Hi garuda team,
whenever i try to install kde theme from its store it shows me error
Installation of /tmp/ALgEFY-Utterly-Sweet-Solid.tar.xz failed: Could not install dependency: 'kns://plasma-themes.knsrc/api.kde-look.org/2011605'
pls help asap.
Kernel: 6.3.2-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=686a2e05-3e59-425c-ba66-a828a07e8439 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec2xxx v: N/A
Mobo: HP model: 88DD v: 96.34 serial: <superuser required> UEFI: AMI
v: F.24 date: 02/22/2023
ID-1: BAT0 charge: 9.3 Wh (22.4%) condition: 41.5/41.5 Wh (100.0%)
volts: 12.2 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: charging
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 192 MiB desc: 12x16 MiB
Speed (MHz): avg: 1373 high: 3300 min/max: 1200/4280 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1197 2: 1200
3: 1197 4: 1200 5: 1200 6: 3300 7: 1200 8: 1200 9: 1194 10: 1198 11: 1200
12: 1200 bogomips: 79075
Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: N/A
alternate: nouveau non-free: 530.xx+ status: current (as of 2023-05)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 41.0 C
Device-3: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
chip-ID: 30c9:0035 class-ID: fe01 serial: <filter>
compositor: kwin_x11 driver: gpu: amdgpu display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0058 built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.2-arch1-1) direct-render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.3.2-arch1-1 status: kernel-api tools: N/A
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8852
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0bda:2852
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
Local Storage: total: 476.94 GiB used: 10.06 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: PC711 HFS512GDE9X073N size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS0 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 200.5 GiB size: 200.5 GiB (100.00%) used: 9.97 GiB (5.0%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 94.1 MiB (36.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 200.5 GiB size: 200.5 GiB (100.00%)
used: 9.97 GiB (5.0%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 200.5 GiB size: 200.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 200.5 GiB size: 200.5 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.11 GiB used: 746.8 MiB (10.3%)
System Temperatures: cpu: 51.1 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 340 Uptime: 6h 19m wakeups: 233 Memory: available: 7.11 GiB
used: 5.42 GiB (76.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1371
libs: 379 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2023-05-19 ↻
Failed units: nmb.service systemd-vconsole-setup.service```
You have a brand new installation and you have not rebooted. Please do so.
i did
but same issue
╰─λ garuda-inxi
loglevel=3 ibt=off
ID-1: BAT0 charge: 39.5 Wh (95.2%) condition: 41.5/41.5 Wh (100.0%)
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1265 high: 1397 min/max: 1200/4280 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1397
3: 1198 4: 1200 5: 1200 6: 1197 7: 1200 8: 1200 9: 1200 10: 1397 11: 1200
12: 1396 bogomips: 79082
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 48.0 C
Local Storage: total: 476.94 GiB used: 10.08 GiB (2.1%)
fw-rev: HPS0 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 200.5 GiB size: 200.5 GiB (100.00%) used: 9.99 GiB (5.0%)
used: 9.99 GiB (5.0%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-1: swap-1 type: zram size: 7.11 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 60.8 C mobo: N/A gpu: amdgpu temp: 49.0 C
Processes: 356 Uptime: 1m wakeups: 1 Memory: available: 7.11 GiB
used: 3.32 GiB (46.6%) Init: systemd v: 253 default: graphical
Try getting it through the front door.
Utterly Sweet Solid - KDE Store
yes i did from there also
i install ocs-url then install the theme
nothing worked.
Even i download the themes and put in /plasma/desktoptheme (where all the themes are stored ,exact path don't know but i pasted it there as there r more themes present already) but nothing shows in setting
system
Closed
2 June 2023 04:33
7
