replace kauth with extra/kauth5? [Y/n] y
:: Replace kbookmarks with extra/kbookmarks5? [Y/n] y
:: Replace kcmutils with extra/kcmutils5? [Y/n] y
:: Replace kcodecs with extra/kcodecs5? [Y/n] y
:: Replace kcompletion with extra/kcompletion5? [Y/n] y
:: Replace kconfig with extra/kconfig5? [Y/n] y
:: Replace kconfigwidgets with extra/kconfigwidgets5? [Y/n] y
:: Replace kcontacts with extra/kcontacts5? [Y/n] y
:: Replace kcoreaddons with extra/kcoreaddons5? [Y/n] y
:: Replace kcrash with extra/kcrash5? [Y/n] y
:: Replace kdbusaddons with extra/kdbusaddons5? [Y/n] y
:: Replace kdeclarative with extra/kdeclarative5? [Y/n] y
:: Replace kded with extra/kded5? [Y/n] y
:: Replace kdesu with extra/kdesu5? [Y/n] y
:: Replace kdnssd with extra/kdnssd5? [Y/n] y
:: Replace kdsoap with extra/kdsoap-qt5? [Y/n] y
:: Replace kglobalaccel with extra/kglobalaccel5? [Y/n] y
:: Replace kguiaddons with extra/kguiaddons5? [Y/n] y
:: Replace kholidays with extra/kholidays5? [Y/n] y
:: Replace ki18n with extra/ki18n5? [Y/n] y
:: Replace kiconthemes with extra/kiconthemes5? [Y/n] y
:: Replace kidletime with extra/kidletime5? [Y/n] y
:: Replace kimageformats with extra/kimageformats5? [Y/n] y
:: Replace kio with extra/kio5? [Y/n] y
:: Replace kirigami-addons with extra/kirigami-addons5? [Y/n] y
:: Replace kitemmodels with extra/kitemmodels5? [Y/n] y
:: Replace kitemviews with extra/kitemviews5? [Y/n] y
:: Replace kjobwidgets with extra/kjobwidgets5? [Y/n] y
:: Replace knewstuff with extra/knewstuff5? [Y/n] y
:: Replace knotifications with extra/knotifications5? [Y/n] y
:: Replace knotifyconfig with extra/knotifyconfig5? [Y/n] y
:: Replace kpackage with extra/kpackage5? [Y/n] y
:: Replace kparts with extra/kparts5? [Y/n] y
:: Replace kpeople with extra/kpeople5? [Y/n] y
:: Replace kpty with extra/kpty5? [Y/n] y
:: Replace kservice with extra/kservice5? [Y/n] y
:: Replace ksysguard with extra/plasma-systemmonitor? [Y/n] y
:: Replace ktexteditor with extra/ktexteditor5? [Y/n] y
:: Replace ktextwidgets with extra/ktextwidgets5? [Y/n] y
:: Replace kunitconversion with extra/kunitconversion5? [Y/n] y
:: Replace kwallet with extra/kwallet5? [Y/n] y
:: Replace kwayland with extra/kwayland5? [Y/n] y
:: Replace kwidgetsaddons with extra/kwidgetsaddons5? [Y/n] y
:: Replace kwindowsystem with extra/kwindowsystem5? [Y/n] y
:: Replace kxmlgui with extra/kxmlgui5? [Y/n] y
:: Replace libqaccessibilityclient with extra/libqaccessibilityclient-qt5? [Y/n] y
:: Replace mhwd-db-garuda-git with garuda/mhwd-db-garuda? [Y/n] y
:: Replace mhwd-garuda-git with garuda/mhwd-garuda? [Y/n] y
:: Replace modemmanager-qt with extra/modemmanager-qt5? [Y/n] y
:: Replace networkmanager-qt with extra/networkmanager-qt5? [Y/n] y
:: Replace plasma-framework with extra/libplasma? [Y/n] y
:: Replace plasma-framework with extra/plasma-framework5? [Y/n] y
:: Replace plasma-integration with extra/plasma5-integration? [Y/n] y
:: Replace plasma5-applets-window-buttons with extra/plasma-applet-window-buttons? [Y/n] y
:: Replace prison with extra/prison5? [Y/n] y
:: Replace purpose with extra/purpose5? [Y/n] y
:: Replace qqc2-desktop-style with extra/qqc2-desktop-style5? [Y/n] y
:: Replace solid with extra/solid5? [Y/n] y
:: Replace sonnet with extra/sonnet5? [Y/n] y
:: Replace syndication with extra/syndication5? [Y/n] y
:: Replace syntax-highlighting with extra/syntax-highlighting5? [Y/n] y
:: Replace threadweaver with extra/threadweaver5? [Y/n] y
resolving dependencies...
:: There are 2 providers available for qt6-multimedia-backend:
:: Repository extra
1) qt6-multimedia-ffmpeg  2) qt6-multimedia-gstreamer
Enter a number (default=1): 1
:: There are 3 providers available for phonon-qt6-backend:
:: Repository extra
1) phonon-qt6-vlc
:: Repository chaotic-aur
2) phonon-qt6-gstreamer-git  3) phonon-qt6-mpv
:: garuda-dr460nized and plasma5-applets-window-appmenu are in conflict. Remove plasma5-applets-window-appmenu? [y/N] y
:: garuda-dr460nized and plasma5-applets-window-title are in conflict. Remove plasma5-applets-window-title? [y/N] y
:: garuda-dr460nized and plasma5-applets-betterinlineclock-git are in conflict. Remove plasma5-applets-betterinlineclock-git? [y/N] y
:: garuda-dr460nized and plasma5-wallpapers-blurredwallpaper are in conflict. Remove plasma5-wallpapers-blurredwallpaper? [y/N] y
:: plasma5-themes-sweet-full-git and sweet-theme-full-git are in conflict. Remove sweet-theme-full-git? [y/N] y
:: plasma5-themes-sweet-kde-git and sweet-kde-theme-git are in conflict. Remove sweet-kde-theme-git? [y/N] y
:: removing plasma-framework breaks dependency 'plasma-framework' required by latte-dock
╭─in ~ as 🧙 took 43s
I just wanted to make sure I wasn’t seeing things :rofl: :rofl: :rofl:
You should explain this a little more.
What tool?
What do you mean with “manually select updates”?
One may think that you are applying partial updates… :thinking:
As for the update issues, you may be lucky and you just have to uninstall latte-dock . If so, you are very lucky. :smiley:
The update tool provided via Setup Assistant for Discover
Updating via konsole, it always asks at the very end of the process to enter a value; default number being 1.
Entering 1, I get an error message.
This I’m assuming is Latte Dock conflicting with Plasma 6 (which I don’t have) as mentioned.
Note: My current system reads Plasma 5.
That is not a way to update arch. use garuda-update -a at the least but yea at this point. a back up an reinstall would be faster an pain free.
I’ll uninstall Latte Dock and see if anything gets resolved.
Otherwise reinstall it is.
I hear backup being thrown around on Arch Wiki, though I admittedly never done so before.
Not to get too off topic, but is there any recommended GUI for such, especially on a system completely dedicated to run an Arch-based Linux distro like Garuda?
I’m asking this, because losing anything in the process is the last thing that I would want to risk.
You can just move the home dir to another drive though before you move it back you have to set the permissions to your new user or you will have some problems
So no GUI necessary? Just two separate physical drives?
That’s at least how I do it when I need to. you can use you file manager or use terminal what ever floats your poat though the permission bit i would do with terminal but it can be done with root priv in a gui
I cant say this is the 100% correct way but it works. though since your setup is pretty old i might be best not to include the . files like .config .local an all that
Just to be on the safe side, this is the command used to uninstall Latte Dock prior to rebooting?
sudo pacman -Rsu latte-dock
Again, I don’t have Plasma 6.
That or paru -R latte-dock or to also remove dependencies with it paru -Rs
With the amount of time on this I would of simply gotten the current release ISO and reinstalled Garuda. For myself from start of install, to landing on the desktop, to tweaking, to getting all my software installed it’s under 6 hours.
As for the age of the install and someone can correct me if I’m wrong since you did a recent update you should be on Plasma 6 unless something in the old install simply won’t allow Plasma to update.
Without this being updated to the latest Plasma I see no reason to give support cause if Plasma isn’t updated most likely plenty isn’t updated.
Apologies for the delay, but I have found a solution (albeit through blind experimentation) on the same day of posting this topic; and I wouldn’t have done it without the help of any/everyone’s suggestion(s).
petsam mentioned to simply uninstall Latte Dock, followed by restarting/rebooting the system; afterwards applying garuda-update as usual… rinse & repeat, lastly the environment is updated good as new with Plasma 6 fired up and ready to go.
No distro reinstallation necessary.
Cheers,
:+1:
