Issue Staying Logged into Sites in Browser
Hello Team!
So I use Brave Browser regularly, and normally after install, the KDE wallet prompts me to set up a password when I first open the browser. However, on this install, I was never prompted to set a wallet password. Now, whenever I log into sites (such as the Garuda Forum), if the browser is closed, I then need to log back into a site every time I reopen the browser. I've tested this with Firedragon, Firefox as well with the same results. It doesn't matter if I reboot the computer or not. It will not keep me logged into any site. Any thoughts? Thanks!
root=UUID=6eb3aa61-e6de-42bf-87fa-c1d2f4f87877 rw [email protected]
resume=UUID=3c9f7303-a573-42ad-b85e-20d9823581d1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Dash F15 FX516PM_FX516PM
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX516PM v: 1.0 serial: <filter> UEFI: American
Megatrends LLC. v: FX516PM.329 date: 02/01/2023
ID-1: BAT0 charge: 60.1 Wh (95.4%) condition: 63.0/76.0 Wh (82.9%)
status: discharging cycles: 178
Info: model: 11th Gen Intel Core i7-11370H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0xA6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1617 high: 3300 min/max: 400/4800 base/boost: 3300/4800
ext-clock: 100 MHz cores: 1: 3300 2: 3300 3: 1163 4: 1058 5: 1046 6: 834
7: 1200 8: 1041 bogomips: 52838
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-3,DP-5 off: eDP-1 empty: DP-1, DP-2, DP-4, HDMI-A-2
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-03)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 ports:
active: none empty: HDMI-A-1 bus-ID: 0000:01:00.0 chip-ID: 10de:2520
Device-3: Creative Live! Cam Sync 1080p type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-2.1.3:9 chip-ID: 041e:409f
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
s-diag: 1245mm (49.01")
Monitor-1: not-matched mapped: DP-1-1 pos: bottom-r res: 1920x1080 hz: 75
dpi: 102 size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
Monitor-2: not-matched mapped: DP-1-3 pos: primary,top-left res: 2560x1440
hz: 120 dpi: 93 size: 697x392mm (27.44x15.43") diag: 800mm (31.48")
modes: N/A
Monitor-3: eDP-1 note: disabled model: Najing CEC Panda 0x004d built: 2019
res: 2560x1440 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 3-5:4
alternate: snd_sof_pci_intel_tgl chip-ID: 1b1c:0a4f class-ID: 0300
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
Device-3: Corsair HS70 Pro Wireless Gaming Headset type: USB
Device-4: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2.1.1.2:10
chip-ID: 17ef:3083 class-ID: 0300 serial: <filter>
Device-5: Creative Live! Cam Sync 1080p type: USB
Device-6: C-Media Q9-1 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 5-2.1.4:11 chip-ID: 0d8c:0135 class-ID: 0300
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.70 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:2e:00.0
Device-3: Lenovo ThinkPad TBT 3 Dock type: USB driver: r8152
bus-ID: 6-2.1.2:5 chip-ID: 17ef:3082 class-ID: 0000 serial: <filter>
IF: enp4s0u2u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
address: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 14.82 GiB (3.1%)
rev: FXM7201Q temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 106d 3h cycles: 1,681
read-units: 32,314,701 [16.5 TB] written-units: 50,775,003 [25.9 TB]
ID-1: / raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
used: 14.82 GiB (3.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.32 GiB used: 45.5 MiB (0.3%)
ID-2: swap-2 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 302 Uptime: 5h 7m wakeups: 12 Memory: 15.32 GiB
used: 7.03 GiB (45.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1408
libs: 388 tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date:     2023-05-03
Last full system update: 2023-05-03 ↻
you have updates that are pending a reboot.
check the preferences of your browsers, for security reasons those browsers may be set to "clear history"(which includes logged in sessions) when closed.
I saw that after posting my inxi. Rebooted and same result.
I checked the browser history settings and it's not set to clear upon close. Good suggestions though, thanks!
Doing a fresh reinstall fixed the issue.
Sorry @SGS for putting this under the wrong category. Since the issue was about kwallet rather than browsers, I figured it went under KDE Plasma category. The browsers were simply what were affected in my time of testing. Thanks for correcting.
Hey there!
Have you solved the issue somehow? My brave doesn't allow me to sync as well..
Hey!
So I wasn't able to get kwallet to work even reinstalling kwallet or anything. I ended up reinstallilng my system and that somehow fixed the issue.
it may have been a pacnew situation. have you checked for pacnew in your system?
https://wiki.archlinux.org/title/Pacman/Pacnew_and_Pacsave
