Hey. I saw that microphone with XLR on Linux is quite complicated to use but i didn't find any revelant answer. I know that Elgato and Linux are not friend and i don't care. If I am on Linux it's because I believe in gaming on this Os.
So I don't care if I can't use the app Wave Link. I saw that the audio manager already do the same and i can adjust the sound of every application. Exactly what I need.
My problem is the quality of my Wave DX. I don't want to buy a another external sound card for my DX. I spend 160€ on my Wave XLR so I don't want to change my sound card. The DX is awesome I love it but I have so much difficulty to use it. Sometimes i have sound from my DX but it's really poor. So how to improve my DX with the Wave XLR on linux ?
Kernel: 6.3.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=4d5d47c4-1a68-4950-9fcf-fbcb1a98265c rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ROG Strix G513IC_G513IC v: 1.0
Mobo: ASUSTeK model: G513IC v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513IC.329 date: 03/01/2023
ID-1: BAT0 charge: 53.4 Wh (100.0%) condition: 53.4/56.0 Wh (95.3%)
volts: 17.2 min: 15.9 model: AS3GWZC3KC G513-36 type: Li-ion
serial: <filter> status: full
ID-2: hidpp_battery_0 charge: 24% condition: N/A volts: 3.7 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 4284 high: 4294 min/max: 1400/4299 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4276 2: 4276
3: 4279 4: 4279 5: 4279 6: 4275 7: 4276 8: 4276 9: 4292 10: 4294 11: 4293
12: 4292 13: 4292 14: 4292 15: 4294 16: 4291 bogomips: 92625
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a5 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 64.0 C
Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.2.3:10
chip-ID: 1532:0e03 class-ID: 0102
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.83x15.00")
s-diag: 1468mm (57.81")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,top-left
model: Samsung LC34G55T serial: <filter> built: 2022 res: 3440x1440 hz: 100
dpi: 109 gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: max: 3440x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: bottom-r model: BOE Display 0x090f
built: 2020 res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.1-zen2-1-zen) direct-render: Yes
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Device-5: Elgato Systems GmbH Wave XLR driver: snd-usb-audio type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.2.2:9
chip-ID: 0fd9:007d class-ID: fe01 serial: <filter>
Device-6: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-7: Logitech G935 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 3-2:11 chip-ID: 046d:0a87 class-ID: 0300
API: ALSA v: k6.3.1-zen2-1-zen status: kernel-api with: aoss
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:5 chip-ID: 13d3:3563
Local Storage: total: 476.94 GiB used: 76.83 GiB (16.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 36.9 C scheme: GPT
used: 76.83 GiB (16.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.05 GiB used: 210 MiB (1.4%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 64.0 C
Fan Speeds (RPM): cpu: 1900
Processes: 431 Uptime: 1h 17m wakeups: 10 Memory: available: 15.05 GiB
used: 8.96 GiB (59.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1451
libs: 453 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2023-05-11
Last full system update: 2023-05-12
Instead of adding an empty "bump" to the thread, which is considered annoying and somewhat selfish, consider making an effort to update the thread with relevant information instead.
Add a note about something you have tried to fix the issue, for example, or add a link to a resource you have read through in your efforts to resolve the problem and explain why it didn't work. This type of update is more meaningful and useful than just the word "bump", which contributes nothing.
My microphone just don't work properly. I tried on Discord and others app I also tried to install wave link but yeah its not possible so i will bump this topic because im new on linux and i need help i dont know what to do
